On 2/15/2017 12:21 PM, Larry Dighera wrote:
Is it time for venerated pilot Harrison Ford to ground himself for less than adequate judgment skills to act as Pilot In Command? The runway is the one with the big "20L" painted on its near-end. This ignominious incident is worse than Senator Inhoff's landing on a taxiway because there was a big X on the runway. Nonsense Larry. Did you bother taking a glance at the airport diagram? Anytime you have parallel runways, with one fat and the other skinny, this incident will occasionally happen because it's easy to focus on only the skinny runway while confusing it for the larger parallel runway. It's a matter of sight fixation (seeing what you expect to see) Once you've done that, then the even skinnier taxiway becomes the "skinny" runway in the pilot's head. I know that it happens at PBIA, and that pilots are specifically warned about it. That's not to say that Ford is blameless, only that he made a typical and well-known pilot screwup. However it's OTT to imply that one incident means a pilot should be grounded. |
On Wed, 15 Feb 2017 21:03:57 -0500, Vaughn Simon wrote:
On 2/15/2017 12:21 PM, Larry Dighera wrote: Is it time for venerated pilot Harrison Ford to ground himself for less than adequate judgment skills to act as Pilot In Command? The runway is the one with the big "20L" painted on its near-end. This ignominious incident is worse than Senator Inhoff's landing on a taxiway because there was a big X on the runway. Nonsense Larry. Did you bother taking a glance at the airport diagram? I was based at KSNA for a decade. I'm very familiar with the layout. Anytime you have parallel runways, with one fat and the other skinny, this incident will occasionally happen because it's easy to focus on only the skinny runway while confusing it for the larger parallel runway. It's a matter of sight fixation (seeing what you expect to see) Once you've done that, then the even skinnier taxiway becomes the "skinny" runway in the pilot's head. I know that it happens at PBIA, and that pilots are specifically warned about it. I understand your point, but I don't recall anyone ever having landed on that taxiway. The taxiway is quite narrow, I would estimate about 1/3rd the width of the narrow 75' wide runway 20L. Take a look here https://goo.gl/maps/xgXjy2uURJm and you'll see from the surface markings and layout how difficult it is to mistake taxiway Charlie for runway 20L. That's not to say that Ford is blameless, only that he made a typical and well-known pilot screwup. However it's OTT to imply that one incident means a pilot should be grounded. Ford has had his share of mishaps. I know that age has taken its toll on my piloting abilities, and at 74, Ford is likely experiencing a similar decline. If senility-based erosion of one's faculties (in addition to the possibility of arrogance in Ford's case) has impaired one's judgment or cognition, it is irresponsible for any pilot to continue to act as pilot in command. One could look upon Ford's mishaps as Darwin's gentle nudge. When we find our decisions causing disruption of the nominal performance of the NAS, it is an unmistakable sign... The destination denial provides is likely to be the final one IMHO. Sometimes it's difficult to be objective about the things which we are passionate. In our determination to be objective, we must factor in that passion-bias to judgment decisions. |
On Wed, 15 Feb 2017 21:03:57 -0500, Vaughn Simon wrote: On 2/15/2017 12:21 PM, Larry Dighera wrote: Is it time for venerated pilot Harrison Ford to ground himself for less than adequate judgment skills to act as Pilot In Command? The runway is the one with the big "20L" painted on its near-end. This ignominious incident is worse than Senator Inhoff's landing on a taxiway because there was a big X on the runway. Nonsense Larry. Did you bother taking a glance at the airport diagram? I was based at KSNA for a decade. I'm very familiar with the layout. Anytime you have parallel runways, with one fat and the other skinny, this incident will occasionally happen because it's easy to focus on only the skinny runway while confusing it for the larger parallel runway. It's a matter of sight fixation (seeing what you expect to see) Once you've done that, then the even skinnier taxiway becomes the "skinny" runway in the pilot's head. I know that it happens at PBIA, and that pilots are specifically warned about it. I understand your point, but I don't recall anyone ever having landed on that taxiway. The taxiway is quite narrow, I would estimate about 1/3rd the width of the narrow 75' wide runway 20L. Take a look here https://goo.gl/maps/xgXjy2uURJm and you'll see from the surface markings and layout how difficult it is to mistake taxiway Charlie for runway 20L. Really? Try this: http://poitras.org/misc/ksna1.png -- Don Poitras |
snip Mr. Ford is either losing his cognitive abilities, or he lacks due respect for the requirements to operate responsibly, or both. Another possibility; he ****ed up. I suppose you have never in your life done anything that in retrospect you concider stupid due to a momentary lapse in attention, focus or judgment? -- Jim Pennino |
On Fri, 17 Feb 2017 19:57:12 -0000, wrote: Larry Dighera wrote: snip Mr. Ford is either losing his cognitive abilities, or he lacks due respect for the requirements to operate responsibly, or both. Another possibility; he ****ed up. That's beyond a possibility. It's a certainty. Then it is not possible that he is "either losing his cognitive abilities, or he lacks due respect for the requirements to operate responsibly, or both"? The LA Times said Ford may not have been able to see over the nose of the tail-dragger well enough to see the runway. That's a bogus excuse in my opinion. I suppose you have never in your life done anything that in retrospect you concider stupid due to a momentary lapse in attention, focus or judgment? When those type of events began to occur while PIC, I judged it was time to stay out of the left seat. I'm not saying it's easy, but it is something virtually all pilots must face at some point. You'll see ... For most people those type of events begin to occur as soon as mommy and daddy are out of sight. It is when those type of events start occuring on a regular basis that there is a problem. -- Jim Pennino |
On Thursday, February 16, 2017 at 9:48:48 AM UTC-6, Larry Dighera wrote:
On Wed, 15 Feb 2017 21:03:57 -0500, Vaughn Simon wrote: On 2/15/2017 12:21 PM, Larry Dighera wrote: Is it time for venerated pilot Harrison Ford to ground himself for less than adequate judgment skills to act as Pilot In Command? The runway is the one with the big "20L" painted on its near-end. This ignominious incident is worse than Senator Inhoff's landing on a taxiway because there was a big X on the runway. Nonsense Larry. Did you bother taking a glance at the airport diagram? I was based at KSNA for a decade. I'm very familiar with the layout. Anytime you have parallel runways, with one fat and the other skinny, this incident will occasionally happen because it's easy to focus on only the skinny runway while confusing it for the larger parallel runway. It's a matter of sight fixation (seeing what you expect to see) Once you've done that, then the even skinnier taxiway becomes the "skinny" runway in the pilot's head. I know that it happens at PBIA, and that pilots are specifically warned about it. I understand your point, but I don't recall anyone ever having landed on that taxiway. The taxiway is quite narrow, I would estimate about 1/3rd the width of the narrow 75' wide runway 20L. Take a look here https://goo.gl/maps/xgXjy2uURJm and you'll see from the surface markings and layout how difficult it is to mistake taxiway Charlie for runway 20L. That's not to say that Ford is blameless, only that he made a typical and well-known pilot screwup. However it's OTT to imply that one incident means a pilot should be grounded. Ford has had his share of mishaps. I know that age has taken its toll on my piloting abilities, and at 74, Ford is likely experiencing a similar decline. If senility-based erosion of one's faculties (in addition to the possibility of arrogance in Ford's case) has impaired one's judgment or cognition, it is irresponsible for any pilot to continue to act as pilot in command. One could look upon Ford's mishaps as Darwin's gentle nudge. When we find our decisions causing disruption of the nominal performance of the NAS, it is an unmistakable sign... The destination denial provides is likely to be the final one IMHO. Sometimes it's difficult to be objective about the things which we are passionate. In our determination to be objective, we must factor in that passion-bias to judgment decisions. He is working his reign of terror down the SoCal coast. Be on the lookout at Carlsbad's Palomar-McClellan Airport. A stray landing at Camp Pendleton might draw Marine fire ![]() |
Delta Aircraft lands on taxiway in Alanta | Ross | Piloting | 9 | October 23rd 09 05:52 PM |
757 lands on EWR taxiway by mistake | Gary Drescher | Piloting | 45 | November 10th 06 01:59 AM |
I don't care what harrison Ford says | Tony Ryan | Piloting | 17 | March 29th 04 10:21 AM |
Exclusive Harrison Ford Interview | Mergatroide | Owning | 2 | August 5th 03 03:36 AM |
Exclusive Harrison Ford Interview | Mergatroide | General Aviation | 0 | July 29th 03 09:19 PM |
