S-turns on final
Old February 18th 17, 02:24 AM posted to rec.aviation.soaring
kirk.stant
Default S-turns on final
On Friday, February 17, 2017 at 3:45:08 PM UTC-6, Dave Walsh wrote:
At 19:16 17 February 2017, wrote:
Then there is always the Marty Eiler special: Full spoiler, point
the nose
at the ground, go VNE to 5 feet off the deck. Even accounting
for the float
in ground effect, it uses up gobs of altitude.
The Vne approach is an interesting idea that I won't be trying
without 6000 feet of runway available! How do you get rid of
all that speed 5 feet off the ground? It must produce an
incredibly long float?
When I took the glider acro course at Estrella back in the early 90s, one of the "party tricks" was to dive at Vne to the deck on entry to downwind, then fly the whole pattern in ground effect - you had to climb to turn base and final - aiming to be near the approach end of the runway, 10 ft over the desert, at about 60 knots. Then you just cracked the spoilers and landed.. Interesting, to say the least!
It did teach you that once in ground effect, a little speed would take you a LONG WAY.
Helps to have an airport out in the middle of nowhere (then); at my local field there would be too much dodging of houses, water tower, trucks on the interstate, etc..! (although I have tried it in Condor and it still works).
Kirk
66
Old February 18th 17, 10:26 PM posted to rec.aviation.soaring
Dave Walsh
And then there are gliders where side slipping with full air
brakes makes the glide angle better! Apparently.
Old February 19th 17, 12:21 AM posted to rec.aviation.soaring
Bob Whelan[_3_]
Definitely true in my S/N 3 Zuni with full flaps on...
Bob W.
P.S. And a hearty "I second those sentiments!" found in the posts of Dave L.
and Cindy B. earlier in this thread. Always good to have Plans B, C, & D
ready-to-go...and the skills to implement 'em, too.
Old February 19th 17, 12:34 AM posted to rec.aviation.soaring
Jonathan St. Cloud
This thread on s-turns or slipping is all about airman skills that we should all posses or should learn enough to be comfortable with these skills. S-turns may be used in another application unforeseen, same for slips. You never know which skills or experiences you might have to apply to another situation to bring you home save. It is part of being a good airman. Often we fly precise, but that does not teach you the corners of your flight envelope.
Are 'Single 180 Turn From Downwind to Final' and 'Stall-spin on Turnfrom Base to Final' mutually exclusive? son_of_flubber Soaring 122 December 17th 16 11:36 PM
Downwind to final turns Jonathan St. Cloud Soaring 18 June 7th 15 02:19 PM
Final Approach, pt 3 - KFME final.jpg (1/1) Mitchell Holman[_3_] Aviation Photos 0 April 8th 09 12:56 PM
Landing KMBO - Shallow S turns on final Video [email protected] Piloting 2 July 2nd 08 10:50 PM
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
