Why are side sticks unpopular in sailplanes
Old February 19th 17, 12:14 PM posted to rec.aviation.soaring
J. Nieuwenhuize
Default Why are side sticks unpopular in sailplanes
Side sticks seem pretty popular in powered aircraft. Personally like them.
In sailplanes they have the additional advantage of allowing either a smaller cockpit (less drag) or more room. Diana, HP18 and several older designs have them.
Yet, they seem highly unpopular. Why would a well-designed sidesticks not be liked, just because it's different, or are there reasons I'm missing?
Old February 19th 17, 01:08 PM posted to rec.aviation.soaring
Tango Eight
Had a side stick for a decade. Center stick is just better. Having a fuselage big enough to pack a lunch and a sensible landout kit is a good thing, too.
Evan Ludeman / T8
Old February 19th 17, 02:57 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
them.
designs have them.
missing?
Can you expand a bit, please?
I wondered if the short grip-pivot lever might raise stick forces in roll
and/or coarsen aileron control, but I've flown a DG-300, which has a
similarly short grip-pivot distance on the roll axis as well as the same
sliding pitch motion and don't recall that I found the control feel a lot
different from a centre stick.
The only thing I recall that's comment-worthy is that the DG-300's
'automatic trim' system has a more friction in it than the Libelle's
system, but that has nothing to do with side sticks.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 19th 17, 04:02 PM posted to rec.aviation.soaring
Tango Eight
Sure. I think the irreducible issue is simply one of leverage and limited motion options. There's only one way to grip the stick, there's only one way to interact with it.
All of the side stick designs I've seen for direct mechanical actuation of controls require a sliding fore/aft motion for elevator (elbow + shoulder) and a rolling motion of the wrist for aileron. Blending those motions with finesse is just more work (more fatigue) than a conventional gimballed stick. I landed out a couple of times in my side stick glider simply because I got tired and sloppy after 4+ hours and couldn't climb well. Coordination never became unconscious in that ship.
The other things that I don't like about side stick equipped gliders tend to be the *reasons* designers opted for side sticks, not the sticks themselves: supine seating position, lousy forward visibility, tiny instrument pods, cockpits with no extra space for anything.
That said, I have always had a desire to fly (but not own!) a Diana2, just because the thing was so radical.
Evan Ludeman / T8
Old February 19th 17, 05:24 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
Sure...
(Snip...)
"Mercy!" he exclaims about having to landout. I never suffered that particular
fate as a result of my side stick (longest single-flight time 9 hours), but I
concur with the sentiment of that last sentence. Coordinating my Zuni is
another of those things that's "different" about the ship...as was
coordinating my (similarly high-in-roll w. light pitch forces) HP-14 before
it. Not dangerous or difficult, just "not unconscious," as in always on the
fringes of my awareness. But, from my perspective, simultaneously never a
problem, just "different."
FWIW - for readers unfamiliar with the HP-14, HP-18, Zuni designs - Evan's
HP-18 (side stick) and my HP-14 (center stick) are both fully supine designs,
while the (original side-stick-design) Zuni has a "standard semi-reclined"
seating position...with a normally-sized cockpit and instrument pod and view
outside.
I transitioned into my HP-14 with ~200 total hours and put ~200 hours on it
before transitioning into the Zuni. No "German quality" optics on either, the
HP-14 having more distortion thanks to looking though its flat-wrapped forward
canopy section at very shallow in-flight angles. I always found that more of a
"mental nuisance" than I did anything about the fully-reclined seating (*very*
comfortable IMO). Ditto its quite narrow - even for thin, small-framed me -
cockpit with limited sandwich space...though it had eNORmous space atop/after
the spars for water (sucked via tube), multiple O2 tanks, a tent (aerotowed to
a camp once), etc. Of course all visual complaints vanished upon use of
landing flaps (I always used 90-degrees in the HP). So its supine pilot
position may well have been somewhat problematic for old-style,
visually-acquired turnpoints, in contest flying when the HP-14 was designed...
Bob W.
Old February 19th 17, 06:08 PM posted to rec.aviation.soaring
Tango Eight
It's probably worth adding that there were a number of factors that made the HP-18 a lot of work to fly well, among them irreducible play in the stick aileron motion, no aileron differential(!!), small tail volume, no hands off stability at all. It wasn't really my intention to blame the wear out factor on the stick location, but it probably came out that way.
-Evan
Old February 19th 17, 06:44 PM posted to rec.aviation.soaring
ship.
Thanks for the additional detail. Like you I'd like to check out a Diana
2 for comfort and forward visibility and wonder if cricked necks could be
a problem. I entirely understand your point about about panel space.
org |
Old February 19th 17, 03:33 PM posted to rec.aviation.soaring
Dan Marotta
I've never flown one but, if the pitch control is sliding rather than
pivoting, I don't think I'd like it. I learned to fly with my wrist,
not my arm. It just seems to me that it would be more work than
relaxation. Again, I've never flown one.
Dan, 5J
Old February 19th 17, 03:54 PM posted to rec.aviation.soaring
Vaughn Simon[_2_]
Like others here, I've never flown with a side stick. That said, in
gliders I've probably switched hands on the control stick countless
times for more reasons than I could possibly enumerate here. I'm
thinking that would be difficult or impossible with a side stick.
Most airplanes with side sticks have auto pilots to free up the pilot's
hands for other chores, gliders don't.
Vaughn
Old February 19th 17, 04:46 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
designs have them.
Occam suggests one should never overlook the power of "popular/inertial
thinking," but that noted, and based on 2000 hours in a side-stick-equipped
sailplane...
Unmitigated Pros:
- Unrestricted lap space (*I* like it!)
Double-edge swords:
- slider in pitch (not pivoting at base...quite noticeable on first flight;
strictly a conceptual difference thereafter. But given the light
elevator/all-flying-tail forces, part of me has never quit wondering how a
"pivoting implementation" in this ship woulda compared.)
- relatively high roll forces in my ship's implementation, compared to pitch
(and rudder) forces, so definitely "a different feel" from the vast majority
of sailplanes out there; not inherently dangerous, but..."quirky?"
- neutral aileron at "some angle" to the cockpit wall (i.e. not
vertical/"obvious"). After the "controls free?" part of my checklist, aileron
neutralization done by centering the stick between the limits of its lateral
throws, as distinct from centering it vertically as most pilots probably do
"without thinking." Dealing with T.O. crosswinds/gusts is as intuitively
obvious as any center stick implementation with which I'm familiar.
Kinda-sorta related, Dick Johnson noted this particular ship's "neutral stick
position" implementation had possibilities for uncommanded roll inputs under
high/low-G inputs (think rotor turbulence), but I've never found that an
issue. This may be somewhat a function of aileron forces, too...
As for pitch, normal in-flight pitch changes I find most smoothly met by how
much I curl my fingers. Though the stick has "quite a range" of pitch throw,
normal flight uses very little of it...mostly (in my experience) occasionally
on takeoff in very gusty conditions.
I've seen/helped-rig other side-stick-ships (Diamant HBV, HP-18), I don't know
whether they were "sliders" or "pivoters" in pitch, but I imagine any
side-sticker would have the beer-around-the-campfire "pitch/roll funkiness"
available for opinionating.
As a natural right-hander, I've often imagined adapting to a left-side stick
(think many powerplanes) would require far more "mental adaptation" on my part
than did adapting to my Zuni's right-side-stick. Maybe some Airbus-driving
glider pilots will chime in?
FWIW, I transitioned into my side-sticker with 400 total hours and zero
outside checkout advice, and quit thinking about it "being different" within
two or three flights. Over the years for that matter, it's never been much of
conversation starter in BS sessions...though I suppose that option is always
there depending upon one's personality.
Bob W.
Neat Video Shows Two Passenger Jets Landing Side-By-Side at the Same Time Miloch Aviation Photos 0 June 14th 16 04:28 AM
HP310 and hx4705 - side by side, first impression Darryl Ramm Soaring 0 February 22nd 09 02:42 AM
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg [email protected] Aviation Photos 0 April 12th 07 01:28 AM
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 4 January 19th 07 01:19 AM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 04:55 PM
