Why are side sticks unpopular in sailplanes
Old February 19th 17, 09:06 PM posted to rec.aviation.soaring
Del Jensen
Default Why are side sticks unpopular in sailplanes
How does a side stick compare to a parallelogram stick (e.g. Glasflugel)?
Old February 19th 17, 09:22 PM posted to rec.aviation.soaring
Dan Marotta
Again, I've never flown a side stick, though if you think about it, a
simple Cessna with a yoke is flown with the left hand, ala side stick.
The parallelogram stick in the Mosquito feels better than a floor
gimballed center stick. It's very smooth operating and the throw is
small enough that you can fly with wrist motion. Very nice.
Dan, 5J
Old February 19th 17, 10:45 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Glasflugel)?
DG-300 is also a parallelogram stick AFAIK. I've not flown a Glasflugel
Mosquito but I have sat in one I was considering buying and handled the
stick. The Mossy and the DG-300 sticks seemed pretty similar except that
the Mossy's trim worked a lot better. From what others have said, it
sounds as though the side stick is less 'natural' because centralised
ailerons mean the handle sticks out horizontally from the cockpit wall
but in the DG-300/Mossy its vertical like a conventional stick. Both side
and parallelogram sticks require you to rotate your wrist to operate the
ailerons, though with a parallelogram stick that would depend on just how
you hold the stick.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Neat Video Shows Two Passenger Jets Landing Side-By-Side at the Same Time Miloch Aviation Photos 0 June 14th 16 04:28 AM
HP310 and hx4705 - side by side, first impression Darryl Ramm Soaring 0 February 22nd 09 02:42 AM
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg [email protected] Aviation Photos 0 April 12th 07 01:28 AM
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 4 January 19th 07 01:19 AM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 04:55 PM
