Pawnee bladder ground?
Old February 23rd 17, 06:10 PM posted to rec.aviation.soaring
Default Pawnee bladder ground?
Hey all. Removed sight gauge/filler cap assembly from Pawnee to change fuel bladder. It has a (ground?) wire hanging off it, looks like the terminal broke off the other end.
Parts catalog doesn't show this.
Anyone know where that end is supposed to attach? Bolts that hold the assembly on are all thru glass/cork/rubber...doesn't seem like it would serve as a ground there.
Old February 23rd 17, 10:02 PM posted to rec.aviation.soaring
Is it possible it goes to the filler neck to wing structure as a static electricity ground when fueling? Granted, the fuel hose nozzle usually connects to the plane for static discharge.
Old February 24th 17, 01:59 AM posted to rec.aviation.soaring
Mystery solved. Runs from firewall thru fibreglass shell to sight gauge. Lays over top of bladder.
Old February 24th 17, 07:23 PM posted to rec.aviation.soaring
To clarify, it is embedded in the fibreglass. Part of the glass tank so it doesn't show in parts catalog.
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 56 March 24th 14 06:21 AM
Pawnee AD /SB 25/53/03 sugarbush Soaring 1 June 13th 09 12:41 AM
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 4 October 17th 07 01:31 PM
PA-25 PAWNEE Rafgsa Centre Soaring 2 March 3rd 05 03:13 AM
Ground Stops and Ground Delay Programs [email protected] Piloting 1 February 18th 05 01:29 AM
