deleted text,
"As usual most of my words are deleted, new tactic time though, simply lie about what has been written. Denyav has decided to go back to a message I wrote on June 14, bypassing the JN-25 information I posted more recently. I await with interest his retrieval of information I sent in say 1990 as another desperate tactic to avoid actually answering. Denyav wrote in message ... Yes folks, if Denyav can forget about him deleting the text he can simply pretend it did not happen. He started off passing Pearl Harbor the movie as a source of facts and now finds the real facts are coming out, so rewind to those simpler movie days." Again to many words to hide the forest. Translation no ability to reply to basic facts. deleted text, "I expect him to heroically delete my reply and the heroically repeat he is repeating his same junk. Two heroic acts means another self awarded medal." Lets see now, I have mentioned for quite some time the failure to change additive books in December 1941. No,you did not ,because you knew what did it mean Yes folks, Denyav's word is classified by him as Holy writ, no proof is required. Much laughter generated. I am still waiting for proof about what I am supposed to have dated the McCollum memo. I like the way Denyav assumes because he needs to hide the truth the same applies to others. Sigh, I keep telling you the additive book was not changed for the first two months as for why you would have to ask the IJN, presumably an administrative foul up. No you never mentioned this issue before I pressed.Another indicator that you know exactly what to hide. Yes folks, Denyav's word is classified by him as Holy writ, no proof is required. Much laughter generated. In the mean time I am inflated to big boogie man. I prefer get down and boogie man. Now tell us all how this meant the allies gained the complete code book in 2 months. Not just a list of valid code groups. First of all the two month period refers to use of old book by Japanase after introduction of JN25B. The codes in question were the A5 and B5 versions. That is the code book was changed from A to B but the additive (random number) book was left at 5. In August 1945 the USN noted it had 4,907 out of 50,000 additives for the 5 book. Which explains quite well why the main effect of the failure to change additive books did not compromise the code values, but did compromise the fact the basic code system was still in use. If it did compromise the code values then it should have compromised the A version as well, yet the USN reports knowing around 5% of the code values when work stopped around March 1941. On plain English that means the Japanase continued to blunder away JN25 B continuously for two months. In plain English Denyav does not have a clue. Of course US did not completed code recovering within two months,this work continued. In Nov.41 ,US was able to read 90% of JN25B coded messages. (Ditto for Brits and Dutch) Yes folks, Holy Writ time, no proof offered about what they could read. By the way if it was 90% by December 1941 can you explain how this percentage went down by April/May 1942, when the allies were trying to figure out Midway and Coral Sea? Or that the all knowing intelligence system missed the IJN battleships coming out at Midway and the way the IJN carriers came into the Coral Sea? In the latter case it meant the US carriers found themselves with the Japanese airbases in front and the Japanese carriers behind, hence the way the tanker and destroyer supposed to be safely in the rear were sunk first. As of 20 April 1945 the USN found it had 35,761 additives of JN-25B7, the version in use 1 August to 3 December 1941, with the probability several hundred might be bad. So 70% of the additives were thought to be known, this was upped to 47,500 by August 1945, as part of the reworking of the messages. As of 1 December 1941 the USN thought it knew 3,800 code group meanings. Yes folks, the fact the IJN used the old additive book told the allies the basic code system was still in place, 5 digit code groups with valid numbers divisible by 3. There was no need to worry about basic information like say the new valid code groups were now divisible by say 2. Just ignore the new code introduced auxiliary tables, two meanings for the same code group, and stopped having the code groups in alphabetical order. Just pretend the IJN radioed the code book to the allies. So now the lies begin. Firstly the failure to update the random number book enabled the allies to confirm the basic system was still in place. The valid code groups were 5 digit numbers divisible by 3. Secondly the allies did not have all the valid random numbers, additives, used to disguise the valid code groups, thirdly the Japanese did not put out messages containing all 55,000 valid code group meanings in the two months, December 1940 and January 1941. Together with the British the US had 300 values assigned to "B version" code groups by April 1941. If you would like to know the exact code groups recovered it was "Unfinished or Continuous" [i.e., a running tally] April 1, 1941: "approximately 300 values recovered" May 1, 1941: "approximately 400 values recovered" June 1, 1941: "approximately 1100 values recovered" July 1, 1941: "approximately 1100 values recovered" August 1, 1941: "approximately 2000 values recovered" Sept 1, 1941: "approximately 2000 values recovered" Oct 1, 1941: "approximately 2400 values recovered" "Completed during October 1941" Nov 1, 1941: "600 values recovered" [i.e., a total of 3,000 values as of this date] "Completed during November 1941" Dec 1, 1941: "800 values recovered" [i.e., a total of 3,800 values as of this date] "Unfinished or continuous" Jan 1, 1942: "Approximately 6,180 values recovered" Remembering some previously assigned values could be changed by later discoveries. So by the end of December 1941 the allied thought they had around 7% of the code book recovered. BTW you did not even need complete code book to read the most of messages. I am pretty sure that you are also aware what Safford asserted in 1941,but you did and wont mention in any of your messages.Lets refresh your memory: This is wonderful, I am supposed to know all about everything and every document in existence on JN-25. This is not to flatter me of course, but rather to manufacture another sinister hider of the truth. Quick, award new medal for creating a new boogie man. Yes folks, remember JN-25 was in effect a language, and that like all languages most of the talk is in a small subset of the total words available. Just do not mention the unusual words were the things that were used for the messages the conspiracy wants to have decoded in real time. "A large JN25 code as many as 55000 values.But in actual practice, such was the streoteyped nature of the text ,7000 recoveries permitted almost complete decyrption,and many pattern messages could be read practically entire with as few as 1500 meanings" (History of OP-20-GYP1,NSA) We have moved away from using Pearl Harbor the movie as a source and now it seems we have moved onto carefully selected excerpts from US government documents. By the way the assertion above is Captain Safford wrote the words, as opposed to the document being written in around 1944, not by Safford. It also ignores the conclusion of the paper, JN-25 decryption played no part in Pearl Harbor and all the reasons why. You see the problem is the usual one, the really important messages were the non standard ones. By the way in case people are wondering Denyav is wandering the conspiracy theory web sites, yet again Mark Willey's one or conspiracy central, looking for that out of context quote to throw in. Just type a key phrase into a search engine and see which site Denyav is copying, watch the spelling errors though. Stand by for the Martian involvement in the attack if the web site can be found. Oh yes, "nothing to report" is a pattern message. Special orders for unique operations are very non pattern using uncommon code groups. A fundamental problem is knowing the random numbers being used to disguise a given message, it does not matter how common the code groups are if the random numbers are not known. deleted text, rather than telling us where the "world wide" journals from 1931 with how to crack JN-25 can be found. "Translation no proof brought forward, just a wishful thinking. Oh yes, the fact there is said to be a theoretical way to crack a system is supposed to equal the system was cracked, silly isn't it?" The idea the Japanese might improve the system is dismissed. They indeed improved it but they committed one of the most stupit acts of WWII during the process of improvement and they blundered away the improved system. Ah yes the IJN improved the system but just keep up the claim it was the same as US systems from years ago, which come with "how to crack the code in 5 minutes" instructions. imple really, fail to mention Churchill noted what the allies had read they put into the public arena in 1946. Otherwise the conspiracy requires Churchill to be alternatively the truth bringer and telling lies. deleted text, "And remember the IJN had more than 1 code in service, as did the IJA, but just pretend Churchill's first quote has an extra line with JN-25B in it." So Churchill lied on one page and told the truth on another page, (Your truth of Course). Yes folks, I just love the conspiracy claims, they require the truth bringer to be liar and vice versa. You mean Yamamoto's letters to his staff were sent in JN-25B? The couriered messages were in JN-25B? This is really funny. Couriered messages? By the way folks, the IJN should know what it sent by radio and what it couriered, but do not worry, just assume the IJN is totally composed of liars. Ignore the fact the text of the wonder key message comes from post war interrogations. Did you tell Yamamato that JN25 B broken? Yes folks apparently everybody transmits everything by radio unless they are told the code is broken. This joins the claim made one time that the Japanese Post Office would not sent coded IJN messages. It was an attempt to try and wish away the telegraph and courier links to the fleet before it sailed. By the way the Japanese Post Office was willing to send coded messages for non Japanese agencies. They all were radioed messages. Note the Holy Writ no proof statement. By the way folks, the IJN should know what it sent by radio and what it couriered, but do not worry, just assume the IJN is totally composed of liars. Just ignore navies knew it was a good idea to minimise radio traffic, for that matter as did air forces and armies. No need to be told the code might be broken. The German army I think has the slogan all signals traffic is high treason. None of the messages found in the "Pre-Pearl Harbor Japanese Naval Dispatches" file mention Pearl Harbor by name. (This file is found in National Archives at College Park, RG 38, Crane Files, CNSG 5830/115; most of the messages have also have been reprinted in "Pearl Harbor Revisited: United States Navy Communications Intelligence, 1924-1941," an unclassified monograph published by the National Security Agency in 1994.)" deleted text, "The USN went back in 1945/46 and broke out as many of the pre war messages as it could to see what they could have told. One of the favourite tricks is to claim the 1946 dates are faked." Quite correct,but you again forgat to mention WHY the NONE of mentioned Pre-Pearl Harbor messages are available in College Park. Lets refresh your memory again: Does almost three dozen withdrawal notices issued by NSA after the release of "Days of Deceipt" remind you something? Ah yes, Stinnett was in such trouble, he needed to make all sorts of claims about what could be found in the documents, I presume since no proof has been provided of these withdrawal notices we are being treated to another Holy Writ moment. What I really love is the way the claim the documents are being suppressed but Denyav knows what they are, apparently JN-25 intercepts. Who needs research when such psychic powers exist. Hence the Holy Writ moments. Persons who claim that they are not available in College Park,must also tell why they are being withdrawn by NSA. This is good the person who is claiming the documents are not available must now tell us why. Denyav, please tell us why and provide references for the notices. Simple really, fail to mention Churchill noted what the allies had read they put into the public arena in 1946. Otherwise the conspiracy requires Churchill to be alternatively the truth bringer and telling lies. And remember the IJN had more than 1 code in service, as did the IJA, but just pretend Churchill's first quote has an extra line with JN-25B in it. Hard to break JN25B code is an urban legend created in Washington D.C.to cover treason. Translation telling lies about JN-25 is an attempt to cover someone's inability to cope with reality. Yes change the subject time. Try and defend the first Churchill quote and wish away the second. Well, the current custodians of Pearl Harbor conspiracy seemingly are not as honest as Churchill or Stimson,they at least honestly admitted it, or as caring as FDR,he did not inform Honululu about attack and made it happen,but he secretly contacted Red Cross before attack and told them to get prepared for attack,I would call him a really caring President. Yes folks, start off with the idea Churchill would apparently confess to a conspiracy (no one noticed of course until the truth bringers appeared to reinterpret the text). Then find anything the US did to prepare for war as proof of a conspiracy. Imagine that, expecting war, see Stimson, and then doing something stupid like starting to put medical supplies in place. Of course the stockpiles of medical supplies in US west coast ports are presumably proof the Japanese intended to sail onto America after the attack, right? By the way Hawaiian medical resources were being increased in 1940, the Hawaiian Red Cross started war preparations in March 1941. http://hml.org/mmhc/exhibits/ww2hml/ "Chartered as a member of the American Red Cross in 1917, the Hawaii chapter began preparations for war in Hawaii in March 1941. In April, the chapter cooperated with the Major Disaster Council of Honolulu to coordinate the resources of the city with residents, firms, agencies and organizations to meet any major disaster or emergency. The plans of the Red Cross were laid primarily with a view to air attack by Japan, which might be directed against the city as well as military installations. The possibility of bombardment was considered, as well as invasion, and its effect on the civilian population." You see folks, conspiracy land would have the Red Cross must have known, after all there they were preparing for air raids. Note that in March 1941 the IJN attack was still in the is it possible discussion phase between senior leaders. Simple really, look for people preparing for war and announce they must have known what was coming, the specific attacks, not the war as a whole. Drag the Red Cross leadership into the conspiracy claims. "FDR stated that we were likely to be attacked perhaps as soon as next Monday..The question was how should we maneuver them into position of firing the first shot without too much danger to ourselves.In spite of risk involved ,however,in letting Japanase to fire the first shot,we realized that in order to have full support of the American people it was desirable to make sure that the Japanase be the ones to do this so that there should remain no doubt in anyone's mind as to who were the Aggressors" Henry Stimson ,The Secretary of War,Nov.25,1941 Congratulations on a non relevant quote, by the way ever going to tell us why the invasion of the Philippines, Wake and Guam and attacks on US shipping were not enough for first shot honours? By the way the above is apparently proof Stimson is admitting to allowing the Pearl Harbor attack, as opposed to admitting he was not going to allow the US to start shooting first. Remember the isolationists, plus those that opposed FDR? The US was a democracy, people actually differed from the government and were allowed to. Such people were against the government starting a war without congressional approval at least. By the way "Next Monday" for someone writing on 25 November 1941 is 1 December 1941. Amazing how FDR knew the Japanese were going to attack on 30 November 1941, the day after the 29 November deadline the Japanese had set. Oh that's right, throw away all the predictions that were incorrect and only ever mention the ones that were correct, conspiracies need such help. there is lots of deleted text but I will hold off this time. See previous posts if interested. Geoffrey Sinclair Remove the nb for email. |
book was changed from A to B but the additive (random number) book was left at 5. In August 1945 the USN noted it had 4,907 out of 50,000 additives for the 5 book. Which explains quite well why the main effect of the failure to change additive books did not compromise the code values, but did compromise the fact the basic code system was still in use. If it did compromise the code values then it should have compromised the A version as well, yet the USN eports knowing around 5% of the code values when work stopped around March 1941. On plain English that means the Japanase continued to blunder away JN25 B continuously for two months. In plain English Denyav does not have a clue. In Plain English you will continue to deny what really happened in the days prior to Pearl Harbor. Heck even some main actors of Pearl Harbor,like Stimson and Churchill etc admitted it. You are really very good in hiding reality behind too many irrelevant words. What did you say now? US stopped recovering codes in March when only 5% codes were recovered. First of all do you believe to what you say? Everbody knew that US and Japan were moving toward a confrontation in Pasific and and US had a golden opportunity to recover all japanese naval codes,and suddenly US stopped work on code recovering in March only after a couple of months work!!!!. Code recovering did not stop in March,it did not stop on Dec.7 either. According to your data US recovered roughly 5000 codes by March which seems to be correct. But even with 5000 recoveries you can read the most of the messages. "A large code as many as 55000 values ,but in actual practice ,such was streotyped nature of the text,7000 recoveries permitted almost complete decyription,and many pattern messages could be read practicaly entire with as few as 1500 meanings"(History of OP-20-GYP-1,NSA) ou see folks, conspiracy land would have the Red Cross must have known, after all there they were preparing for air raids. Note that in March 1941 the IJN attack was still in the is it possible discussion phase between senior leaders. For a different view please check out: http://www.usni.org/Naval History/Articles/NHborgquist6.htm Yes change the subject time. Try and defend the first Churchill quote and wish away the second. Is quoting from one page and wishing away others a priviledge given only to Gov't employees? I did not know that. the specific attacks, not the war as a whole. Drag the Red Cross leadership into the conspiracy claims. You are very smart really,Red Cross of early 40s had more in common with FEMA of 2001 ,than the Red Cross of 2001. By the way in case people are wondering Denyav is wandering the conspiracy theory web sites, yet again Mark Willey's one or conspiracy central, looking for that out of context quote to throw in. Just type a key phrase into a search engine and see which site Denyav is copying, watch the Thats seems to be big problem for the custodians of Pearl Harbor conspiracy. The public interest in books and websites telling them what their Great Leaders did not and do not tell is skyrocketing specially after 9/11. I think now its pretty safe assume that so called conspiracy theories are now becoming mainstream theories accepted by the most of the people. Congratulations on a non relevant quote, by the way ever going to tell us why the invasion of the Philippines, Wake and Guam and What Stimson said is irrelevant, What Churchill said is irrelevent. What Congressman Dies said is irrelevant. What Joseph Grew said is irrelevant. What Haan said is irrelevant. What US Army Gen.Rhorpe said is irrelevant. What Popov said is irrelevant. What Journalist Leib said is irrelevant. What Capt.Rannefft of Dutch Navy said is irrelevant. Countless others are irrelevant. So whats relevant? Of course the words of Pearl Harbor conspiracy custodians!!. No wonder books,movies and websites telling what the custodians try to hide are experiencing a boom. Simply put,people do not want to hear lies only any longer. Too bad for the custodians. |
http://www.usni.org/Naval History/Articles/NHborgquist6.htm Http://www.usni.org/NavalHistory/Art...borgquist6.htm Sorry for typo |
deleted text,
"As usual most of my words are deleted, new tactic time though, simply lie about what has been written. Denyav has decided to go back to a message I wrote on June 14, bypassing the JN-25 information I posted more recently. I await with interest his retrieval of information I sent in say 1990 as another desperate tactic to avoid actually answering. "I expect him to heroically delete my reply and the heroically repeat he is repeating his same junk. Two heroic acts means another self awarded medal." Denyav wrote in message ... The codes in question were the A5 and B5 versions. That is the code book was changed from A to B but the additive (random number) book was left at 5. In August 1945 the USN noted it had 4,907 out of 50,000 additives for the 5 book. Which explains quite well why the main effect of the failure to change additive books did not compromise the code values, but did compromise the fact the basic code system was still in use. If it did compromise the code values then it should have compromised the A version as well, yet the USN reports knowing around 5% of the code values when work stopped around March 1941. On plain English that means the Japanase continued to blunder away JN25 B continuously for two months. In plain English Denyav does not have a clue. In Plain English you will continue to deny what really happened in the days prior to Pearl Harbor. In plain English Denyav does not have a clue. Yes folks, Denyav's word is classified by him as Holy writ, no proof is required. Much laughter generated. I am still waiting for proof about what I am supposed to have dated the McCollum memo. I like the way Denyav assumes because he needs to hide the truth the same applies to others. Heck even some main actors of Pearl Harbor,like Stimson and Churchill etc admitted it. In plain English Denyav does not have a clue, he needs to pretend what people say. You are really very good in hiding reality behind too many irrelevant words. In plain English Denyav needs to delete the evidence. What did you say now? US stopped recovering codes in March when only 5% codes were recovered. "If it did compromise the code values then it should have compromised the A version as well, yet the USN reports knowing around 5% of the code values when work stopped around March 1941." This is great, this shows Denyav's techniques so well. Firstly changing the random numbers, additives, into code values. The random numbers, additives, are used to disguise the code groups and need to be removed first, no additives no code groups. Secondly ignoring the fact the "5" version of the code stopped being used in January 1941 and the USN stopped working on the A version in around March 1941, since the IJN decided to stop using the A code in December 1940. Just try and pretend I am running some sort of line the USN stopped work at that time. Above all do not even begin to understand that Washington was weeks behind current intercepts because they were mailed in from the Pacific. Thirdly changing the subject. Move away from the fact that if the failure to change additive books compromised the B code it must have compromised the A code, since the US had only 5% of the A code book when work ended on it around March 1941. First of all do you believe to what you say? Denyav is admitting here he does not believe what he posts, and assumes others have the same tactics Everbody knew that US and Japan were moving toward a confrontation in Pasific and and US had a golden opportunity to recover all japanese naval codes,and suddenly US stopped work on code recovering in March only after a couple of months work!!!!. If everybody knew there was going to be a war then diplomacy becomes rather irrelevant. Yes folks, Denyav needs to reply to what he wants to reply to, not to the facts. The US stopped work on the A version about 4 months after the IJN ceased using it, moving to the B version. Code recovering did not stop in March,it did not stop on Dec.7 either. Strange that, but Denyav needs to go off and pretend about what I said. According to your data US recovered roughly 5000 codes by March which seems to be correct. Thanks for a really great laugh, they US recovered around 5,000 random number additives of the 5 additive book, out of 50,000, the additive book that had been in use for months before the A to B codebook change over. This gives an idea of just how little the allies could read in early 1941 since the additives needed to be removed before the code groups could be looked at. But even with 5000 recoveries you can read the most of the messages. Yes folks, now having invented recoveries move to the next leap of logic. "A large code as many as 55000 values ,but in actual practice ,such was streotyped nature of the text,7000 recoveries permitted almost complete decyription,and many pattern messages could be read practicaly entire with as few as 1500 meanings"(History of OP-20-GYP-1,NSA) Trouble is folks, the key messages were not transmitted and were anything but routine messages, even if the above statement is true. Yes folks, Holy Writ time, no proof offered about what they could read. By the way if it was 90% by December 1941 can you explain how this percentage went down by April/May 1942, when the allies were trying to figure out Midway and Coral Sea? Or that the all knowing intelligence system missed the IJN battleships coming out at Midway and the way the IJN carriers came into the Coral Sea? In the latter case it meant the US carriers found themselves with the Japanese airbases in front and the Japanese carriers behind, hence the way the tanker and destroyer supposed to be safely in the rear were sunk first. How about the fact just before midway the allies were intercepting around 60% of IJN traffic and decoding about 20% of the intercepted messages, plus gaining some parts of around 70% of messages. deleted text, "As of 20 April 1945 the USN found it had 35,761 additives of JN-25B7, the version in use 1 August to 3 December 1941, with the probability several hundred might be bad. So 70% of the additives were thought to be known, this was upped to 47,500 by August 1945, as part of the reworking of the messages. As of 1 December 1941 the USN thought it knew 3,800 code group meanings. Yes folks, the fact the IJN used the old additive book told the allies the basic code system was still in place, 5 digit code groups with valid numbers divisible by 3. There was no need to worry about basic information like say the new valid code groups were now divisible by say 2. Just ignore the new code introduced auxiliary tables, two meanings for the same code group, and stopped having the code groups in alphabetical order. Just pretend the IJN radioed the code book to the allies. So now the lies begin. Firstly the failure to update the random number book enabled the allies to confirm the basic system was still in place. The valid code groups were 5 digit numbers divisible by 3. Secondly the allies did not have all the valid random numbers, additives, used to disguise the valid code groups, thirdly the Japanese did not put out messages containing all 55,000 valid code group meanings in the two months, December 1940 and January 1941. If you would like to know the exact code groups recovered it was "Unfinished or Continuous" [i.e., a running tally] April 1, 1941: "approximately 300 values recovered" May 1, 1941: "approximately 400 values recovered" June 1, 1941: "approximately 1100 values recovered" July 1, 1941: "approximately 1100 values recovered" August 1, 1941: "approximately 2000 values recovered" Sept 1, 1941: "approximately 2000 values recovered" Oct 1, 1941: "approximately 2400 values recovered" "Completed during October 1941" Nov 1, 1941: "600 values recovered" [i.e., a total of 3,000 values as of this date] "Completed during November 1941" Dec 1, 1941: "800 values recovered" [i.e., a total of 3,800 values as of this date] "Unfinished or continuous" Jan 1, 1942: "Approximately 6,180 values recovered" Remembering some previously assigned values could be changed by later discoveries. So by the end of December 1941 the allies thought they had around 7% of the code book recovered. ou see folks, conspiracy land would have the Red Cross must have known, after all there they were preparing for air raids. Note that in March 1941 the IJN attack was still in the is it possible discussion phase between senior leaders. For a different view please check out: http://www.usni.org/Naval History/Articles/NHborgquist6.htm Even without the typo, this comes up as page not found for me. Yes change the subject time. Try and defend the first Churchill quote and wish away the second. Is quoting from one page and wishing away others a priviledge given only to Gov't employees? I did not know that. This is very funny, either Denyav is admitting he is a government employee, since he is quoting from one page and wishing away or we have the usual fun stuff. Invent my job, wrongly of course. I should send in a list of pay and conditions requirements. the specific attacks, not the war as a whole. Drag the Red Cross leadership into the conspiracy claims. You are very smart really,Red Cross of early 40s had more in common with FEMA of 2001 ,than the Red Cross of 2001. Yes folks, change the subject, since the Red Cross decided to prepare in case Hawaii was attacked by air they must have been in on the conspiracy right. After all if any arm of the US government does the same the claim is it was part of a conspiracy. By the way in case people are wondering Denyav is wandering the conspiracy theory web sites, yet again Mark Willey's one or conspiracy central, looking for that out of context quote to throw in. Just type a key phrase into a search engine and see which site Denyav is copying, watch the Thats seems to be big problem for the custodians of Pearl Harbor conspiracy. The public interest in books and websites telling them what their Great Leaders did not and do not tell is skyrocketing specially after 9/11. Denyav is proudly announcing he does not have a clue about book sales. I think now its pretty safe assume that so called conspiracy theories are now becoming mainstream theories accepted by the most of the people. Translation Denyav is delusional, as can be seen from this posting. Congratulations on a non relevant quote, by the way ever going to tell us why the invasion of the Philippines, Wake and Guam and What Stimson said is irrelevant, Never mentions Pearl Harbor. What Churchill said is irrelevent. Notes all messages the allies decoded were released just after the war. What Congressman Dies said is irrelevant. Simply put if he had the information why didn't he release it on the floor of Congress. What Joseph Grew said is irrelevant. The IJN had just been given the results of the Taranto raid. If Grew really knew then one of only about 2 or 3 IJN officers talked, since it was still Yamamoto's idea, not a plan. In case people are wondering Denyav is mining the conspiracy site of Mark Willey, the name he dare not utter, presumably he will endorse the claim the US was trying to lose Coral Sea and Midway as well and that the US never gave Pearl Harbor any help cracking JN-25, the unit there had to start from scratch in December 1941. There are more names to be added from the page if Denyav wants to continue this line, you know the world is flat because some people say it is. Willey is like Stinnett, the evidence does not match the claims. What Haan said is irrelevant. I presume this is the Kilsoo Haan that is supposed to be a member of the Sino-Korean People's League. Apparently there was a Korean who is supposed to have seen the plans. We will ignore the problems of a Korean making it in the IJN, think something worse than US race relations in the 1930s. Presumably you should ask the person who is claimed to be given the information, Senator Guy Gillette, who seems to have never put the information out on the floor of the Senate. Of course FDR is apparently told in a private, no notes meeting. What US Army Gen.Rhorpe said is irrelevant. Which Rhorpe? I presume the claimed messages sent by General Thorpe. The problem is quite simple, the Japanese diplomatic system did not know about the attack on Pearl Harbor, rather hard to credit a cracked diplomatic message with having the information. Instead what was intercepted was the "winds message" set up, the open code to be sent if communications were cut telling the Japanese about who the Japanese were about to be at war with. See, Thorpe, Elliott R. East Wind Rain: The Intimate Account of an Intelligence Officer in the Pacific, 1939-1949. Boston: Gambit, 1969. What Popov said is irrelevant. Given he was no where near the place, and the Germans did not attack the target. What Journalist Leib said is irrelevant. Which Leib? The one who is supposed to have been shown a message by Hull? Apparently the one the IJN couriered to Nagumo. No evidence of course. Oh yes, apparently the New York Times on 8 December 1941 is supposed to have published an article claiming the, presumably Pearl Harbor, attack was known about, time and place. Amazing how New York seems to have missed that, similar for the rest of the US, at the time and later during the various post war hearings. What Capt.Rannefft of Dutch Navy said is irrelevant. His diary makes it clear he was not talking about the Pearl Harbor strike despite attempts to claim otherwise, after some enhancements to the text. Countless others are irrelevant. Denyav, Denyav, Denyav, it is marvellous how you can count yourself several dozen times. Now try the IJN and USN people dealing with the strike and the many histories that conclude no conspiracy, plus all the USN and IJN documents showing the same conclusion. So whats relevant? Of course the words of Pearl Harbor conspiracy custodians!!. Actually I have not quoted the conspiracy custodians, that firstly requires a conspiracy to take custody of. Meantime Denyav quotes the conspiracy custodians, the ones who have custody of the conspiracy to lie about the events of 1941, people like Stinnett and Willey. No wonder books,movies and websites telling what the custodians try to hide are experiencing a boom. The boom is the theories exploding in their face, think duck as in Daffy. Simply put,people do not want to hear lies only any longer. Denyav however will continue. Too bad for the custodians. This is because it is really possible to die laughing. Geoffrey Sinclair Remove the nb for email. |
prior to Pearl Harbor. In plain English Denyav does not have a clue. Nice to see you in the forum again,I guess you dont work,oops I meant post,on weekends. In plain English Denyav does not have a clue, he needs to pretend what people say. Of course all those people say is IRRELEVANT for you. Unlike some gov't employees who say what they supposed to say,even if they dont believe to what they say,I, like the majority of people find them utmostly relevant Being a custodian of conspiracies is a tough job nowadays,I guess. In plain English Denyav needs to delete the evidence. Since when detractors are called evidence? Denyav is admitting here he does not believe what he posts, and assumes others have the same tactics Even your pretty skilful use of detractors could not hide the fact,that you said in your last post that in March 41,US stopped recovering (I said no) whereas now you admit that recovery work did not stop in april. I like your detractors and salami tactic. Even without the typo, this comes up as page not found for me. You are right .But I dont know why maybe only for subscribers. Yes folks, change the subject, since the Red Cross decided to prepare in case Hawaii was attacked by air they must have been in on the conspiracy right. After all if any arm of the US government does the same the claim is it was part of a conspiracy. Red Cross of 1941 was more like FEMA of 2001 than Red Cross of 2001,which also means that the parties interested in finding truths about 9/11 must scrunitize FEMA more closely than CIA or FBI. Denyav is proudly announcing he does not have a clue about book sales. Yeah right,even a third rate documentary is breaking records. Translation Denyav is delusional, as can be seen from this posting. Accept the fact the majority on this planet do not believe to US evergreen stories anymore (Ft.Sumter,Maine,Pearl Harbor,9/11),after 150 years you must come up with new story line,not with the copycat versions of the original. Never mentions Pearl Harbor. You are right,he did not even mentioned anything about particulars of attack,he did not mention exact date of attack,the launch position of japanese carriers,torpedo drop altitude selected by japanase carriers etc. You are 100% right his words are totally irrelevant under this circumstances. Notes all messages the allies decoded were released just after the war. That means all messages the allies decoded (during war) were not released during the war,which supports his statement in page 598. Simply put if he had the information why didn't he release it on the floor of Congress. I think he gave the answer to your question,namely FDR and Hull asked him to keep the info secret. Senator Guy Gillette, who seems to have never put the information out on the floor of the Senate. Of course FDR is apparently told in a private, no notes meeting. I wonder if current Senators are putting everything they know out on the Senate floor? Instead what was intercepted was the "winds message" set up, the open code to be sent if communications were cut telling the Japanese about who the Japanese were about to be at war with. It was message to Bangkok,and in this message name of Pearl Harbor appeared along with three others. What Popov said is irrelevant. Given he was no where near the place, and the Germans did not attack the target. Of course irrelevant. Which Leib? The one who is supposed to have been shown a message by Hull? Apparently the one the IJN couriered to Nagumo. No evidence of course. I guess you were the courier who delivered message to Yamamato. Oh yes, apparently the New York Times on 8 December 1941 is supposed to have published an article claiming the, presumably Pearl Harbor, attack was known about, time and place. Amazing how New York seems to have missed that, similar for the rest of the US, at the time and later during the various post As you are proving with every post,if you want to miss or disregard evidences,the sky is the limit. His diary makes it clear he was not talking about the Pearl Harbor strike despite attempts to claim otherwise, after some enhancements to the text. His original diary is available in Dutch archieves (in Dutch of course),if you are interested I can post it here.(in Dutch) Simply put,people do not want to hear lies only any longer. Denyav however will continue. At least I dont get paid for that. |
This took 5 minutes of basic cut and paste of deleted words back into the text.
deleted text, "As usual most of my words are deleted, new tactic time though, simply lie about what has been written. Denyav has decided to go back to a message I wrote on June 14, bypassing the JN-25 information I posted more recently. I await with interest his retrieval of information I sent in say 1990 as another desperate tactic to avoid actually answering. "I expect him to heroically delete my reply and the heroically repeat he is repeating his same junk. Two heroic acts means another self awarded medal." Denyav wrote in message ... In Plain English you will continue to deny what really happened in the days prior to Pearl Harbor. In plain English Denyav does not have a clue. Nice to see you in the forum again,I guess you dont work,oops I meant post,on weekends. This is becoming very funny, ever heard of a weekend away? Ever heard of the idea things can wait a few days? Denyav has decided this is my work it seems, which is great, I will get his address and send him the bill. deleted text, Yes folks, Denyav's word is classified by him as Holy writ, no proof is required. Much laughter generated. I am still waiting for proof about what I am supposed to have dated the McCollum memo. I like the way Denyav assumes because he needs to hide the truth the same applies to others. In plain English Denyav does not have a clue, he needs to pretend what people say. Of course all those people say is IRRELEVANT for you. No what the people are saying does not match what Denyav is saying. Unlike some gov't employees who say what they supposed to say, even if they dont believe to what they say,I, like the majority of people find them utmostly relevant You see folks, Denyav has decided where I work without proof and has to pretend he is a majority. Being a custodian of conspiracies is a tough job nowadays,I guess. Denyav is into self pity. The conspiracy to lie about a conspiracy. In plain English Denyav needs to delete the evidence. Since when detractors are called evidence? As people can see the evidence is deleted. Denyav is admitting here he does not believe what he posts, and assumes others have the same tactics Even your pretty skilful use of detractors could not hide the fact,that you said in your last post that in March 41,US stopped recovering (I said no) whereas now you admit that recovery work did not stop in april. I like your detractors and salami tactic. deleted text, to the next . Strange that, but Denyav needs to go off and pretend about what I said, from a post where I gave the recovered code values totals until the end of 1941, Denyav keeps deleting the totals. "If it did compromise the code values then it should have compromised the A version as well, yet the USN reports knowing around 5% of the code values when work stopped around March 1941. Thanks for a really great laugh, they US recovered around 5,000 random number additives of the 5 additive book, out of 50,000, the additive book that had been in use for months before the A to B codebook change over. This gives an idea of just how little the allies could read in early 1941 since the additives needed to be removed before the code groups could be looked at. This is great, this shows Denyav's techniques so well. Firstly changing the random numbers, additives, into code values. The random numbers, additives, are used to disguise the code groups and need to be removed first, no additives no code groups. Secondly ignoring the fact the "5" version of the code stopped being used in January 1941 and the USN stopped working on the A version in around March 1941, since the IJN decided to stop using the A code in December 1940. Just try and pretend I am running some sort of line the USN stopped work at that time. Above all do not even begin to understand that Washington was weeks behind current intercepts because they were mailed in from the Pacific. Thirdly changing the subject. Move away from the fact that if the failure to change additive books compromised the B code it must have compromised the A code, since the US had only 5% of the A code book when work ended on it around March 1941. Trouble is folks, the key messages were not transmitted and were anything but routine messages, even if the above statement is true. Yes folks, Holy Writ time, no proof offered about what they could read. By the way if it was 90% by December 1941 can you explain how this percentage went down by April/May 1942, when the allies were trying to figure out Midway and Coral Sea? Or that the all knowing intelligence system missed the IJN battleships coming out at Midway and the way the IJN carriers came into the Coral Sea? In the latter case it meant the US carriers found themselves with the Japanese airbases in front and the Japanese carriers behind, hence the way the tanker and destroyer supposed to be safely in the rear were sunk first. How about the fact just before midway the allies were intercepting around 60% of IJN traffic and decoding about 20% of the intercepted messages, plus gaining some parts of around 70% of messages. deleted text, "As of 20 April 1945 the USN found it had 35,761 additives of JN-25B7, the version in use 1 August to 3 December 1941, with the probability several hundred might be bad. So 70% of the additives were thought to be known, this was upped to 47,500 by August 1945, as part of the reworking of the messages. As of 1 December 1941 the USN thought it knew 3,800 code group meanings. Yes folks, the fact the IJN used the old additive book told the allies the basic code system was still in place, 5 digit code groups with valid numbers divisible by 3. There was no need to worry about basic information like say the new valid code groups were now divisible by say 2. Just ignore the new code introduced auxiliary tables, two meanings for the same code group, and stopped having the code groups in alphabetical order. Just pretend the IJN radioed the code book to the allies. So now the lies begin. Firstly the failure to update the random number book enabled the allies to confirm the basic system was still in place. The valid code groups were 5 digit numbers divisible by 3. Secondly the allies did not have all the valid random numbers, additives, used to disguise the valid code groups, thirdly the Japanese did not put out messages containing all 55,000 valid code group meanings in the two months, December 1940 and January 1941. If you would like to know the exact code groups recovered it was "Unfinished or Continuous" [i.e., a running tally] April 1, 1941: "approximately 300 values recovered" May 1, 1941: "approximately 400 values recovered" June 1, 1941: "approximately 1100 values recovered" July 1, 1941: "approximately 1100 values recovered" August 1, 1941: "approximately 2000 values recovered" Sept 1, 1941: "approximately 2000 values recovered" Oct 1, 1941: "approximately 2400 values recovered" "Completed during October 1941" Nov 1, 1941: "600 values recovered" [i.e., a total of 3,000 values as of this date] "Completed during November 1941" Dec 1, 1941: "800 values recovered" [i.e., a total of 3,800 values as of this date] "Unfinished or continuous" Jan 1, 1942: "Approximately 6,180 values recovered" Remembering some previously assigned values could be changed by later discoveries. So by the end of December 1941 the allies thought they had around 7% of the code book recovered. Even without the typo, this comes up as page not found for me. You are right .But I dont know why maybe only for subscribers. Translation Denyav chooses to supply URLs with no evidence. Yes folks, change the subject, since the Red Cross decided to prepare in case Hawaii was attacked by air they must have been in on the conspiracy right. After all if any arm of the US government does the same the claim is it was part of a conspiracy. Red Cross of 1941 was more like FEMA of 2001 than Red Cross of 2001, which also means that the parties interested in finding truths about 9/11 must scrunitize FEMA more closely than CIA or FBI. Yes folks, change the subject, since the Red Cross decided to prepare in case Hawaii was attacked by air they must have been in on the conspiracy right. After all if any arm of the US government does the same the claim is it was part of a conspiracy. Denyav is proudly announcing he does not have a clue about book sales. Yeah right,even a third rate documentary is breaking records. So this documentary is on Pearl Harbor right? Translation Denyav is delusional, as can be seen from this posting. Accept the fact the majority on this planet do not believe to US evergreen stories anymore (Ft.Sumter,Maine,Pearl Harbor,9/11),after 150 years you must come up with new story line,not with the copycat versions of the original. Translation Denyav denies the tide is in, the air is just a little wet. By the way in case people are wondering Denyav is wandering the conspiracy theory web sites, yet again Mark Willey's one or conspiracy central, looking for that out of context quote to throw in. Just type a key phrase into a search engine and see which site Denyav is copying, watch the typos though. Never mentions Pearl Harbor. You are right,he did not even mentioned anything about particulars of attack,he did not mention exact date of attack,the launch position of japanese carriers,torpedo drop altitude selected by japanase carriers etc. You are 100% right his words are totally irrelevant under this circumstances. These are the words that apparently prove what Stimson knew, they have to be deleted, "FDR stated that we were likely to be attacked perhaps as soon as next Monday..The question was how should we maneuver them into position of firing the first shot without too much danger to ourselves. In spite of risk involved, however, in letting Japanase to fire the first shot, we realized that in order to have full support of the American people it was desirable to make sure that the Japanese be the ones to do this so that there should remain no doubt in anyone's mind as to who were the Aggressors" Henry Stimson, The Secretary of War,Nov.25,1941 Notes all messages the allies decoded were released just after the war. That means all messages the allies decoded (during war) were not released during the war,which supports his statement in page 598. Yes folks, remember the conspiracy to cause Pearl Harbor must have happened pre war and that Churchill says all the decoded messages were released. In case people are wondering Denyav is mining the conspiracy site of Mark Willey, the name he dare not utter, presumably he will endorse the claim the US was trying to lose Coral Sea and Midway as well and that the US never gave Pearl Harbor any help cracking JN-25, the unit there had to start from scratch in December 1941. There are more names to be added from the page if Denyav wants to continue this line, you know the world is flat because some people say it is. Willey is like Stinnett, the evidence does not match the claims. Simply put if he had the information why didn't he release it on the floor of Congress. I think he gave the answer to your question,namely FDR and Hull asked him to keep the info secret. Ah yes, so he kept the secret until he died, allowing the system to railroad the commanders etc. etc. Dies was a very anti communist person, the claimed information could be used to discredit much of the democrat administration even post war, but strange to tell the claimed information never surfaces until people are dead. Senator Guy Gillette, who seems to have never put the information out on the floor of the Senate. Of course FDR is apparently told in a private, no notes meeting. I wonder if current Senators are putting everything they know out on the Senate floor? Post war would be easily possible, as part of the investigations even. Instead what was intercepted was the "winds message" set up, the open code to be sent if communications were cut telling the Japanese about who the Japanese were about to be at war with. It was message to Bangkok,and in this message name of Pearl Harbor appeared along with three others. No. Which Rhorpe? I presume the claimed messages sent by General Thorpe. The problem is quite simple, the Japanese diplomatic system did not know about the attack on Pearl Harbor, rather hard to credit a cracked diplomatic message with having the information. Instead what was intercepted was the "winds message" set up, the open code to be sent if communications were cut telling the Japanese about who the Japanese were about to be at war with. See, Thorpe, Elliott R. East Wind Rain: The Intimate Account of an Intelligence Officer in the Pacific, 1939-1949. Boston: Gambit, 1969. What Popov said is irrelevant. Given he was no where near the place, and the Germans did not attack the target. Of course irrelevant. But Denyav will include it, since it was on a web site. Which Leib? The one who is supposed to have been shown a message by Hull? Apparently the one the IJN couriered to Nagumo. No evidence of course. I guess you were the courier who delivered message to Yamamato. No, the IJN officers present told people about the communications. This is the trouble for the conspiracy the IJN keeps shooting it down. Oh yes, Leib waited until after Hull was dead before telling the world of his claims. Does this make Hull a conspirator? If so a stupid one by letting the claimed secret out? Oh yes, apparently the New York Times on 8 December 1941 is supposed to have published an article claiming the, presumably Pearl Harbor, attack was known about, time and place. Amazing how New York seems to have missed that, similar for the rest of the US, at the time and later during the various post As you are proving with every post,if you want to miss or disregard evidences,the sky is the limit. Yes folks, the article does not appear instead we are left to believe no one in New Your noticed it. His diary makes it clear he was not talking about the Pearl Harbor strike despite attempts to claim otherwise, after some enhancements to the text. His original diary is available in Dutch archieves (in Dutch of course),if you are interested I can post it here.(in Dutch) This should be funny, presumably Denyav can read Dutch, including the Captain's shorthand. Actually I have not quoted the conspiracy custodians, that firstly requires a conspiracy to take custody of. Meantime Denyav quotes the conspiracy custodians, the ones who have custody of the conspiracy to lie about the events of 1941, people like Stinnett and Willey Simply put,people do not want to hear lies only any longer. Denyav however will continue. At least I dont get paid for that. Denyav however will continue with the lies. Geoffrey Sinclair Remove the nb for email. |
post,on weekends. This is becoming very funny, ever heard of a weekend away? Ever heard of the idea things can wait a few days? Perfect enjoy it. No what the people are saying does not match what Denyav is saying. Unfortunately what people says,from Churchill to Dulles,from Stimson to Hoover and countless others is IRRELEVANT for you because they do not match what you are telling us. You see folks, Denyav has decided where I work without proof and has to pretend he is a majority. Did I say "You are a gov' t employee"? NO. But your response to that is interesting. Denyav is into self pity. The conspiracy to lie about a conspiracy. Which reminds me your posts. As people can see the evidence is deleted. Detractors sir,nothing but detractors. Strange that, but Denyav needs to go off and pretend about what I said, from a post where I gave the recovered code values totals until the end of 1941, Denyav keeps deleting the totals. Only after claiming that recovery work had been stopped in March after recovery of almost 5000 codes.As you now say recovery work did stop in March. BTW 5000 code recoveries in three months is a good performance and enabled US,as Safford stated enough to read the most of Japanase traffic. Secondly ignoring the fact the "5" version of the code stopped being used in January 1941 and the USN stopped working on the A version in around March 1941, since the IJN decided to stop using the A code Now your correction comes? Move away from the fact that if the failure to change additive books compromised the B code it must have compromised the A code, since the US had only 5% of the A code book when work ended on it around March 1941. Actually work never ended. percentage went down by April/May 1942, when the allies were trying to figure out Midway and Coral Sea? Or that the all knowing intelligence system missed the IJN battleships coming out at Midway and the way the IJN carriers came into the Could you tell me ,surely you know the story,how US only a couple of months after Pearl Harbor were able to read IJN messages in entirety.? Midway is based almost solely on intelligence superiority. Sometimes you are contradicting yourself. April 1, 1941: "approximately 300 values recovered" May 1, 1941: "approximately 400 values recovered" June 1, 1941: "approximately 1100 values recovered" uly 1, 1941: "approximately 1100 values recovered" August 1, 1941: "approximately 2000 values recovered" Sept 1, 1941: "approximately 2000 values recovered" Oct 1, 1941: "approximately 2400 Roughly 10000 values according to Safford more than enough to read the most of the IJN traffic. Translation Denyav chooses to supply URLs with no evidence. I think anybody with subs.to the Proceeding can access to article. been in on the conspiracy right. After all if any arm of the US government does the same the claim is it was part of a conspiracy. So this documentary is on Pearl Harbor right? No,but on a copy cat version of Pearl Harbor. Willey is like Stinnett, the evidence does not match the claims. Of course,only official's claims match evidences,because they are the ones who produce official evidences. Post war would be easily possible, as part of the investigations even. No,dont you know some selected senators always meet behind closed doors. This should be funny, presumably Denyav can read Dutch, including the Captain's shorthan You bet. custody of. Meantime Denyav quotes the conspiracy custodians, the ones who have custody of the conspiracy to lie about the events of 1941, people like Stinnett and Willey I think you are the conspiracy custodian,sir Numbers declining but still exist. |
deleted text,
"As usual most of my words are deleted, new tactic time though, simply lie about what has been written. Denyav has decided to go back to a message I wrote on June 14, bypassing the JN-25 information I posted more recently. I await with interest his retrieval of information I sent in say 1990 as another desperate tactic to avoid actually answering. "I expect him to heroically delete my reply and the heroically repeat he is repeating his same junk. Two heroic acts means another self awarded medal." yes folks, if the theory requires a pink elephant driving a BMW while towing a trailer upon which a giraffe is doing the hula dance Denyav will announce elephants go to slimming clubs, wear lots of pink make up and can drive, while giraffes are native to Hawaii. Denyav wrote in message ... Nice to see you in the forum again,I guess you dont work,oops I meant post,on weekends. This is becoming very funny, ever heard of a weekend away? Ever heard of the idea things can wait a few days? Perfect enjoy it. This should be good, the attempt to imply I am paid to spend so much time laughing will no doubt continue. deleted text, Denyav has decided this is my work it seems, which is great, I will get his address and send him the bill. Yes folks, Denyav's word is classified by him as Holy writ, no proof is required. Much laughter generated. I am still waiting for proof about what I am supposed to have dated the McCollum memo. I like the way Denyav assumes because he needs to hide the truth the same applies to others. No what the people are saying does not match what Denyav is saying. Unfortunately what people says,from Churchill to Dulles,from Stimson to Hoover and countless others is IRRELEVANT for you because they do not match what you are telling us. Translation Denyav needs to pretend he has people agreeing with him even when they do not. Churchill, Stimson and Hoover for a start, Dulles without any attempt to provide the evidence. "countless" is defined as Denyav counting himself multiple time, 1, 2 3, many. You see folks, Denyav has decided where I work without proof and has to pretend he is a majority. Did I say "You are a gov' t employee"? NO. But your response to that is interesting. Translation Denyav will continue to try and smear, using his ideas of insults of course. He has announced he is not paid to push his jokes, which is not surprising, those who know the truth would not pay to push lies and those pushing the lies would not pay for such mediocre efforts. Note now the absurd attempt to try and avoid the fact he has no long range "what does that person do" device. Denyav is into self pity. The conspiracy to lie about a conspiracy. Which reminds me your posts. The last post was while waiting for a haircut, the person next to me wanted to know where the site with all the great jokes were since I was laughing so much. His response when I told him what was going on, without the adjectives, was "conspiracies are for losers". As people can see the evidence is deleted. Detractors sir,nothing but detractors. Yes folks, if the evidence does not fit ignore it. Strange that, but Denyav needs to go off and pretend about what I said, from a post where I gave the recovered code values totals until the end of 1941, Denyav keeps deleting the totals. Only after claiming that recovery work had been stopped in March after recovery of almost 5000 codes. Simply I never said that, another claim without proof. As you now say recovery work did stop in March. Denyav is having trouble coping with the idea the work on the A code stopped after it went out of service while work picked up on the B code. BTW 5000 code recoveries in three months is a good performance and enabled US,as Safford stated enough to read the most of Japanase traffic. By the way folks Denyav is going to keep announcing he has no idea about the code, changing recoveries of random numbers into recovery of the meanings of code groups. The allies knew around 5,000 random numbers from the 5 additive book, which ended use on 31 January 1941. They had 300 B code group meanings assigned by 1 April 1941. Different things. deleted text, on the idea the failure to change additives compromised the B code. "If it did compromise the code values then it should have compromised the A version as well, yet the USN reports knowing around 5% of the code values when work stopped around March 1941. Thanks for a really great laugh, they US recovered around 5,000 random number additives of the 5 additive book, out of 50,000, the additive book that had been in use for months before the A to B codebook change over. This gives an idea of just how little the allies could read in early 1941 since the additives needed to be removed before the code groups could be looked at. This is great, this shows Denyav's techniques so well. Firstly changing the random numbers, additives, into code values. The random numbers, additives, are used to disguise the code groups and need to be removed first, no additives no code groups. Secondly ignoring the fact the "5" version of the code stopped being used in January 1941 and the USN stopped working on the A version in around March 1941, since the IJN decided to stop using the A code deleted text, "in December 1940. Just try and pretend I am running some sort of line the USN stopped work at that time. Above all do not even begin to understand that Washington was weeks behind current intercepts because they were mailed in from the Pacific. Thirdly changing the subject. Move away from the fact that if the failure to change additive books compromised the B code it must have compromised the A code, since the US had only 5% of the A code book when work ended on it around March 1941." Now your correction comes? Yes folks, Denyav cannot cope with reality so pretend the story has changed. Move away from the fact that if the failure to change additive books compromised the B code it must have compromised the A code, since the US had only 5% of the A code book when work ended on it around March 1941. Actually work never ended. So tell us all please what A code values did the US recover in say the second half of 1941? Deleted text, "Yes folks, Holy Writ time, no proof offered about what they could read. By the way if it was 90% by December 1941 can you explain how this" percentage went down by April/May 1942, when the allies were trying to figure out Midway and Coral Sea? Or that the all knowing intelligence system missed the IJN battleships coming out at Midway and the way the IJN carriers came into the Could you tell me, surely you know the story,how US only a couple of months after Pearl Harbor were able to read IJN messages in entirety.? yes folks, Denyav cannot answer how come his claims mean the US could read less in 1942 than in 1941 so it is time to change the subject. The reason the allies could read more in 1942 was quite simple, they had recovered more of the code. I like the idea what was possible in May 1942 is supposed to be less than November 1941 despite 6 months more work. Oh yes the USN went onto trying to read IJN messages immediately on 18 March 1942, it was then they had enough of the code to try this. Midway is based almost solely on intelligence superiority. Sometimes you are contradicting yourself. Yes folks, just announce in effect the US went backwards in code reading ability in 1941 to fit the conspiracy. Deleted text, "How about the fact just before midway the allies were intercepting around 60% of IJN traffic and decoding about 20% of the intercepted messages, plus gaining some parts of around 70% of messages. "As of 20 April 1945 the USN found it had 35,761 additives of JN-25B7, the version in use 1 August to 3 December 1941, with the probability several hundred might be bad. So 70% of the additives were thought to be known, this was upped to 47,500 by August 1945, as part of the reworking of the messages. As of 1 December 1941 the USN thought it knew 3,800 code group meanings. Yes folks, the fact the IJN used the old additive book told the allies the basic code system was still in place, 5 digit code groups with valid numbers divisible by 3. There was no need to worry about basic information like say the new valid code groups were now divisible by say 2. Just ignore the new code introduced auxiliary tables, two meanings for the same code group, and stopped having the code groups in alphabetical order. Just pretend the IJN radioed the code book to the allies. So now the lies begin. Firstly the failure to update the random number book enabled the allies to confirm the basic system was still in place. The valid code groups were 5 digit numbers divisible by 3. Secondly the allies did not have all the valid random numbers, additives, used to disguise the valid code groups, thirdly the Japanese did not put out messages containing all 55,000 valid code group meanings in the two months, December 1940 and January 1941. If you would like to know the exact code groups recovered it was "Unfinished or Continuous" [i.e., a running tally] April 1, 1941: "approximately 300 values recovered" May 1, 1941: "approximately 400 values recovered" June 1, 1941: "approximately 1100 values recovered" uly 1, 1941: "approximately 1100 values recovered" August 1, 1941: "approximately 2000 values recovered" Sept 1, 1941: "approximately 2000 values recovered" Oct 1, 1941: "approximately 2400 Roughly 10000 values according to Safford more than enough to read the most of the IJN traffic. This is good, the allies have 2,400 values but the claim is they needed 10,000. Note by the way how many the allies had in January 1942 below. Denyav will now painfully put 2 and 2 together and come up with a convenient number. See the tracking of the recoveries shows why the allies could actually read JN-25 in 1942 but not 1941. Deleted text, "Completed during October 1941" Nov 1, 1941: "600 values recovered" [i.e., a total of 3,000 values as of this date] "Completed during November 1941" Dec 1, 1941: "800 values recovered" [i.e., a total of 3,800 values as of this date] "Unfinished or continuous" Jan 1, 1942: "Approximately 6,180 values recovered" Remembering some previously assigned values could be changed by later discoveries. So by the end of December 1941 the allies thought they had around 7% of the code book recovered. By the way people will be happy to know the quote assigned to Safford (about the number of code groups needed) was written by someone else, and appears to be related to a situation in 1943 where units were sending very standardised messages. Hard to tell exactly given how badly the quote is transcribed. Translation Denyav chooses to supply URLs with no evidence. I think anybody with subs.to the Proceeding can access to article. So Denyav will continue to avoid presenting the evidence. been in on the conspiracy right. After all if any arm of the US government does the same the claim is it was part of a conspiracy. So this documentary is on Pearl Harbor right? No,but on a copy cat version of Pearl Harbor. When did the IJN attack US territory again after 1942? Where did the new IJN carriers come from? Willey is like Stinnett, the evidence does not match the claims. Of course,only official's claims match evidences,because they are the ones who produce official evidences. Thanks for admitting the conspiracy people do not match the evidence. Post war would be easily possible, as part of the investigations even. No,dont you know some selected senators always meet behind closed doors. Ah a good laugh does wonders for the soul. Apparently Senators and Congressman, some major opponents of FDR, failed to make the evidence public and now this is apparently because they always meet behind closed doors. Presumably never let out onto the floor of the house etc. deleted text, "Ah yes, so he kept the secret until he died, allowing the system to railroad the commanders etc. etc. Dies was a very anti communist person, the claimed information could be used to discredit much of the democrat administration even post war, but strange to tell the claimed information never surfaces until people are dead." This should be funny, presumably Denyav can read Dutch, including the Captain's shorthan You bet. But fails to provide the evidence. custody of. Meantime Denyav quotes the conspiracy custodians, the ones who have custody of the conspiracy to lie about the events of 1941, people like Stinnett and Willey I think you are the conspiracy custodian,sir Numbers declining but still exist. Yes folks, delete the evidence and you can claim anything. rest of the post is deleted text, "Yes folks, change the subject, since the Red Cross decided to prepare in case Hawaii was attacked by air they must have been in on the conspiracy right. After all if any arm of the US government does the same the claim is it was part of a conspiracy. Translation Denyav denies the tide is in, the air is just a little wet. By the way in case people are wondering Denyav is wandering the conspiracy theory web sites, yet again Mark Willey's one or conspiracy central, looking for that out of context quote to throw in. Just type a key phrase into a search engine and see which site Denyav is copying, watch the typos though. Yes folks, remember the conspiracy to cause Pearl Harbor must have happened pre war and that Churchill says all the decoded messages were released. In case people are wondering Denyav is mining the conspiracy site of Mark Willey, the name he dare not utter, presumably he will endorse the claim the US was trying to lose Coral Sea and Midway as well and that the US never gave Pearl Harbor any help cracking JN-25, the unit there had to start from scratch in December 1941. There are more names to be added from the page if Denyav wants to continue this line, you know the world is flat because some people say it is. Willey is like Stinnett, the evidence does not match the claims. Which Rhorpe? I presume the claimed messages sent by General Thorpe. The problem is quite simple, the Japanese diplomatic system did not know about the attack on Pearl Harbor, rather hard to credit a cracked diplomatic message with having the information. Instead what was intercepted was the "winds message" set up, the open code to be sent if communications were cut telling the Japanese about who the Japanese were about to be at war with. See, Thorpe, Elliott R. East Wind Rain: The Intimate Account of an Intelligence Officer in the Pacific, 1939-1949. Boston: Gambit, 1969. No, the IJN officers present told people about the communications. This is the trouble for the conspiracy the IJN keeps shooting it down. Oh yes, Leib waited until after Hull was dead before telling the world of his claims. Does this make Hull a conspirator? If so a stupid one by letting the claimed secret out? (on the claimed New York article of 8 December 1941) Yes folks, the article does not appear instead we are left to believe no one in New Your noticed it. Geoffrey Sinclair Remove the nb for email. |
Videos: Su-37 Superflanker vs F-22 Raptor | Alejandro Magno | Military Aviation | 20 | January 10th 04 05:19 PM |
