Control Reversal in WWII
Old June 25th 04, 01:14 PM
Eunometic
"Darrell" wrote in message news:FAjBc.20218$ey.9317@fed1read06...
The B-47 had neutral aileron control at about 425 knots (as I seem to
remember). Above that speed it rolled in the opposite direction than the
control input. It was because of the flexible wing. Approaching 425 (if
that's the right speed), the roll produced by aileron input reduced to no
roll at all at 425, then it would roll opposite the control input above 425.
It was, as you noted, because, above 425, the aileron served merely as a tab
which ended up twisting the overall wing in the opposite control direction.
The 707 used outer ailerons only at low speed. Roll control was
provided by inner ailerons. At high speed the outer ailerons
shutdown. I though this was to limit response but it may also have
been to reduce aeroelastic twist. Spoilers also seem to be used for
roll control in some aircraft: perhaps their aeroelastic effects are
less troublesome.
B-58 Hustler History: http://members.cox.net/dschmidt1/
"Eunometic" wrote in message
om...
In discusing the characteristics of how the Me 109K should be flown
against the P51 Mustang and P47 the issue of control reversability
came up. Would someone be able to expand on control reversability.
The Me 109 G10 and Me 109 K4 (G14 was a stopgap due to engine delays
in the G10)had a powerfull engine that allowed them to do a speed of
458mph and outclimbe all allied aircraft. However the old crate had
an old wing section that created enormous aileron forces for the
pilot; also becuase the the small Me 109 cockpit a pilot could
generate only 40lbs of joystick force could have generated 60lbs of
force in a P51. As a result only 2-3 degree of airleron deflection
was possible at 400mph the 109 had a roll rate of 45 degrees/second.
A FW190A and even a P47 could have managed nearly 180 degrees in that
time.
The issue of control reversability then came up. If power ailerons
were fited to the Me 109 they would have allowed a greater deflection
but would this have caused control reversability at some point as the
wing twisted and the ailerons acted more like trim tabs?
What causes reversability? Why is a slab elevator sometimes used?
I've also heard of WW2 pilots using trim tabs to pull out of a dive or
get an aircraft rightway up. What were they doing?
The P38 had a smaller turning circle than the Me 109 (presumably at
lower speeds of around 300mph) but its roll rate was even worse than
the 109 and this is how 109s escaped P38s and I note that some late
war P38s received power controls.
Old June 26th 04, 11:13 AM
Cub Driver
Fascinating. (Indeed, this has been a fascinating discussion: thank
you all!)
I well remember the first time I flew in a 707, and how startled I was
to realize that the wings which had sagged below my line of sight
while on the ground were now clearly raised by what seemed to be a
matter of several feet.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! weblog www.vivabush.org
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
Tactical Air Control Party Airmen Help Ground Forces Otis Willie Military Aviation 0 January 22nd 04 02:20 AM
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In Zeno Aerobatics 0 August 2nd 03 07:31 PM
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In zeno Military Aviation 0 July 14th 03 07:31 PM
