Will circular runways ever take off?
Old March 16th 17, 09:16 PM posted to rec.aviation.soaring
Matt Herron Jr.
Default Will circular runways ever take off?
Hmm...interesting idea. first blush thoughts:
headwind changes to a crosswind, changes to a tailwind as you land/take-off?
banked runway means lateral load on the aircraft changes as speed increases, meaning you are slipping or crabbing on the ground?
turning take-off requires higher AOA to produce higher lift in turn? more chance of stall?
Americans don't know haw to drive in a round-about!
the real reason it won't work: drinks slide off the table in 1st class as you taxi to the "threshold".
Old March 16th 17, 09:44 PM posted to rec.aviation.soaring
Bruce Hoult
Smoothly increasing bank on the runway so you can start on flat ground at the start of the takeoff and go up the sides as the speed increases, keeping crab at zero.
Not a lot.
At his suggested size of 3.5 km diameter, total G loading at 250 km/h would be 1.04 G, requiring a 2% higher takeoff speed and a 16 degree banking to be balanced.
At 2 km diameter those figures would be 1.12 G, 6% higher takeoff speed, and 27 degrees of bank.
At a very sporting 1 km diameter the figures would be 1.4 G, 20% higher takeoff speed, and 45 degrees banking.
OK, those all assume a constant 250 km/h, so actually it would be worse than that once you allow for the extra loading of the higher speed.
The suggested 3.5 km diameter is certainly very mild! Just almost impossible to find a site for.
Old March 16th 17, 10:26 PM posted to rec.aviation.soaring
Bruce Hoult
Not a lot.
Updated figures, allowing for increased takeoff speed feeding back into G loading and required bank angle..
Assumed straight runway takeoff speed 70 m/s, 252 km/h, 136 knots, 156.5 mph
3500 m diameter, 257 km/h, 1.044 G, 16.6 deg bank
2000 m diameter, 271 km/h, 1.155 G, 30.0 deg bank
1609 m diameter, 285 km/h, 1.276 G, 38.4 deg bank
1414 m diameter, 300 km/h, 1.414 G, 45.0 deg bank
1155 m diameter, 356 km/h, 2.000 G, 60.0 deg bank
The figures head to infinite speed and G at 1000 m diameter.
When are thermals not circular and do thermal helpers assume thatthey are? son_of_flubber Soaring 65 August 20th 13 11:48 PM
Circular runways for airports? Larry Dighera Piloting 15 December 27th 06 12:24 AM
Circular Aircraft Hangar Jeff Home Built 16 October 8th 05 11:44 PM
dedTUNIA: Gegen kreisrunden Haarausfall - Against circular loss of hair - Contre Alopécie Areata Greasy Rider Naval Aviation 0 June 10th 05 12:51 PM
Circular Runway jsmith Piloting 55 April 11th 04 10:22 AM
