What are your opinions on the Slingsby Skylark 4?
Old April 11th 17, 10:05 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default What are your opinions on the Slingsby Skylark 4?
On Tuesday, April 11, 2017 at 4:50:36 PM UTC-4, wrote:
How did it stack up against the K6e, SHK, etc.?
How are it's flying qualities?
What's your thoughts?
Thanks so much!
-Nick
My main memory is rigging the club 4... Very heavy centre section that must be held close to fuselage in order to connect controls; nervous work. Outer panels light. There is a flight report in Winning on the Wind vol 1 page 31-33; he found it slightly superior to the Ka-6, though larger and heavier.. He liked the handling and comfort for a tall man.
Old April 11th 17, 11:46 PM posted to rec.aviation.soaring
Have flown and assembled all three. Ka6 the easiest to assemble and easiest to fly, probably one of the nicest handling sailplanes ever built. Skylark 4 more involved to assemble, but very nice to fly, docile, and good climber. SHK wings heavy and require technique, but very manageable with a SoloRigger. The SHK will easily outperform the Ka6 and Skylark 4 . The handling is good, but not as docile as the Ka6 or 4. The Skylark 4 is very capable of all badge distances downwind and is enjoyable to fly. If you are considering buying a Skylark 4 , you should call Bruce Beddow who has owned a 4 for over 20 years.
Old April 12th 17, 10:22 AM posted to rec.aviation.soaring
Peter Whitehead
I did 2 diamonds in K6e and Skylark 4 in the UK. 300 triangle in the Skylark, so amazingly comfortable and roomy, a gentleman's machine. Trim in pitch the best,can fly hands off. K6e a disaster in this respect. Skylark 4 ailerons need some work, k6 a delight to fly, much easier for working the thermals, though the Skylark, once centered, allows you to eat your lunch. If you are a big chap I would go for the Skylark, especially if can be left in hangar with tips off. Airbrakes good on both, but skylark's are supreme, the best of any glider I have flown. Pete
Slingsby T.61 MotorFalke R. Wubben Soaring 11 December 10th 17 07:38 PM
For all things Slingsby Jack Russell Soaring 0 January 18th 15 11:20 PM
Gliders at Camphill 2 - Slingsby T-41 Skylark 2C Andrew B Aviation Photos 0 July 1st 09 10:09 AM
Skylark test flight and piloting technique. Roger (K8RI) Piloting 0 May 9th 07 03:05 AM
Slingsby T-21 Nyal Williams Soaring 14 March 1st 07 08:28 AM
