I have a Ventus cT which is pretty similar for rigging. I previously had
a Duo which uses the same Schempp-Hirth system. Firstly, before rigging ensure the water ballast dump lever is set to shut. then unlock your airbrakes. I usually rig the left wing first. The most important thing then, and before rigging the right wing is to ensure that the left wing is properly in position, i.e the gap between the wing and fuselage is small and uniform and most importantly, the fuselage height should be set so when you look at the right side of the fuselage, the left wing stub is exactly in the middle of the hole. If you don't get this right, any S-H glider is a pig to rig. If you set the height correctly, the whole aircraft goes together very easily. Hope this helps. Mike At 06:47 20 April 2017, wrote: I'd appreciate hearing advice on the best visual clues for getting the wings on a Ventus 2c aligned when rigging. |
ASG-32 Mi rigging aid | [email protected] | Soaring | 3 | June 8th 16 04:22 PM |
Wayne Madsen: Additional clues point to U.S. attack on Iran | dontcowerfromthetruth | Naval Aviation | 4 | August 20th 06 01:38 PM |
Ventus C rigging | James Hamilton | Soaring | 8 | July 7th 06 08:30 AM |
Ventus C rigging | James Hamilton | Soaring | 0 | July 6th 06 07:41 PM |
Searching for clues... what can be seen from an F-16??? | Neil Gould | Piloting | 9 | July 7th 05 08:35 PM |
