On Friday, April 21, 2017 at 6:33:29 AM UTC-7, wrote:
April 1, 2017 By Mike Collins The FAA’s Office of the Chief Counsel has issued a legal interpretation that clarifies automatic dependent surveillance-broadcast (ADS-B) requirements for operators of aircraft without electrical systems. The FAA has mandated ADS-B Out equipage after January 1, 2020, for flight in airspace where a transponder is required today. In the regulations requiring the use of altitude-reporting transponders, FAR 91.215(b)(3) and 91.215(b)(5) specify exemptions for “any aircraft which was not originally certificated with an engine-driven electrical system or which has not subsequently been certified with such a system installed, balloon, or glider.” However, FAR 91.225(e)—which provides comparable exemptions to the ADS-B Out requirement—omits the phrase “engine-driven,” which has caused significant confusion among pilots and aircraft owners. “The legal interpretation confirms that the same aircraft excluded from the transponder requirement are excluded from the ADS-B Out equipage requirement,” said Justin Barkowski, AOPA’s director of regulatory affairs. “That means aircraft subsequently equipped with batteries or an electric starter would not be required to equip for ADS-B Out. |
On Friday, April 21, 2017 at 8:38:25 AM UTC-7, jfitch wrote:
On Friday, April 21, 2017 at 6:33:29 AM UTC-7, wrote: April 1, 2017 By Mike Collins The FAA’s Office of the Chief Counsel has issued a legal interpretation that clarifies automatic dependent surveillance-broadcast (ADS-B) requirements for operators of aircraft without electrical systems. The FAA has mandated ADS-B Out equipage after January 1, 2020, for flight in airspace where a transponder is required today. In the regulations requiring the use of altitude-reporting transponders, FAR 91.215(b)(3) and 91.215(b)(5) specify exemptions for “any aircraft which was not originally certificated with an engine-driven electrical system or which has not subsequently been certified with such a system installed, balloon, or glider.” However, FAR 91.225(e)—which provides comparable exemptions to the ADS-B Out requirement—omits the phrase “engine-driven,” which has caused significant confusion among pilots and aircraft owners. “The legal interpretation confirms that the same aircraft excluded from the transponder requirement are excluded from the ADS-B Out equipage requirement,” said Justin Barkowski, AOPA’s director of regulatory affairs. “That means aircraft subsequently equipped with batteries or an electric starter would not be required to equip for ADS-B Out. “The concern was that the exception expanded the types of aircraft required to equip with ADS-B Out beyond those required to equip with a transponder,” Barkowski added. “AOPA has received several inquiries about what types of aircraft fall within this exception, and has been tracking this issue with the FAA for some time now. This is a favorable interpretation.” FAR 91.225(e) allows eligible aircraft not equipped with ADS-B Out to operate within 30 nm of a Class B primary airport—basically, within its Mode C veil—while remaining outside of any Class B or Class C airspace. In addition, eligible aircraft can operate beneath Class B and Class C airspace, although they may not operate above Class B or Class C airspace. Aircraft not certificated with an electrical system, including balloons and gliders, may fly as high as 17,999 feet except above Class B or Class C airspace. Wonder if that has any ramifications for overflying the Reno Class C airspace. I was thinking the exact same thing about Reno...Its a common path back to Truckee, and a big circle to go around. |
On Friday, April 21, 2017 at 11:52:21 AM UTC-5, Matt Herron Jr. wrote:
On Friday, April 21, 2017 at 8:38:25 AM UTC-7, jfitch wrote: On Friday, April 21, 2017 at 6:33:29 AM UTC-7, wrote: April 1, 2017 By Mike Collins The FAA’s Office of the Chief Counsel has issued a legal interpretation that clarifies automatic dependent surveillance-broadcast (ADS-B) requirements for operators of aircraft without electrical systems. The FAA has mandated ADS-B Out equipage after January 1, 2020, for flight in airspace where a transponder is required today. In the regulations requiring the use of altitude-reporting transponders, FAR 91.215(b)(3) and 91.215(b)(5) specify exemptions for “any aircraft which was not originally certificated with an engine-driven electrical system or which has not subsequently been certified with such a system installed, balloon, or glider.” However, FAR 91.225(e)—which provides comparable exemptions to the ADS-B Out requirement—omits the phrase “engine-driven,” which has caused significant confusion among pilots and aircraft owners. “The legal interpretation confirms that the same aircraft excluded from the transponder requirement are excluded from the ADS-B Out equipage requirement,” said Justin Barkowski, AOPA’s director of regulatory affairs. “That means aircraft subsequently equipped with batteries or an electric starter would not be required to equip for ADS-B Out. “The concern was that the exception expanded the types of aircraft required to equip with ADS-B Out beyond those required to equip with a transponder,” Barkowski added. “AOPA has received several inquiries about what types of aircraft fall within this exception, and has been tracking this issue with the FAA for some time now. This is a favorable interpretation.” FAR 91.225(e) allows eligible aircraft not equipped with ADS-B Out to operate within 30 nm of a Class B primary airport—basically, within its Mode C veil—while remaining outside of any Class B or Class C airspace. In addition, eligible aircraft can operate beneath Class B and Class C airspace, although they may not operate above Class B or Class C airspace. Aircraft not certificated with an electrical system, including balloons and gliders, may fly as high as 17,999 feet except above Class B or Class C airspace. Wonder if that has any ramifications for overflying the Reno Class C airspace. I was thinking the exact same thing about Reno...Its a common path back to Truckee, and a big circle to go around. The lawyer needs to read the regs again. Gliders are exempt from the transponder requirement (and ADS-B) above 10,000 feet. That exemption does not apply to the area above Class B/C up to 10,000 though. So, just like today, if you are not transponder or ADS-B equipped, you cannot cross over Class C below 10,000, but non-equipped gliders can cross above 10,000. |
On Friday, April 21, 2017 at 9:56:32 AM UTC-7, Tony wrote:
On Friday, April 21, 2017 at 11:52:21 AM UTC-5, Matt Herron Jr. wrote: On Friday, April 21, 2017 at 8:38:25 AM UTC-7, jfitch wrote: On Friday, April 21, 2017 at 6:33:29 AM UTC-7, wrote: April 1, 2017 By Mike Collins The FAA’s Office of the Chief Counsel has issued a legal interpretation that clarifies automatic dependent surveillance-broadcast (ADS-B) requirements for operators of aircraft without electrical systems. The FAA has mandated ADS-B Out equipage after January 1, 2020, for flight in airspace where a transponder is required today. In the regulations requiring the use of altitude-reporting transponders, FAR 91.215(b)(3) and 91.215(b)(5) specify exemptions for “any aircraft which was not originally certificated with an engine-driven electrical system or which has not subsequently been certified with such a system installed, balloon, or glider.” However, FAR 91.225(e)—which provides comparable exemptions to the ADS-B Out requirement—omits the phrase “engine-driven,” which has caused significant confusion among pilots and aircraft owners. “The legal interpretation confirms that the same aircraft excluded from the transponder requirement are excluded from the ADS-B Out equipage requirement,” said Justin Barkowski, AOPA’s director of regulatory affairs. “That means aircraft subsequently equipped with batteries or an electric starter would not be required to equip for ADS-B Out. “The concern was that the exception expanded the types of aircraft required to equip with ADS-B Out beyond those required to equip with a transponder,” Barkowski added. “AOPA has received several inquiries about what types of aircraft fall within this exception, and has been tracking this issue with the FAA for some time now. This is a favorable interpretation.” FAR 91.225(e) allows eligible aircraft not equipped with ADS-B Out to operate within 30 nm of a Class B primary airport—basically, within its Mode C veil—while remaining outside of any Class B or Class C airspace. In addition, eligible aircraft can operate beneath Class B and Class C airspace, although they may not operate above Class B or Class C airspace. Aircraft not certificated with an electrical system, including balloons and gliders, may fly as high as 17,999 feet except above Class B or Class C airspace. Wonder if that has any ramifications for overflying the Reno Class C airspace. I was thinking the exact same thing about Reno...Its a common path back to Truckee, and a big circle to go around. The lawyer needs to read the regs again. Gliders are exempt from the transponder requirement (and ADS-B) above 10,000 feet. That exemption does not apply to the area above Class B/C up to 10,000 though. So, just like today, if you are not transponder or ADS-B equipped, you cannot cross over Class C below 10,000, but non-equipped gliders can cross above 10,000. That has been our understanding of Reno class C for many years, we overfly it above 10,000. I hope the lawyer is wrong and you are right. |
PowerFlarm for ADSB source? | [email protected] | Soaring | 7 | February 24th 15 05:01 PM |
Stratus / Foreflight ADSB | 6X | Soaring | 5 | December 17th 13 09:34 AM |
ADSB is only the start... | Martin Gregorie[_5_] | Soaring | 0 | October 1st 09 01:27 PM |
Santa and ADSB | Mal | Soaring | 0 | December 15th 06 07:42 PM |
US: TSA RE-INTERPRETATION | Judy Ruprecht | Soaring | 0 | October 22nd 04 05:17 PM |
