SkySight forecast available for SW USA
Old April 22nd 17, 12:31 AM posted to rec.aviation.soaring
Kurt Thams
Default SkySight forecast available for SW USA
On Friday, March 17, 2017 at 7:03:24 PM UTC-7, wrote:
I have had a number of queries offlist about SkySight's coverage - we cover almost all of the US now, barring an area around North Dakota/Minnesota.
Coverage will be extended there too if demand exists.
One of the features from Dr. Jack that I like but is missing from XCSkies is CU Potential.
Does Skysight have that?
I find it useful because just having "yes / no" to cumulus isn't nearly as informative as the likelihood of them.
Old April 22nd 17, 04:31 AM posted to rec.aviation.soaring
JS
Kurt et al:
Skysight has the following regarding cloud potential.
Boundary Layer Cloud Cover
Low Level Cloud Cover (up to FL130)
Mid Level Cloud Cover (FL130 - 330)
High Level Cloud Cover (FL330 up)
Old April 22nd 17, 10:30 AM posted to rec.aviation.soaring
Hi Kurt,
Yes it does, and SkySight calls this "Cu Depth". The concept is identical.
Cheers,
Matthew
Old April 22nd 17, 12:33 PM posted to rec.aviation.soaring
Hi Kurt,
Cheers,
Matthew
I would like to add that the convergence forecast on skysight is very good. Certainly helped in my last flight.
Thanks Matthew.
Best Regards,
Daniel
Dr Jack forecast high too low [email protected] Soaring 6 February 21st 17 06:40 PM
Flying through known or forecast icing John Doe Instrument Flight Rules 76 December 20th 05 08:01 AM
Flying through known or forecast icing John Doe Piloting 67 December 17th 05 01:20 PM
Translate WX Forecast John T Piloting 34 August 5th 05 02:28 PM
Help, Need Wave forecast Kevin R. Anderson Soaring 2 March 1st 04 06:26 PM
