A manual release system will never be suitable to stop the rapid pitch up caused in this situation. It happens too fast for a manual (actually a sensory-brain-muscle-manual) system, however good the manual system on the tug.
Glider CofG winch hooks are not really suitable for aero-towing, are they? Some of these gliders can't be controlled in pitch once the kiting starts. I have seen people leave their shoulder starts loose on areotowing, and that means the pilot can slide backwards - with hand held on the stick, so that moves too - on pitch-up. (Always use tight shoulder straps on launching, please). I have lost two acquaintances, both gliding "greats" in such tug upsets. I would say banning the use of aero-towing using a CofG winch hook would be the safest bet to save lives, until an automatic system is available.I suspect this is something EASA and the FAA would sort very quickly ( the banning bit, not the automatic system). Sensors to measure pitch, rate rate of the tug, and also tug/rope angle and angular rate,suitably processed and actioned automatically could allow immediate release BEFORE the critical situation is reached - if we feel that we must continue to launch by aero-tow using CofG hooks. A rule of nose hooks or "compromise" hooks only, meanwhile, would probably reduce the risk towards zero. |
I have posted what follows on a previous occasion but, given the posts in
this thread, I think it bears repeating. Whilst I was Chief Instructor at Booker Gliding Club, we conducted two series of test on the phenomenon variously referred to as “Kiting”, “Winch Launching behind the Tow-Plane” and “Sling-Shot Accident”, one in 1978 and one in 1982; my memory of them is quite vivid. * Airplanes used were, for the first series, a Beagle Terrier (a side by side, two place, high wing, tail-dragger), fitted with an Ottfur Glider hook for towing (very similar to the Tost hook, dissimilar to the Schweizer hook) with a 160 hp Lycoming engine; for the second series of tests a PA18-180 with a Schweitzer hook was used. Gliders used were a Schleicher Ka 8b and ASK 13. Tow rope initially used was a heavy (4000 lb breaking strain) rope with a thinner rope weak link at the glider end (nominally 900 lb, but a well worn specimen could break at as little as 200 – 300 lbs – laboratory tests, not opinion), the second series of test used the same heavy duty rope with “Mity” links at each end, 1100 lbs at the Tow-Plane end and 900 lbs at the Glider end – these links use metal shear pins, one under load and a second unloaded, which takes over if the first one fails. This eliminates failure due to fatigue and means that the links always fail at close to their nominal load even after some time in service – again laboratory tested, not just subjective opinion. Rope length was around 180 feet in all cases. * I was the Glider Pilot on all tests; Tow-Plane Pilot was Verdun Luck (then my deputy Chief Instructor) for the first series of tests and Brian Spreckley (then Manager of Booker GC) for the second. The object of the tests was to try to reproduce the “Kiting” under controlled circumstances, with a view to developing a Tow-Plane release mechanism that would automatically release the glider if it got dangerously high above the Tow-Plane. All tests were conducted at about 4000 feet agl. * First test: Terrier Tow-Plane and ASK 13 on nose-hook. At about 4000 feet I took the glider progressively higher above the tow-plane, eventually reached about 100 feet above tow-plane (i.e. rope angle more than 45 degrees above horizontal). At about this point, the tow pilot, who had been using progressively more back stick, ran out of back stick and the Tow-Plane began to pitch nose down but not excessively violently. I released at that point. It took a very positive control input on my part to achieve the displacement, we both felt it was something unlikely to occur accidentally, even with an inexperienced glider pilot, and there was plenty of time for either party to release if it did occur. * Second test: Terrier Tow-Plane and ASK 13 on C of G hook. I pitched the glider about 25 – 30 degrees nose up – the weak link broke immediately! Tow pilot reported a sharp jerk, but no significant change to flight path. * Third test: Terrier Tow-Plane, K 8b on C of G hook. I pitched the glider about 25 degrees nose up. The glider continued to pitch up fairly rapidly (as at the start of a winch launch) and substantial forward movement of the stick only slightly slowed the rate of pitch. The glider achieved about 45 degrees nose up, speed increased rapidly from 55 knots to about 75 knots and the glider was pulled back towards level flight (again as at the top of a winch launch). I released at that point. The entire sequence of events occupied a VERY short period of time (subsequently measured as 2 - 3 seconds). The Tow Pilot reported a marked deceleration and start of pitching down which he attempted to contain by moving the stick back; this was followed immediately by a very rapid pitch down accompanied by significant negative “G”. The tow-plane finished up about 70 degrees nose down and took about 400 feet to recover to level flight. We both found the experience alarming, even undertaken deliberately at 4000 feet. Our conclusion was that the combination of the initial pitch down and the upward deflection of the elevator caused the horizontal stabilizer/elevator combination to stall and the abrupt removal of the down-force it provided caused the subsequent very rapid pitch-down and negative “G”. * Our first conclusion was that, in the event of this sequence occurring accidentally as a result of an inadvertent pitch up by the glider pilot, there was effectively no chance that either the glider pilot or tow-pilot would recognise the problem and pull the release in the available time. * Attempts to produce a tow-plane hook that would release automatically were unsuccessful for reasons that became apparent later. * These tests were repeated a few years later with a PA18 – 180 as the tow-plane, Brian Spreckley flying it. The third test described above was repeated and photographed from a chase plane using a 35 mm motor drive camera on automatic (this took a frame every half second – video camcorders of small size were not readily available then). The photo sequence started with the glider in a slightly low normal tow position and starting to pitch up, the second frame has the glider about 30 degrees nose up and about 20 feet higher than previously in the third frame it is about 45 degrees nose up and has gained another 30 feet or so, the tow-plane is already starting to pitch down, in the fourth frame the glider is about 100 feet higher than its original position and the climb is starting to shallow, the tow-plane is about 50 degrees nose down, the final frame shows the tow-plane about 70 degrees nose down and the glider almost back in level flight , almost directly above it (that was about the point that I pulled the release). * Sufficiently alarmed by events, Brian Spreckley had been trying to pull the release in the tow-plane earlier and found that it would not operate until my releasing at the glider end removed the tension from the rope. Subsequent tests on the ground showed that the Schweizer hook fitted to the tow-plane, whilst perfectly satisfactory under normal loads, was jammed solid by the frictional loads when subject to a pull of around 700 lbs with a slight upwards component – not something that a normal pre-flight check would reveal. * We solved that problem on our tow-planes by replacing the bolt that the hook latches onto with a small roller bearing. So far as I know, no one in the UK has tested the Schweizer hook as fitted to a glider, but I would not be surprised if it exhibited the same characteristics at high loads. * The photo sequence also showed that at no time was the glider at an angle greater than 30 degrees above the tow-plane’s centre-line. However, of course once the glider has pitched up, the wings generate considerable extra lift and that extra lift provides extra load on the rope. With a large, heavy glider it is easy to exceed weak link breaking strains and with a lightweight machine the tension can easily rise to 700 lbs or so. With that much load on the rope, quite a small upward angle provides enough of a vertical component to produce the results described. * That of course is the reason that attempts to produce a hook that released if a certain angle was exceeded were unsuccessful. The, quite small, angle between the rope and the fuselage centreline needed to trigger the “Kiting” when the glider is pitched significantly nose-up is not much greater than the amount of out of position commonly experienced in turbulent conditions. We did build an experimental hook and tried it, but, set to an angle that prevented “Kiting” it occasionally dumped an innocent glider in turbulence, and set to an angle that prevented that, it didn’t prevent the “Kiting”. What was needed was a hook that responded to the vertical component of the load, not the angle at which it was applied, and that problem we decided was beyond us (at least in a form robust and fool-proof enough to be attached to the rear end of a tow-plane). * Our conclusions for preventing “Kiting” we * Don’t aerotow gliders, especially lightweight, low wing-loading gliders, on C of G hooks intended for winch launching (I think the JAR 22 requirement for nose hooks to be fitted to new gliders for aerotowing was at least in part a result of these tests). * Don’t use short ropes. The speed at which things happen varies directly with the length of the rope. * Don’t let inexperienced pilots fly at anywhere near aft C of G. * Don’t let inexperienced pilots fly solo in turbulent conditions. * Replace or modify all Schweizer hooks fitted to tow planes. (So far as I know there are none on gliders in the UK, so that question never arose). * We did also modify our PA18’s so that instead of the release cable ending at a floor-mounted lever, it went round a pulley where that lever used to be, and then all the way up the side of the cockpit, anchored at the roof. This meant that grabbing any point on the wire and pulling it in any direction could operate the release; considerably easier than finding a floor mounted lever when being subject to about minus two “G”. We never regarded this modification as being likely to prevent a worst-case scenario, because, as stated earlier, it was the opinion of all involved, that in a real “Kiting” incident, there was no realistic hope that either pilot would respond in time. At 10:06 24 April 2017, Peter Whitehead wrote: A manual release system will never be suitable to stop the rapid pitch up c= aused in this situation. It happens too fast for a manual (actually a senso= ry-brain-muscle-manual) system, however good the manual system on the tug. Glider CofG winch hooks are not really suitable for aero-towing, are they? = Some of these gliders can't be controlled in pitch once the kiting starts. = I have seen people leave their shoulder starts loose on areotowing, and tha= t means the pilot can slide backwards - with hand held on the stick, so tha= t moves too - on pitch-up. (Always use tight shoulder straps on launching, = please).=20 I have lost two acquaintances, both gliding "greats" in such tug upsets. I = would say banning the use of aero-towing using a CofG winch hook would be t= he safest bet to save lives, until an automatic system is available.I suspe= ct this is something EASA and the FAA would sort very quickly ( the banning= bit, not the automatic system). Sensors to measure pitch, rate rate of the= tug, and also tug/rope angle and angular rate,suitably processed and actio= ned automatically could allow immediate release BEFORE the critical situati= on is reached - if we feel that we must continue to launch by aero-tow usin= g CofG hooks.=20 A rule of nose hooks or "compromise" hooks only, meanwhile, would probably = reduce the risk towards zero. |
[quote='Chris Rollings[_2_];944055']I have posted what follows on a previous occasion but, given the posts in
this thread, I think it bears repeating. Chris, Yours was one of the posts I paid the most attention to. I appreciate the approach you took to the problem and agree with your assessments although I think it's somewhat not feasible to eliminate aero tows to CG hook gliders. The vast majority of the high performance models I tow are CG but overall they are also being flown by the best pilots, never had big problem with one of them. Short ropes, of course, bad idea but interestingly the rope on the student who kited low was a new rope and we make them longer to allow for repairs. This was not a problem in this instance. These were largely inexperienced pilots, one student and one older gentleman who had not done an aerotow in quite some time. As I have noted earlier I will reserve the right to not tow someone for whatever reason. Having observed this older gentleman and had I known he hadn't done an aerotow in quite some time I would have insisted on some dual with an instructor. Turbulence.....whlle there was some cross wind and we always have some thermals off the end of the runway it was not excessive, she flew two tows prior to the upset, she was not great but it was acceptable overall. I agree with replacing all Schweizer hooks and this will be accomplished post haste with no argument or I will be gone..... Release handle position....NO Question. These are things which I think should be on the FAA radar and under an AD note. Thank you for your input, it greatly supports my position. Walt |
The Pawnees at Turf Soaring had a 337 mod to invert the Schweizer releases. In theory that would work on a kiting situation, since the pull force would be on the fixed arm so the release arm would be free to move.
But that begs the question of the glider end - if a 1-26 or 2-33 kites, now HIS release is under tension, so HE can't release! A truly poor design, IMO. Probably the best solution is the TOST internal reel with the guillotine - we checked ours on the ground (at rope replacement time) and even with relatively little tension on the rope (compared to a kiting glider), the guillotine (lever right in front of the throttle in the Pawnee) cut the rope like a piece of spaghetti. Actually surprised us how easy it was! And enough to convince us to install the same system on our other Pawnee, replacing the POS Schweizer release. Kirk 66 |
I recently had a discussion with a CAP CFIG from Alaska that stated they actually tested the schewizer release on there tow plane at 45 degree angle up at 4000 pounds the release pressure on the handle was less than 25 lbs. Now I didn't get specifics as to method or condition of release. But it was his belief that it, as mentioned earlier in this thread, was more of a reaction time issue than ability. YRMV.
I have had the pleasure of taking tows behind Walt. He is best in show and a class act. I only have a few hundred tows in our club Pawnees and about 800tt in power and 50 in sailplanes so I'm no expert. What I do know is this: sailplane pilots are usually type-A and do a great job of rationalizing risk factors to themselves and others. Tost hook be damned, Walt- the variability in sailplane pilots at any club/commercial op will be a risk factor no modified release will solve for. It's a question of whether or not you are comfortable blocking out that idea or not. If I recall correctly, your past career is heavily analytical and clinical- I don't think this question is solvable that way.
The older, taller gliders were more problematic with CG hooks because the
hook was well below the actual CG. Some have a tendency to pitch up excessively even on a winch. I've taken aerotows on a CG hook in Pilatus, LS-4, ASW-20 and 27. None harder than a nose hook in a Blanik. The new designs are easier as long as the tow pilot gives you the manufacturer recommended aerotow speed. One towpilot shorted me 10 kts once too many times. I don't take tows from him any more as I got high behind him twice and yanked. The 27 with CG hook is lovely on aerotow, even through rotor. YMMV with water and different CGs. A nose hook is more work as you have to compensate for yaw and pitch couples. My question is which gliders with CG hooks are giving towpilots trouble? Or is it a pilot problem? |
![]() Quote:
I made a comment about the two pilots in question and you are right, there is a wide disparity among pilots relative to skill. A gentleman with obvious physical problems and a 15 year old student who never impressed me while she was dual are exactly the type you have to watch but if we only towed highly experienced pilots no one would get their license to gain that experience. That being said my analysis of the problem tells me that a Schweizer hook is inappropriate when we know the Tost will work under similar circumstances AND that the release handle MUST be immediately available to the tow pilot, not down on the floor or where one must bend and reach and feel for it and it must provide enough mechanical advantage to accomplish the job. Learning that other clubs and facilities have changed to the Tost 30 years ago and that their handles are such that the pilot does not have to do Olympic class gymnastics to grab it concerns me. I realize that we can't pull things out of our asses today and rectify the problem immediately BUT I assure you things will be well underway today to correct my concerns OR I will be starting my second retirement a bit earlier than I had wanted to. Walt |
Good testing and great write-up!
While not intending to excuse the short comings of the Schweizer release as a tow hook, I recall seeing one mounted to a ground launch vehicle via a very robust hinge (something you'd see on a farm field gate). In a kiting incident, the release would rotate upwards keeping it aligned with the tow rope and making release possible. Of course, the final mounting location of the release cable would have to be such that the cable could still exert sufficient pull distance to effect the release. On 4/24/2017 4:39 AM, Chris Rollings wrote: I have posted what follows on a previous occasion but, given the posts in this thread, I think it bears repeating. Whilst I was Chief Instructor at Booker Gliding Club, we conducted two series of test on the phenomenon variously referred to as “Kiting”, “Winch Launching behind the Tow-Plane” and “Sling-Shot Accident”, one in 1978 and one in 1982; my memory of them is quite vivid. Airplanes used were, for the first series, a Beagle Terrier (a side by side, two place, high wing, tail-dragger), fitted with an Ottfur Glider hook for towing (very similar to the Tost hook, dissimilar to the Schweizer hook) with a 160 hp Lycoming engine; for the second series of tests a PA18-180 with a Schweitzer hook was used. Gliders used were a Schleicher Ka 8b and ASK 13. Tow rope initially used was a heavy (4000 lb breaking strain) rope with a thinner rope weak link at the glider end (nominally 900 lb, but a well worn specimen could break at as little as 200 – 300 lbs – laboratory tests, not opinion), the second series of test used the same heavy duty rope with “Mity” links at each end, 1100 lbs at the Tow-Plane end and 900 lbs at the Glider end – these links use metal shear pins, one under load and a second unloaded, which takes over if the first one fails. This eliminates failure due to fatigue and means that the links always fail at close to their nominal load even after some time in service – again laboratory tested, not just subjective opinion. Rope length was around 180 feet in all cases. I was the Glider Pilot on all tests; Tow-Plane Pilot was Verdun Luck (then my deputy Chief Instructor) for the first series of tests and Brian Spreckley (then Manager of Booker GC) for the second. The object of the tests was to try to reproduce the “Kiting” under controlled circumstances, with a view to developing a Tow-Plane release mechanism that would automatically release the glider if it got dangerously high above the Tow-Plane. All tests were conducted at about 4000 feet agl. First test: Terrier Tow-Plane and ASK 13 on nose-hook. At about 4000 feet I took the glider progressively higher above the tow-plane, eventually reached about 100 feet above tow-plane (i.e. rope angle more than 45 degrees above horizontal). At about this point, the tow pilot, who had been using progressively more back stick, ran out of back stick and the Tow-Plane began to pitch nose down but not excessively violently. I released at that point. It took a very positive control input on my part to achieve the displacement, we both felt it was something unlikely to occur accidentally, even with an inexperienced glider pilot, and there was plenty of time for either party to release if it did occur. Second test: Terrier Tow-Plane and ASK 13 on C of G hook. I pitched the glider about 25 – 30 degrees nose up – the weak link broke immediately! Tow pilot reported a sharp jerk, but no significant change to flight path. Third test: Terrier Tow-Plane, K 8b on C of G hook. I pitched the glider about 25 degrees nose up. The glider continued to pitch up fairly rapidly (as at the start of a winch launch) and substantial forward movement of the stick only slightly slowed the rate of pitch. The glider achieved about 45 degrees nose up, speed increased rapidly from 55 knots to about 75 knots and the glider was pulled back towards level flight (again as at the top of a winch launch). I released at that point. The entire sequence of events occupied a VERY short period of time (subsequently measured as 2 - 3 seconds). The Tow Pilot reported a marked deceleration and start of pitching down which he attempted to contain by moving the stick back; this was followed immediately by a very rapid pitch down accompanied by significant negative “G”. The tow-plane finished up about 70 degrees nose down and took about 400 feet to recover to level flight. We both found the experience alarming, even undertaken deliberately at 4000 feet. Our conclusion was that the combination of the initial pitch down and the upward deflection of the elevator caused the horizontal stabilizer/elevator combination to stall and the abrupt removal of the down-force it provided caused the subsequent very rapid pitch-down and negative “G”. Our first conclusion was that, in the event of this sequence occurring accidentally as a result of an inadvertent pitch up by the glider pilot, there was effectively no chance that either the glider pilot or tow-pilot would recognise the problem and pull the release in the available time. Attempts to produce a tow-plane hook that would release automatically were unsuccessful for reasons that became apparent later. These tests were repeated a few years later with a PA18 – 180 as the tow-plane, Brian Spreckley flying it. The third test described above was repeated and photographed from a chase plane using a 35 mm motor drive camera on automatic (this took a frame every half second – video camcorders of small size were not readily available then). The photo sequence started with the glider in a slightly low normal tow position and starting to pitch up, the second frame has the glider about 30 degrees nose up and about 20 feet higher than previously in the third frame it is about 45 degrees nose up and has gained another 30 feet or so, the tow-plane is already starting to pitch down, in the fourth frame the glider is about 100 feet higher than its original position and the climb is starting to shallow, the tow-plane is about 50 degrees nose down, the final frame shows the tow-plane about 70 degrees nose down and the glider almost back in level flight , almost directly above it (that was about the point that I pulled the release). Sufficiently alarmed by events, Brian Spreckley had been trying to pull the release in the tow-plane earlier and found that it would not operate until my releasing at the glider end removed the tension from the rope. Subsequent tests on the ground showed that the Schweizer hook fitted to the tow-plane, whilst perfectly satisfactory under normal loads, was jammed solid by the frictional loads when subject to a pull of around 700 lbs with a slight upwards component – not something that a normal pre-flight check would reveal. We solved that problem on our tow-planes by replacing the bolt that the hook latches onto with a small roller bearing. So far as I know, no one in the UK has tested the Schweizer hook as fitted to a glider, but I would not be surprised if it exhibited the same characteristics at high loads. The photo sequence also showed that at no time was the glider at an angle greater than 30 degrees above the tow-plane’s centre-line. However, of course once the glider has pitched up, the wings generate considerable extra lift and that extra lift provides extra load on the rope. With a large, heavy glider it is easy to exceed weak link breaking strains and with a lightweight machine the tension can easily rise to 700 lbs or so. With that much load on the rope, quite a small upward angle provides enough of a vertical component to produce the results described. That of course is the reason that attempts to produce a hook that released if a certain angle was exceeded were unsuccessful. The, quite small, angle between the rope and the fuselage centreline needed to trigger the “Kiting” when the glider is pitched significantly nose-up is not much greater than the amount of out of position commonly experienced in turbulent conditions. We did build an experimental hook and tried it, but, set to an angle that prevented “Kiting” it occasionally dumped an innocent glider in turbulence, and set to an angle that prevented that, it didn’t prevent the “Kiting”. What was needed was a hook that responded to the vertical component of the load, not the angle at which it was applied, and that problem we decided was beyond us (at least in a form robust and fool-proof enough to be attached to the rear end of a tow-plane). Our conclusions for preventing “Kiting” we Don’t aerotow gliders, especially lightweight, low wing-loading gliders, on C of G hooks intended for winch launching (I think the JAR 22 requirement for nose hooks to be fitted to new gliders for aerotowing was at least in part a result of these tests). Don’t use short ropes. The speed at which things happen varies directly with the length of the rope. Don’t let inexperienced pilots fly at anywhere near aft C of G. Don’t let inexperienced pilots fly solo in turbulent conditions. Replace or modify all Schweizer hooks fitted to tow planes. (So far as I know there are none on gliders in the UK, so that question never arose). We did also modify our PA18’s so that instead of the release cable ending at a floor-mounted lever, it went round a pulley where that lever used to be, and then all the way up the side of the cockpit, anchored at the roof. This meant that grabbing any point on the wire and pulling it in any direction could operate the release; considerably easier than finding a floor mounted lever when being subject to about minus two “G”. We never regarded this modification as being likely to prevent a worst-case scenario, because, as stated earlier, it was the opinion of all involved, that in a real “Kiting” incident, there was no realistic hope that either pilot would respond in time. At 10:06 24 April 2017, Peter Whitehead wrote: A manual release system will never be suitable to stop the rapid pitch up c= aused in this situation. It happens too fast for a manual (actually a senso= ry-brain-muscle-manual) system, however good the manual system on the tug. Glider CofG winch hooks are not really suitable for aero-towing, are they? = Some of these gliders can't be controlled in pitch once the kiting starts. = I have seen people leave their shoulder starts loose on areotowing, and tha= t means the pilot can slide backwards - with hand held on the stick, so tha= t moves too - on pitch-up. (Always use tight shoulder straps on launching, = please).=20 I have lost two acquaintances, both gliding "greats" in such tug upsets. I = would say banning the use of aero-towing using a CofG winch hook would be t= he safest bet to save lives, until an automatic system is available.I suspe= ct this is something EASA and the FAA would sort very quickly ( the banning= bit, not the automatic system). Sensors to measure pitch, rate rate of the= tug, and also tug/rope angle and angular rate,suitably processed and actio= ned automatically could allow immediate release BEFORE the critical situati= on is reached - if we feel that we must continue to launch by aero-tow usin= g CofG hooks.=20 A rule of nose hooks or "compromise" hooks only, meanwhile, would probably = reduce the risk towards zero. -- Dan, 5J |
![]() Quote:
Both of these incidents were with nose releases not CG hooks. I've never really had a problem with a CG glider but I guess it could happen. Both of these incidents were due to extreme carlessness and or inexperience on the part of the glider pilot. My concern is with the inability to release at the critical moment. It will be my purpose to communicate this condition as broadly and relentlessly as possible. No commercial operation or club should be towing with a Schweizer hook or a release not immediately available to the tow pilot. Walt |
Slow Tows and Upsets | 7C | Soaring | 0 | March 4th 14 11:41 PM |
F-35: Second test plane powers up, but first plane stays grounded | Mike[_7_] | Naval Aviation | 1 | October 29th 07 09:40 PM |
the plane! the plane! protect it without photons. | Spike | Home Built | 0 | December 17th 05 03:28 AM |
Plane down - NASCAR team plane crashes... | Chuck | Piloting | 10 | October 28th 04 12:38 AM |
Kit plane boom with Sport Plane rules | Dave | Home Built | 1 | February 4th 04 02:37 PM |
