Tow Plane Upsets......
Old April 24th 17, 11:39 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
Default Tow Plane Upsets......
I have posted what follows on a previous occasion but, given the posts in
this thread, I think it bears repeating.
Whilst I was Chief Instructor at Booker Gliding Club, we conducted two
series of test on the phenomenon variously referred to as “Kiting”,
“Winch Launching behind the Tow-Plane” and “Sling-Shot Accident”,
one in 1978 and one in 1982; my memory of them is quite vivid.
Airplanes used were, for the first series, a Beagle Terrier (a side by
side, two place, high wing, tail-dragger), fitted with an Ottfur Glider
hook for towing (very similar to the Tost hook, dissimilar to the Schweizer
hook) with a 160 hp Lycoming engine; for the second series of tests a
PA18-180 with a Schweitzer hook was used. Gliders used were a Schleicher
Ka 8b and ASK 13. Tow rope initially used was a heavy (4000 lb breaking
strain) rope with a thinner rope weak link at the glider end (nominally 900
lb, but a well worn specimen could break at as little as 200 – 300 lbs
– laboratory tests, not opinion), the second series of test used the same
heavy duty rope with “Mity” links at each end, 1100 lbs at the
Tow-Plane end and 900 lbs at the Glider end – these links use metal shear
pins, one under load and a second unloaded, which takes over if the first
one fails. This eliminates failure due to fatigue and means that the links
always fail at close to their nominal load even after some time in service
– again laboratory tested, not just subjective opinion. Rope length was
around 180 feet in all cases.
I was the Glider Pilot on all tests; Tow-Plane Pilot was Verdun Luck (then
my deputy Chief Instructor) for the first series of tests and Brian
Spreckley (then Manager of Booker GC) for the second. The object of the
tests was to try to reproduce the “Kiting” under controlled
circumstances, with a view to developing a Tow-Plane release mechanism that
would automatically release the glider if it got dangerously high above the
Tow-Plane. All tests were conducted at about 4000 feet agl.
First test: Terrier Tow-Plane and ASK 13 on nose-hook. At about 4000 feet
I took the glider progressively higher above the tow-plane, eventually
reached about 100 feet above tow-plane (i.e. rope angle more than 45
degrees above horizontal). At about this point, the tow pilot, who had
been using progressively more back stick, ran out of back stick and the
Tow-Plane began to pitch nose down but not excessively violently. I
released at that point. It took a very positive control input on my part
to achieve the displacement, we both felt it was something unlikely to
occur accidentally, even with an inexperienced glider pilot, and there was
plenty of time for either party to release if it did occur.
Second test: Terrier Tow-Plane and ASK 13 on C of G hook. I pitched the
glider about 25 – 30 degrees nose up – the weak link broke immediately!
Tow pilot reported a sharp jerk, but no significant change to flight
path.
Third test: Terrier Tow-Plane, K 8b on C of G hook. I pitched the glider
about 25 degrees nose up. The glider continued to pitch up fairly rapidly
(as at the start of a winch launch) and substantial forward movement of the
stick only slightly slowed the rate of pitch. The glider achieved about 45
degrees nose up, speed increased rapidly from 55 knots to about 75 knots
and the glider was pulled back towards level flight (again as at the top of
a winch launch). I released at that point. The entire sequence of events
occupied a VERY short period of time (subsequently measured as 2 - 3
seconds). The Tow Pilot reported a marked deceleration and start of
pitching down which he attempted to contain by moving the stick back; this
was followed immediately by a very rapid pitch down accompanied by
significant negative “G”. The tow-plane finished up about 70 degrees
nose down and took about 400 feet to recover to level flight. We both
found the experience alarming, even undertaken deliberately at 4000 feet.
Our conclusion was that the combination of the initial pitch down and the
upward deflection of the elevator caused the horizontal stabilizer/elevator
combination to stall and the abrupt removal of the down-force it provided
caused the subsequent very rapid pitch-down and negative “G”.
Our first conclusion was that, in the event of this sequence occurring
accidentally as a result of an inadvertent pitch up by the glider pilot,
there was effectively no chance that either the glider pilot or tow-pilot
would recognise the problem and pull the release in the available time.
Attempts to produce a tow-plane hook that would release automatically were
unsuccessful for reasons that became apparent later.
These tests were repeated a few years later with a PA18 – 180 as the
tow-plane, Brian Spreckley flying it. The third test described above was
repeated and photographed from a chase plane using a 35 mm motor drive
camera on automatic (this took a frame every half second – video
camcorders of small size were not readily available then). The photo
sequence started with the glider in a slightly low normal tow position and
starting to pitch up, the second frame has the glider about 30 degrees nose
up and about 20 feet higher than previously in the third frame it is about
45 degrees nose up and has gained another 30 feet or so, the tow-plane is
already starting to pitch down, in the fourth frame the glider is about 100
feet higher than its original position and the climb is starting to
shallow, the tow-plane is about 50 degrees nose down, the final frame shows
the tow-plane about 70 degrees nose down and the glider almost back in
level flight , almost directly above it (that was about the point that I
pulled the release).
Sufficiently alarmed by events, Brian Spreckley had been trying to pull the
release in the tow-plane earlier and found that it would not operate until
my releasing at the glider end removed the tension from the rope.
Subsequent tests on the ground showed that the Schweizer hook fitted to the
tow-plane, whilst perfectly satisfactory under normal loads, was jammed
solid by the frictional loads when subject to a pull of around 700 lbs with
a slight upwards component – not something that a normal pre-flight check
would reveal.
We solved that problem on our tow-planes by replacing the bolt that the
hook latches onto with a small roller bearing. So far as I know, no one in
the UK has tested the Schweizer hook as fitted to a glider, but I would not
be surprised if it exhibited the same characteristics at high loads.
The photo sequence also showed that at no time was the glider at an angle
greater than 30 degrees above the tow-plane’s centre-line. However, of
course once the glider has pitched up, the wings generate considerable
extra lift and that extra lift provides extra load on the rope. With a
large, heavy glider it is easy to exceed weak link breaking strains and
with a lightweight machine the tension can easily rise to 700 lbs or so.
With that much load on the rope, quite a small upward angle provides enough
of a vertical component to produce the results described.
That of course is the reason that attempts to produce a hook that released
if a certain angle was exceeded were unsuccessful. The, quite small, angle
between the rope and the fuselage centreline needed to trigger the
“Kiting” when the glider is pitched significantly nose-up is not much
greater than the amount of out of position commonly experienced in
turbulent conditions. We did build an experimental hook and tried it, but,
set to an angle that prevented “Kiting” it occasionally dumped an
innocent glider in turbulence, and set to an angle that prevented that, it
didn’t prevent the “Kiting”. What was needed was a hook that
responded to the vertical component of the load, not the angle at which it
was applied, and that problem we decided was beyond us (at least in a form
robust and fool-proof enough to be attached to the rear end of a
tow-plane).
Our conclusions for preventing “Kiting” we
Don’t aerotow gliders, especially lightweight, low wing-loading gliders,
on C of G hooks intended for winch launching (I think the JAR 22
requirement for nose hooks to be fitted to new gliders for aerotowing was
at least in part a result of these tests).
Don’t use short ropes. The speed at which things happen varies directly
with the length of the rope.
Don’t let inexperienced pilots fly at anywhere near aft C of G.
Don’t let inexperienced pilots fly solo in turbulent conditions.
Replace or modify all Schweizer hooks fitted to tow planes. (So far as I
know there are none on gliders in the UK, so that question never arose).
We did also modify our PA18’s so that instead of the release cable ending
at a floor-mounted lever, it went round a pulley where that lever used to
be, and then all the way up the side of the cockpit, anchored at the roof.
This meant that grabbing any point on the wire and pulling it in any
direction could operate the release; considerably easier than finding a
floor mounted lever when being subject to about minus two “G”. We
never regarded this modification as being likely to prevent a worst-case
scenario, because, as stated earlier, it was the opinion of all involved,
that in a real “Kiting” incident, there was no realistic hope that
either pilot would respond in time.
At 10:06 24 April 2017, Peter Whitehead wrote:
A manual release system will never be suitable to stop the rapid pitch up
c=
aused in this situation. It happens too fast for a manual (actually a
senso=
ry-brain-muscle-manual) system, however good the manual system on the
tug.
Glider CofG winch hooks are not really suitable for aero-towing, are
they?
Some of these gliders can't be controlled in pitch once the kiting
starts.
I have seen people leave their shoulder starts loose on areotowing, and
tha=
t means the pilot can slide backwards - with hand held on the stick, so
tha=
t moves too - on pitch-up. (Always use tight shoulder straps on
launching,
please).=20
I have lost two acquaintances, both gliding "greats" in such tug upsets.
I
would say banning the use of aero-towing using a CofG winch hook would be
t=
he safest bet to save lives, until an automatic system is available.I
suspe=
ct this is something EASA and the FAA would sort very quickly ( the
banning=
bit, not the automatic system). Sensors to measure pitch, rate rate of
the=
tug, and also tug/rope angle and angular rate,suitably processed and
actio=
ned automatically could allow immediate release BEFORE the critical
situati=
on is reached - if we feel that we must continue to launch by aero-tow
usin=
g CofG hooks.=20
A rule of nose hooks or "compromise" hooks only, meanwhile, would
probably
reduce the risk towards zero.
Old April 24th 17, 04:55 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
[quote='Chris Rollings[_2_];944055']I have posted what follows on a previous occasion but, given the posts in
Chris,
Yours was one of the posts I paid the most attention to. I appreciate the approach you took to the problem and agree with your assessments although I think it's somewhat not feasible to eliminate aero tows to CG hook gliders. The vast majority of the high performance models I tow are CG but overall they are also being flown by the best pilots, never had big problem with one of them.
Short ropes, of course, bad idea but interestingly the rope on the student who kited low was a new rope and we make them longer to allow for repairs. This was not a problem in this instance.
These were largely inexperienced pilots, one student and one older gentleman who had not done an aerotow in quite some time. As I have noted earlier I will reserve the right to not tow someone for whatever reason. Having observed this older gentleman and had I known he hadn't done an aerotow in quite some time I would have insisted on some dual with an instructor.
Turbulence.....whlle there was some cross wind and we always have some thermals off the end of the runway it was not excessive, she flew two tows prior to the upset, she was not great but it was acceptable overall.
I agree with replacing all Schweizer hooks and this will be accomplished post haste with no argument or I will be gone.....
Release handle position....NO Question. These are things which I think should be on the FAA radar and under an AD note.
Thank you for your input, it greatly supports my position.
Walt
Old April 24th 17, 09:39 PM posted to rec.aviation.soaring
kirk.stant
The Pawnees at Turf Soaring had a 337 mod to invert the Schweizer releases. In theory that would work on a kiting situation, since the pull force would be on the fixed arm so the release arm would be free to move.
But that begs the question of the glider end - if a 1-26 or 2-33 kites, now HIS release is under tension, so HE can't release! A truly poor design, IMO.
Probably the best solution is the TOST internal reel with the guillotine - we checked ours on the ground (at rope replacement time) and even with relatively little tension on the rope (compared to a kiting glider), the guillotine (lever right in front of the throttle in the Pawnee) cut the rope like a piece of spaghetti. Actually surprised us how easy it was! And enough to convince us to install the same system on our other Pawnee, replacing the POS Schweizer release.
Kirk
66
Old April 25th 17, 01:03 AM posted to rec.aviation.soaring
I recently had a discussion with a CAP CFIG from Alaska that stated they actually tested the schewizer release on there tow plane at 45 degree angle up at 4000 pounds the release pressure on the handle was less than 25 lbs. Now I didn't get specifics as to method or condition of release. But it was his belief that it, as mentioned earlier in this thread, was more of a reaction time issue than ability. YRMV.
Old April 25th 17, 02:51 AM posted to rec.aviation.soaring
I have had the pleasure of taking tows behind Walt. He is best in show and a class act. I only have a few hundred tows in our club Pawnees and about 800tt in power and 50 in sailplanes so I'm no expert. What I do know is this: sailplane pilots are usually type-A and do a great job of rationalizing risk factors to themselves and others. Tost hook be damned, Walt- the variability in sailplane pilots at any club/commercial op will be a risk factor no modified release will solve for. It's a question of whether or not you are comfortable blocking out that idea or not. If I recall correctly, your past career is heavily analytical and clinical- I don't think this question is solvable that way.
Old April 25th 17, 04:57 AM posted to rec.aviation.soaring
George Haeh
The older, taller gliders were more problematic with CG hooks because the
hook was well below the actual CG. Some have a tendency to pitch up
excessively even on a winch.
I've taken aerotows on a CG hook in Pilatus, LS-4, ASW-20 and 27. None
harder than a nose hook in a Blanik.
The new designs are easier as long as the tow pilot gives you the
manufacturer recommended aerotow speed. One towpilot shorted me 10 kts
once too many times. I don't take tows from him any more as I got high
behind him twice and yanked.
The 27 with CG hook is lovely on aerotow, even through rotor. YMMV with
water and different CGs.
A nose hook is more work as you have to compensate for yaw and pitch
couples.
My question is which gliders with CG hooks are giving towpilots trouble?
Or is it a pilot problem?
Old April 25th 17, 12:40 PM
Senior Member
couples.
George, this was initially a pilot problem. A 15 year old student on her 3rd solo pattern tow and an older guy with obvious physical problems who had not taken an aero tow in a year or more are not the safest people to tow. That being said the next problem as previously stated is the Schweizer hook. It is well documented that under extreme pressure pulling the handle requires a herculean effort which I understand the a Tost conversion will correct. Then there is the question of the size and position of the release handle. It should be easily accessable and provide the necessary mechanical advantage. Someone mentioned reaction time. In one case I could see the belly of the glider in the mirror and I knew things were about to go bad but even if my hand was on the release at the time, by the time I knew I HAD to do it it would have been too late. It happened in the wink of an eye. The second time I could not see the glider as the student was out to the right and there is no mirror on the right side of the tow plane. There is ''NO ONE SIMPLE FIX."
Walt
Old April 25th 17, 12:18 PM
Senior Member
Quote:
Rick,
I made a comment about the two pilots in question and you are right, there is a wide disparity among pilots relative to skill. A gentleman with obvious physical problems and a 15 year old student who never impressed me while she was dual are exactly the type you have to watch but if we only towed highly experienced pilots no one would get their license to gain that experience. That being said my analysis of the problem tells me that a Schweizer hook is inappropriate when we know the Tost will work under similar circumstances AND that the release handle MUST be immediately available to the tow pilot, not down on the floor or where one must bend and reach and feel for it and it must provide enough mechanical advantage to accomplish the job.
Learning that other clubs and facilities have changed to the Tost 30 years ago and that their handles are such that the pilot does not have to do Olympic class gymnastics to grab it concerns me. I realize that we can't pull things out of our asses today and rectify the problem immediately BUT I assure you things will be well underway today to correct my concerns OR I will be starting my second retirement a bit earlier than I had wanted to.
Walt
Old April 24th 17, 04:53 PM posted to rec.aviation.soaring
Dan Marotta
Good testing and great write-up!
While not intending to excuse the short comings of the Schweizer release
as a tow hook, I recall seeing one mounted to a ground launch vehicle
via a very robust hinge (something you'd see on a farm field gate). In
a kiting incident, the release would rotate upwards keeping it aligned
with the tow rope and making release possible. Of course, the final
mounting location of the release cable would have to be such that the
cable could still exert sufficient pull distance to effect the release.
path.
would reveal.
tow-plane).
c=
senso=
tug.
they?
starts.
tha=
tha=
launching,
please).=20
I
t=
suspe=
banning=
the=
actio=
situati=
usin=
g CofG hooks.=20
probably
Dan, 5J
Slow Tows and Upsets 7C Soaring 0 March 4th 14 11:41 PM
F-35: Second test plane powers up, but first plane stays grounded Mike[_7_] Naval Aviation 1 October 29th 07 09:40 PM
the plane! the plane! protect it without photons. Spike Home Built 0 December 17th 05 03:28 AM
Plane down - NASCAR team plane crashes... Chuck Piloting 10 October 28th 04 12:38 AM
Kit plane boom with Sport Plane rules Dave Home Built 1 February 4th 04 02:37 PM
