I recently had a discussion with a CAP CFIG from Alaska that stated they actually tested the schewizer release on there tow plane at 45 degree angle up at 4000 pounds the release pressure on the handle was less than 25 lbs. Now I didn't get specifics as to method or condition of release. But it was his belief that it, as mentioned earlier in this thread, was more of a reaction time issue than ability. YRMV.
I have had the pleasure of taking tows behind Walt. He is best in show and a class act. I only have a few hundred tows in our club Pawnees and about 800tt in power and 50 in sailplanes so I'm no expert. What I do know is this: sailplane pilots are usually type-A and do a great job of rationalizing risk factors to themselves and others. Tost hook be damned, Walt- the variability in sailplane pilots at any club/commercial op will be a risk factor no modified release will solve for. It's a question of whether or not you are comfortable blocking out that idea or not. If I recall correctly, your past career is heavily analytical and clinical- I don't think this question is solvable that way.
The older, taller gliders were more problematic with CG hooks because the
hook was well below the actual CG. Some have a tendency to pitch up excessively even on a winch. I've taken aerotows on a CG hook in Pilatus, LS-4, ASW-20 and 27. None harder than a nose hook in a Blanik. The new designs are easier as long as the tow pilot gives you the manufacturer recommended aerotow speed. One towpilot shorted me 10 kts once too many times. I don't take tows from him any more as I got high behind him twice and yanked. The 27 with CG hook is lovely on aerotow, even through rotor. YMMV with water and different CGs. A nose hook is more work as you have to compensate for yaw and pitch couples. My question is which gliders with CG hooks are giving towpilots trouble? Or is it a pilot problem? |
![]() Quote:
Walt |
![]() On 4/25/2017 5:18 AM, Walt Connelly wrote: snip .... AND that the release handle MUST be immediately available to the tow pilot, not down on the floor or where one must bend and reach and feel for it and it must provide enough mechanical advantage to accomplish the job. /snip It's been over a year but, IIRC, the release levers on the three tugs at Sundance Aviation (Moriarty) are hinged at the floor with an approximately 3-foot lever at about the same height as the throttle. Easy to grab without looking and LOTS of mechanical advantage. Not commenting at this time about the relative merits or each type of release. |
![]() Quote:
Were these 3 foot handles the original design approved by the FAA or were they conversions later? I understand that it is not permissible to simply fabricate a longer handle and have it installed. Walt |
Walt, I can't answer that.
When I started towing at Sundance, both the CallAir and the Pawnee had long handles. When the Ag Wagon came, it did, too. As I said, it's been over a year since I looked into any of those cockpits, so I may not be remembering correctly. I'll try to remember to take a look next time I go to the airport. Dan On 4/27/2017 5:34 AM, Walt Connelly wrote: Dan Marotta;944164 Wrote: On 4/25/2017 5:18 AM, Walt Connelly wrote: snip .... AND that the release handle MUST be immediately available to the tow pilot, not down on the floor or where one must bend and reach and feel for it and it must provide enough mechanical advantage to accomplish the job. /snip It's been over a year but, IIRC, the release levers on the three tugs at Sundance Aviation (Moriarty) are hinged at the floor with an approximately 3-foot lever at about the same height as the throttle. Easy to grab without looking and LOTS of mechanical advantage. Not commenting at this time about the relative merits or each type of release. Dan, Were these 3 foot handles the original design approved by the FAA or were they conversions later? I understand that it is not permissible to simply fabricate a longer handle and have it installed. Walt -- Dan, 5J |
Dan,
Were these 3 foot handles the original design approved by the FAA or were they conversions later? I understand that it is not permissible to simply fabricate a longer handle and have it installed. Walt It actually is relatively easy to approve a longer handle Walt. AC 43.13-2B You would need to do 337 and have an IA sign off on it. |
![]() Quote:
I made a comment about the two pilots in question and you are right, there is a wide disparity among pilots relative to skill. A gentleman with obvious physical problems and a 15 year old student who never impressed me while she was dual are exactly the type you have to watch but if we only towed highly experienced pilots no one would get their license to gain that experience. That being said my analysis of the problem tells me that a Schweizer hook is inappropriate when we know the Tost will work under similar circumstances AND that the release handle MUST be immediately available to the tow pilot, not down on the floor or where one must bend and reach and feel for it and it must provide enough mechanical advantage to accomplish the job. Learning that other clubs and facilities have changed to the Tost 30 years ago and that their handles are such that the pilot does not have to do Olympic class gymnastics to grab it concerns me. I realize that we can't pull things out of our asses today and rectify the problem immediately BUT I assure you things will be well underway today to correct my concerns OR I will be starting my second retirement a bit earlier than I had wanted to. Walt |
Slow Tows and Upsets | 7C | Soaring | 0 | March 4th 14 11:41 PM |
F-35: Second test plane powers up, but first plane stays grounded | Mike[_7_] | Naval Aviation | 1 | October 29th 07 09:40 PM |
the plane! the plane! protect it without photons. | Spike | Home Built | 0 | December 17th 05 03:28 AM |
Plane down - NASCAR team plane crashes... | Chuck | Piloting | 10 | October 28th 04 12:38 AM |
Kit plane boom with Sport Plane rules | Dave | Home Built | 1 | February 4th 04 02:37 PM |
