![]() Quote:
Walt |
![]() On 4/25/2017 5:18 AM, Walt Connelly wrote: snip .... AND that the release handle MUST be immediately available to the tow pilot, not down on the floor or where one must bend and reach and feel for it and it must provide enough mechanical advantage to accomplish the job. /snip It's been over a year but, IIRC, the release levers on the three tugs at Sundance Aviation (Moriarty) are hinged at the floor with an approximately 3-foot lever at about the same height as the throttle. Easy to grab without looking and LOTS of mechanical advantage. Not commenting at this time about the relative merits or each type of release. |
![]() Quote:
Were these 3 foot handles the original design approved by the FAA or were they conversions later? I understand that it is not permissible to simply fabricate a longer handle and have it installed. Walt |
Walt, I can't answer that.
When I started towing at Sundance, both the CallAir and the Pawnee had long handles. When the Ag Wagon came, it did, too. As I said, it's been over a year since I looked into any of those cockpits, so I may not be remembering correctly. I'll try to remember to take a look next time I go to the airport. Dan On 4/27/2017 5:34 AM, Walt Connelly wrote: Dan Marotta;944164 Wrote: On 4/25/2017 5:18 AM, Walt Connelly wrote: snip .... AND that the release handle MUST be immediately available to the tow pilot, not down on the floor or where one must bend and reach and feel for it and it must provide enough mechanical advantage to accomplish the job. /snip It's been over a year but, IIRC, the release levers on the three tugs at Sundance Aviation (Moriarty) are hinged at the floor with an approximately 3-foot lever at about the same height as the throttle. Easy to grab without looking and LOTS of mechanical advantage. Not commenting at this time about the relative merits or each type of release. Dan, Were these 3 foot handles the original design approved by the FAA or were they conversions later? I understand that it is not permissible to simply fabricate a longer handle and have it installed. Walt -- Dan, 5J |
Dan,
Were these 3 foot handles the original design approved by the FAA or were they conversions later? I understand that it is not permissible to simply fabricate a longer handle and have it installed. Walt It actually is relatively easy to approve a longer handle Walt. AC 43.13-2B You would need to do 337 and have an IA sign off on it. |
Slow Tows and Upsets | 7C | Soaring | 0 | March 4th 14 11:41 PM |
F-35: Second test plane powers up, but first plane stays grounded | Mike[_7_] | Naval Aviation | 1 | October 29th 07 09:40 PM |
the plane! the plane! protect it without photons. | Spike | Home Built | 0 | December 17th 05 03:28 AM |
Plane down - NASCAR team plane crashes... | Chuck | Piloting | 10 | October 28th 04 12:38 AM |
Kit plane boom with Sport Plane rules | Dave | Home Built | 1 | February 4th 04 02:37 PM |
