PZL KI13 Compass adjustment / manual
Old May 14th 17, 05:19 PM posted to rec.aviation.soaring
Default PZL KI13 Compass adjustment / manual
On Friday, May 12, 2017 at 11:20:07 AM UTC-4, wrote:
My glider came with a PZL KI13 Compass - it turns fine but seems to be 90° out of alignment. I tried to adjust it and found I could choose between 90 or 180° of incorrectness!
It might be because of the Borgelt B40 vario I put next to it so I may not be able to keep this setup. I didn't notice if it was correct before changing the position of a couple of instruments.
Does anyone have a manual or instructions on how to adjust it?
I don't know if the (2) E-W & N-S screws should be turned 0-360 degrees (1 full turn) or multiple full turns etc.
thanks
Chris
Most likely the cause is external magnetic field from electric variometer. Try relocating the compass before any more effort elsewhere.
Need Help with VOR error adjustment PiperFlyer Owning 4 March 7th 10 01:50 PM
value adjustment for short tbo on cam Paul kgyy Piloting 3 November 27th 07 12:29 PM
value adjustment for short tbo on cam Paul kgyy Owning 3 November 27th 07 12:29 PM
KI-209 VOR/LOC/GS Indicator adjustment kontiki Owning 13 April 25th 05 11:35 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
