SPOT 3 now reporting altitude?
Old May 15th 17, 04:17 PM posted to rec.aviation.soaring
Tom BravoMike
Default SPOT 3 now reporting altitude?
On Monday, May 15, 2017 at 12:07:39 AM UTC-5, 2KA wrote:
I can confirm that both the XML and JSON feeds from SPOT now contain a (new) altitude field. It reports in meters. I have test flown and verified that it is the accurate GPS altitude.
So far, I see this data filled in only in tracking messages. In messages sent in response to a button push, the field appears to be zero.
I also note quite a few instances of drop-outs -- perhaps as many as 20% or 30% of all messages. I speculate that these may be related to instances where the rapid acquisition GPS engine in the SPOT fails to get enough satellites for a 3D solution. In these cases altitude is reported as zero or negative.
Darryl Ramm
May 7
I think you'll find the data you are looking at is the height of the ground where you flew, which Spot has had inits Web UI forever, maybe you never noticed it before. No spot system transmits altitude data, and the current message format used does not have space for such data.
Darryl Ramm? What's your take on that?
Tom BravoMike
Old May 15th 17, 10:09 PM posted to rec.aviation.soaring
Darryl Ramm
Darryl Ramm
May 7
Tom BravoMike
If they have added this it is an impressive deployment of updating (and supporting now two) over the air data message formats. it will be interesting to see if this feature was hidden in the original Spot 3 or added in a firmware update.
Now looks like they need to solve some performance options. I don't have a Spot 3 so I can't test.
Old May 16th 17, 03:16 AM posted to rec.aviation.soaring
2KA
There was indeed a recent firmware update. I didn't test before installing the update, so I can't say for sure if it was added then -- but it seems likely.
Lynn
Delorme InReach reporting elevation or altitude ?? [email protected] Soaring 6 March 3rd 13 04:57 PM
Good News on Delorme InReach (2 min tracking and altitude vs. Spot w/10 min tracking and no altitude) Sean F (F2) Soaring 34 February 24th 13 12:46 AM
SPOT User Survey - Altitude? MarkHawke7 Soaring 12 August 8th 09 07:25 PM
Spot deal, today only, buy service get a free Spot Tim Taylor Soaring 3 December 1st 08 10:30 PM
Vector altitude for ILS below GS intercept altitude? M Instrument Flight Rules 23 May 20th 06 07:41 PM
