Reserve altitude
Old May 26th 17, 01:46 PM posted to rec.aviation.soaring
MNLou
Default Reserve altitude
Hi Evan -
Would you please expand a bit on why you think it is better to set reserve altitude to zero?
Thanks!
Lou
Old May 26th 17, 03:08 PM posted to rec.aviation.soaring
Tango Eight
On Friday, May 26, 2017 at 8:46:28 AM UTC-4, MNLou wrote:
Hi Evan -
Thanks!
Lou
Uh, sure. This is a semi-religious issue, so opinions will vary. Here's my $0.02 on a rainy day:
Conditions vary. Airport environments vary. I happen to fly in a region of the world (Northern New England) that features a lot of terrain that runs between poorly landable and completely unlandable, and weather than runs from benign to a crash-waiting-to-happen. While my environment is more challenging than many, yours isn't uniform, either.
So, the basic point is: there is no one standard reserve height that is appropriate in all situations. You as PIC need to be making decisions based on environment, current conditions & anything else that affects safety of flight. The computer is your assistant, not your decision maker.
For example: At my home airport (also DC's home airport) our traffic pattern is high due to surrounding terrain and your final glide ought to be padded well beyond this because there is simply no safe place to land other than the airport for a radius of about 5 miles (and then only one or two places, not necessarily where you want them!). Furthermore, the "safe" (that is, landable) route into my home airport follows a river valley which often features a) valley winds and b) subsiding air. I'm usually looking for 1500' over an MC 2.0 (kts) final glide from 25 out, based on the airport elevation. When I was learning to fly XC here, it was more like 2000 over.
This is total overkill at a million flat lands airports.
The obvious, simple solution is to set your flight computer to report estimated arrival height at any destination without any reserve, then do the PIC decision making thing. For old Cambridge gear, that's trivial. For ClearNav, there's one gotcha involved (easily handled, set the purple amoeba to zero and the red one to 1000 agl), for SN-10, you have to build yourself a whole new database with fake-news airport elevations (yes, people really do this, I've watched).
Go fast, make good decisions, land safe!
best,
Evan Ludeman / T8
Old May 26th 17, 03:26 PM posted to rec.aviation.soaring
Steve Thompson[_2_]
I agree with Evan.
But why not get the guys at LXNav, Naviter,
LXNavigation, to call it arrival "height" and reserve
"height" if you must have it? Which imho is what it is
displayed, and this more precise terminology might
remove at least one source of confusion.
While you're at it, Waypoints have Elevation, perhaps.
Hi Evan -=20
=20
better to set
reserv=
e altitude to zero?
=20
Thanks!
=20
Lou
vary. Here's
m=
to fly in a region
o=
of terrain that
runs=
f=
environment is more
chal=
height that is
app=
decisions based
o=
affects safety of
fl=
maker.
patter=
ought to be
padde=
place to land other
than=
one or two
places=
the "safe" (that
is,=
valley which often
fe=
looking for
1500'=
the airport
elevati=
like 2000 over.=20
This is total overkill at a million flat lands airports.=20
computer to report
estim=
PIC=
trivial. For
Clear=
to build yourself a
(yes, people really
do=
best,
Evan Ludeman / T8
Old May 26th 17, 03:59 PM posted to rec.aviation.soaring
John Cochrane[_3_]
I also set reserve to zero. Remembering which reserve altitude is set for the glide to turnpoint, glide to alternates, glide to finish, and the two amoebas (clearnav) is too much for me. So I set them all to zero. If I want to arrive at 1000', I don't proceed unless it says 1000' (plus a decent macCready). The one exception is the finish -- if it's a contest finish and the arrival height is 1000' MSL, then I set that to 1000' MSL, which is the logical equivalent of zero.
John Cochrane BB
Old May 28th 17, 01:18 AM posted to rec.aviation.soaring
Craig Reinholt
I prefer setting an appropriate pattern entry altitude for the simple reason that many places I fly have a ridge or other high obstacle to clear before I get home. The LX9000 software will show if my current final glide will clear the offending obstacle. Granted, it isn't full proof, but it gives a general idea. Setting the reserve to zero negates this feature.
Craig
Old May 28th 17, 07:17 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Craig
I agree with Craig and John.
1) I don't like the idea of setting up a final glide where I get no indication if the calculation works out that I will clear a ridge by 1 foot. I'd like to know if it's going to be close.
2) Most contest finish cylinders are 1000' - the scoring equivalent of ground level (sort of).
Therefore 1000' reserve is what I use. If I have a half-decent climb I will go to at least Mc=4 plus an additional 500-1000'.
Andy Blackburn
9B
Old May 28th 17, 10:17 AM posted to rec.aviation.soaring
Bruce Hoult
Craig
Not having used one of these devices: if you set 1000' reserve and Mc=10, will you be at 1000 ft when you arrive, or after you pull up?
Old May 28th 17, 05:03 PM posted to rec.aviation.soaring
Steve Koerner
With ClearNav you can use the Amoebas as a good way of verifying ridge clearance. Set one amoeba to zero and the other to 1000 ft. Using the Amoebas for the ridge problem, allows the more sensible: reserve = 0 setting. Using the amoeba this way gives a visual / analog sense of clearance that is really better than a go/ no go. The width of the amoeba clearance through the pass or over the ridge provides a great indication of margin.
Old May 26th 17, 10:23 PM posted to rec.aviation.soaring
Hi Evan -
Thanks!
Lou
I think the idea behind reserve altitude is somehow simplify thinking about getting home. Unless you have a positive number for your arrival, don't start your final glide. However, I think it does the opposite. Every pilot I know (and me when I used a reserve) would be thinking " I have a thousand feet over a thousand feet (reserve)". So when it was supposed save math, it really complicates it. No big deal on a fat glide, but the real problem is when it is not working out on final.
So you are on final glide, things go south, and now you are "under glide". You could be in a reasonable position, but you are seeing a very worrying -270 ft on the display. Is it safe to stay on glide, or do you need to really worry. Much better to have set your "goal" to arrive at 1000 ft, have no reserve, and then when it does not work out, you are seeing exactly what you want (or don't want) to know, you are 730' over. If your panties are in a bunch, and you are trying to add a reserve (was it 1000, or 800ft) to your negative glide number, it is just the distraction you don't want.
Set the reserve to 0, and head home at your comfort level + the amount you used to have in your reserve. It will be a much better display if you end up with a squeaker...
Rick
Good News on Delorme InReach (2 min tracking and altitude vs. Spot w/10 min tracking and no altitude) Sean F (F2) Soaring 34 February 24th 13 12:46 AM
Vector altitude for ILS below GS intercept altitude? M Instrument Flight Rules 23 May 20th 06 07:41 PM
GPS altitude vs altimeter altitude Chris W Piloting 37 April 19th 06 10:45 AM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 10:48 AM
FA: New ASA IP Trainer V6.5 IFR - no reserve Scaggs Island Pilots Supplies Aviation Marketplace 0 August 26th 03 03:07 AM
