In-Flight CG Calculation
Old May 30th 17, 05:11 PM posted to rec.aviation.soaring
JS
Default In-Flight CG Calculation
JJ's trim handle technique seems the best in-flight indicator, and requires no additional sensors.
What happened to the "That Looks About Right" technique? Isn't that how it all ends up?
The Blanik L13 was great for TLAR. If it went over on the nose when you climbed in the C/G was too far forward, so put the big pilot in the back. The DG1000 is similar, but waits until the wheel brake is applied on landing... Ask the USAF TPS.
From experience, an LS4 with 70 liters of water in the cockpit is beyond the forward C/G limit. Also from experience the Nimbus 3 at 108% and ASW27 at 112% fly nicely.
Wondering what the CG position on XX's test flight of the same N3 with the broken Mercury weight shift system was.
302 wind calculation 5Z Soaring 1 March 26th 10 11:56 AM
302 wind calculation AK Soaring 0 March 26th 10 02:47 AM
flight computer calculation Tim General Aviation 1 April 26th 05 10:40 AM
Three leg GS to TAS calculation Mike Rapoport Owning 21 September 12th 04 04:37 AM
The "Complex" TAS calculation Arnold Pieper Soaring 2 December 14th 03 12:22 PM
