Even 9mm is a lot, the DG-300 had a similar problem and it was found that the root rib was deforming under closing loads. Check the mounting of all spoiler controls.........looking for a loose rib or mounting pads, etc. Check the whole spoiler by trying to move it up-dowd, for-aft, Inboard-outboard to see if the pivot points are loose. Some sing very wong here!
JJ |
LS-6b Spoiler Issues | Stu | Soaring | 2 | April 1st 13 05:54 PM |
Spoiler Signal | [email protected] | Soaring | 14 | August 2nd 11 08:22 PM |
using less spoiler just before the flare??? | Gary Emerson | Soaring | 16 | October 29th 07 01:08 PM |
Landing with one spoiler | [email protected] | Soaring | 82 | October 7th 05 12:58 AM |
Spoiler placement and design. | B2431 | Home Built | 9 | November 11th 03 04:02 PM |
