Interesting. I believe that this is the HF part that JJ is talking about.
https://www.harborfreight.com/8-in-r...ake-61836.html Question: is a solid rubber tire, versus pneumatic, an issue for a tail dolly? I had put a solid rubber wheel on mine years ago due to a flat tire and caught all sorts of grief from nay-sayers. Something about vibration from uneven ground being transmitted into the boom with ill effect. Thanks. |
On Monday, June 5, 2017 at 4:00:29 PM UTC+3, OHM Ω http://aviation.derosaweb.net wrote:
Interesting. I believe that this is the HF part that JJ is talking about.. https://www.harborfreight.com/8-in-r...ake-61836.html Question: is a solid rubber tire, versus pneumatic, an issue for a tail dolly? I had put a solid rubber wheel on mine years ago due to a flat tire and caught all sorts of grief from nay-sayers. Something about vibration from uneven ground being transmitted into the boom with ill effect. Thanks. |
Interesting. I believe that this is the HF part that JJ is talking about.. https://www.harborfreight.com/8-in-r...ake-61836.html Question: is a solid rubber tire, versus pneumatic, an issue for a tail dolly? I had put a solid rubber wheel on mine years ago due to a flat tire and caught all sorts of grief from nay-sayers. Something about vibration from uneven ground being transmitted into the boom with ill effect. They probably have a point. Maybe putting an appropriate length of thick walled rubber hose with suitable outside diameter inside a regular tyre would be a good compromise? I'm thinking the kind of thing they use for milking machines ("vacuum hose") might be good. |
On 5/06/2017 23:00, OHM Ω http://aviation.derosaweb.net wrote:
Interesting. I believe that this is the HF part that JJ is talking about. https://www.harborfreight.com/8-in-r...ake-61836.html Question: is a solid rubber tire, versus pneumatic, an issue for a tail dolly? I had put a solid rubber wheel on mine years ago due to a flat tire and caught all sorts of grief from nay-sayers. Something about vibration from uneven ground being transmitted into the boom with ill effect. Thanks. Polyurethane foam-filled tyres in the same size as most tail dollies are used for the front wheels of common wheel chairs. They're quite cheap (the $$$$ word 'aviation' doesn't appear) and work perfectly. google will tell you your local supplier. -- GC |
Yeah, that's the caster............I switched to Libelle tail wheel just to make it lighter. The solid tire would be fine if your crew can deal with it.
Cheers, JJ |
Ka-6 E Tail Dolly | [email protected] | Soaring | 0 | November 8th 15 04:26 PM |
Tail dolly for 1-35? | [email protected] | Soaring | 5 | October 22nd 13 11:14 PM |
LS1 Tail locking spring | Andrew[_9_] | Soaring | 7 | September 24th 10 02:09 AM |
LS4 tail dolly | Leigh | Soaring | 0 | May 30th 08 02:02 AM |
FS: ASW-24 Tail Dolly | [email protected] | Soaring | 0 | December 26th 06 02:40 PM |
