Locking tail dolly
Old June 5th 17, 03:37 PM posted to rec.aviation.soaring
[email protected][_2_]
Default Locking tail dolly
On 5/06/2017 23:00, OHM Ω http://aviation.derosaweb.net wrote:
Interesting. I believe that this is the HF part that JJ is talking about.
https://www.harborfreight.com/8-in-r...ake-61836.html
Question: is a solid rubber tire, versus pneumatic, an issue for a tail dolly? I had put a solid rubber wheel on mine years ago due to a flat tire and caught all sorts of grief from nay-sayers. Something about vibration from uneven ground being transmitted into the boom with ill effect.
Thanks.
Polyurethane foam-filled tyres in the same size as most tail dollies are
used for the front wheels of common wheel chairs. They're quite cheap
(the $$$$ word 'aviation' doesn't appear) and work perfectly.
google will tell you your local supplier.
GC
Ka-6 E Tail Dolly [email protected] Soaring 0 November 8th 15 04:26 PM
Tail dolly for 1-35? [email protected] Soaring 5 October 22nd 13 11:14 PM
LS1 Tail locking spring Andrew[_9_] Soaring 7 September 24th 10 02:09 AM
LS4 tail dolly Leigh Soaring 0 May 30th 08 02:02 AM
FS: ASW-24 Tail Dolly [email protected] Soaring 0 December 26th 06 02:40 PM
