Tost Ring Failure
Old June 6th 17, 02:44 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default Tost Ring Failure
On Tuesday, June 6, 2017 at 7:29:55 AM UTC-4, Dan Daly wrote:
On Tuesday, June 6, 2017 at 6:54:52 AM UTC-4, Tango Eight wrote:
http://www.tost.de/PDF/Arbeitskatalog_engl.pdf
Page 19.
Welded rings are long obsolete (or possibly counterfeit).
The right rings to use are easily identified.
It's pretty important to be using the right rings.
best,
Evan / T8
The manual also says that the standard dimensions should be checked and they are available from the factory. Does anyone in ras-land have them?
Received a pdf by e-mail; thanks, Glen from Aboyne.
Tow ring attachment? Waveguru Soaring 7 May 25th 15 07:50 AM
Tost release failure Bill D Soaring 24 August 20th 13 10:49 AM
TOST Release Failure - Two Uncommanded Release's [email protected] Soaring 11 October 13th 12 10:23 AM
red ring of death larryo keeffecom Soaring 1 February 29th 12 03:50 PM
VW Flywheel O-ring [email protected] Home Built 0 April 6th 08 09:57 PM
