Letter to the FAA
Old June 8th 17, 02:52 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Quote:
Originally Posted by View Post
Walt-
Before you go off with velocity but no direction, please supply the names and incidences of all these dead tow pilots. You see a problem because it happened to you. I agree that perhaps the Schweizer release is susceptible to failures when the towed glider is wildly out of position, and that there is likely a remedy through either inverting the release or hoping for better training.
Asking for a ban on these release mechanisms nationwide is likely to cause a large number of glider operations to halt operations since the Schweizer release is the ONLY mechanism accepted for a particular tow plane. Banning the Schweizer release is likely to shut down an active club or commercial operator.
The FAA will issue a Notice of Proposed Rule Making (NPRM) prior to proposing an Airworthiness Directive that would ban the use of the Schweizer release. They will have to justify this by citing the "Unsafe conditions" that the AD is supposed to correct. You will have to supply the evidence that this is, in fact, a valid concern. Be prepared with solid evidence of fatalities, accidents incidents and testimony from affected parties. Your word and your singular experiences will not be enough.
Commercial operators and clubs faced with a significant monetary outlay to change release systems are encouraged to document the hundreds of thousands of successful aerotows using the Schweizer release with no incidents or accidents (or tow pilot fatalities).
You don't like Schweizer releases because of your particularly terrifying experience, and I can heartily agree and accept that. Glad you are still around. But, how many tows have you done with the same system that went off without a hitch?
I have fallen off a bicycle several times. (Also motorcycles, hang gliders, horses etc., etc.) but I don't see the need to stop other participants when the vast majority of operations are carried out successfully..
Or, as one of my more colorfully necked acquaintances recently said,
"Y'all don't need ta' NUKE the gopher!"
Mark,
I am surprised that you would ask the question "But how many tows have you done with the same system that went off without a hitch?" Are you serious? Well, to answer your question I have done just short of 7,000 tows prior to my "dismissal." Of those seven thousand, TWO resulted in a severe, sudden, unanticipated kiting which resulted in my need to attempt to release. Of those two situations, IN ONE HUNDRED PERCENT OF THEM I WAS UNABLE TO RELEASE FROM THE GLIDER.
I too have fallen from my bicycle, I was a USCF Senior Three many years and about 40 pounds ago. The bicycle fall was my fault, no one elses. I have dropped my motorcycle in the rain, my fault, no one elses. I too have fallen from a horse, my fault. The difference here is that a tow pilot is connected to a glider by a 200 foot rope and the glider pilot can negatively affect the situation with no fault of the tow pilot. If at that moment the system that is meant to save the life of the tow pilot doesn't work (and it is beyond well documented that it might not) the tow pilot could be dead. What part of this is it that some people don't seem to understand?
I am willing to allow the SFF/SAA and their representatives handle this but the fact is they have had decades to do so and have failed in this regard.
Walt
Old June 8th 17, 09:24 PM posted to rec.aviation.soaring
Default Letter to the FAA
It did!
Old June 9th 17, 08:38 PM
Senior Member
I am in receipt of an email from the SSA Government Liason representative Mr Northcutt. I am truly amazed at being told that since I am NOT a current member of the Soaring Society of America he is unwilling to discuss my concerns.
He did go on to make three bullet points which make me think he did not read my email.
To say that perhaps the facility at which I worked need to address their training is a bit presumptative. One pilot was not from this field, but one of the many who come down to this facility due to the weather. The second was a 15 year old solo student on her third pull. For those of you familiar with the USAFA accident where the cadet instructor noted she was above the tow plane with a "taught" rope and decided to increase pitch to slow up and allow the tow pilot to get back in position I would ask, "how can we expect a 15 year old student to understand the importance of releasing in such a position if a USAFA student and CFI-G doesn't understand and react properly?
I am well aware of the FAA requirements for PIC. The airplanes I was flying were not unsafe to fly and the Schweizer hook system is approved by the FAA. My concern is one that has been expressed by other pilots and which has directly contributed to the death of more than one tow pilot here and in other countries.
My investigation of the available information continues, it will take some time but I will try to be as thorough as possible.
Walt
Old June 10th 17, 03:01 AM posted to rec.aviation.soaring
Do you even fly bro?
read my email.
Walt
Walt Connelly
Old June 10th 17, 05:33 AM posted to rec.aviation.soaring
Tom BravoMike
I would think that any institution we deal with, FAA, SSA, EAA, AOPA etc,. etc. should take with highest level of seriousness any remark concerning safety made by a pilot and based on his/her life-threatening experience in flight, member or not.
Several years ago when flying their LS-4 at Soar Minden I was in a situation after landing where the wheel brake, activated by pushing both rudder pedals, seemingly didn't work on a roll-out. I was happy I didn't hit any one on the tarmac. I quickly found out that you have to push with your HEELS, and not FEET. I reported my observation to their instructor with a reference to a possible wrong translation in the glider's Flight Manual, which I had studied before the flight. Some time later checking their web site I was pleased and grateful to see they had reacted and put a proper remark in the manual. The German original reads: "wird mit den Absätzen bedient". I just found the English manual for the LS-4A on-line, and it reads correctly now: "Press rudder pedals with heels to activate wheel brake" - so it must have been amended officially.
Just an example of a proper concern instead of a denial.
Tom BravoMike
Old June 10th 17, 04:17 PM
Senior Member
Tom BravoMike
I would think the same Tom but apparently the SSA is less concerned with safety and more concerned with who is and who is not a member of the club. But for that matter every club and commercial operation out there still flying with Schweizer hooks and release handles not immediately accessable by the tow pilot are not concerned with safety either.
Walt
Old June 10th 17, 07:49 PM posted to rec.aviation.soaring
Tango Eight
Walt
So you weren't concerned with safety, either, until very recently?
best,
Evan Ludeman / T8
Old June 11th 17, 05:21 AM posted to rec.aviation.soaring
[email protected][_1_]
There are treatments for PTSD that don't involve the FAA.
The odds of anything rational and positive coming from involving .GOV is really poor.
Old June 11th 17, 01:57 PM
Senior Member
Walt
best,
Evan Ludeman / T8
Evan, I would say that your thought process needs some work.
Walt
from latest news letter on vulcan, hope it is of intrest to some of you if you dont get the news letter PAUL H Aviation Photos 0 January 27th 13 11:21 AM
A LETTER OF THANKS minimoa Soaring 0 September 14th 10 12:06 AM
Letter from TSA? Emily Piloting 14 August 14th 06 11:33 PM
A letter to a friend... Greasy Rider© @ invalid.com Naval Aviation 3 August 23rd 05 12:23 AM
Letter from TSA Rosspilot Piloting 2 November 20th 03 01:12 AM
