On Monday, June 12, 2017 at 7:14:35 AM UTC-7, wrote:
That is true for the small ring! They are seamlessly rolled or forged but the large ring has to get through it somehow, so it starts its life as a piece or 'wire' which gets formed and its ends are then joined by electric resistance welding (look up 'chain making' on YouTube). Today, I inspected all the large rings of the double ring pairs I have with our winch and all of them show the tell-tale signs of a weld opposite of the stamped name 'Tost'. At least a close visual did not show any cracks.. Maybe a simple 'dye-pen test is in order. Uli 'AS' I seem to remember having read that the rings are made that way without any form of welding now. I suppose you could get the exact method used if you agree to pay for the technical norm: http://standards.globalspec.com/std/...7/din-ln-65091 It's cheaper than ordering from the original German institute: http://www..din.de/en/getting-involv...din21:84399512 Correct. Any connecting rings meeting Aeronautical Standard (LN) 65091 can't be welded. Tost connecting rings pairs are made from steel fine cast. The small ring and large ring are casted into each other. This casting is an elaborate procedure. Rings with welding seam are not from Tost and do not meet the Aeronautical Standard. Sean Franke |
On Monday, June 12, 2017 at 11:12:03 AM UTC-7, Sean Franke wrote:
On Monday, June 12, 2017 at 7:14:35 AM UTC-7, wrote: That is true for the small ring! They are seamlessly rolled or forged but the large ring has to get through it somehow, so it starts its life as a piece or 'wire' which gets formed and its ends are then joined by electric resistance welding (look up 'chain making' on YouTube). Today, I inspected all the large rings of the double ring pairs I have with our winch and all of them show the tell-tale signs of a weld opposite of the stamped name 'Tost'. At least a close visual did not show any cracks. Maybe a simple 'dye-pen test is in order. Uli 'AS' I seem to remember having read that the rings are made that way without any form of welding now. I suppose you could get the exact method used if you agree to pay for the technical norm: http://standards.globalspec.com/std/...7/din-ln-65091 It's cheaper than ordering from the original German institute: http://www.din.de/en/getting-involve...din21:84399512 Correct. Any connecting rings meeting Aeronautical Standard (LN) 65091 can't be welded. Tost connecting rings pairs are made from steel fine cast. The small ring and large ring are casted into each other. This casting is an elaborate procedure. Rings with welding seam are not from Tost and do not meet the Aeronautical Standard. Sean Franke Web page has been reconstructed. It has new detailed pictures. It also has a standard dimensions diagram. http://wingsandwheels.com/tost-double-tow-rings.html Sean Franke |
On Monday, June 12, 2017 at 7:56:05 PM UTC-4, Sean Franke wrote:
On Monday, June 12, 2017 at 11:12:03 AM UTC-7, Sean Franke wrote: On Monday, June 12, 2017 at 7:14:35 AM UTC-7, wrote: That is true for the small ring! They are seamlessly rolled or forged but the large ring has to get through it somehow, so it starts its life as a piece or 'wire' which gets formed and its ends are then joined by electric resistance welding (look up 'chain making' on YouTube). Today, I inspected all the large rings of the double ring pairs I have with our winch and all of them show the tell-tale signs of a weld opposite of the stamped name 'Tost'. At least a close visual did not show any cracks. Maybe a simple 'dye-pen test is in order. Uli 'AS' I seem to remember having read that the rings are made that way without any form of welding now. I suppose you could get the exact method used if you agree to pay for the technical norm: http://standards.globalspec.com/std/...7/din-ln-65091 It's cheaper than ordering from the original German institute: http://www.din.de/en/getting-involve...din21:84399512 Correct. Any connecting rings meeting Aeronautical Standard (LN) 65091 can't be welded. Tost connecting rings pairs are made from steel fine cast. The small ring and large ring are casted into each other. This casting is an elaborate procedure. Rings with welding seam are not from Tost and do not meet the Aeronautical Standard. Sean Franke Web page has been reconstructed. It has new detailed pictures. It also has a standard dimensions diagram. http://wingsandwheels.com/tost-double-tow-rings.html Sean Franke Confused; one header has "New Edition of LN 54091" vs LN65091. Is 54091 new? Thank you for publishing the dimensions of the tow ring; must get busy with a micrometer this weekend! Dan |
On Monday, June 12, 2017 at 8:06:29 PM UTC-7, Dan Daly wrote:
On Monday, June 12, 2017 at 7:56:05 PM UTC-4, Sean Franke wrote: On Monday, June 12, 2017 at 11:12:03 AM UTC-7, Sean Franke wrote: On Monday, June 12, 2017 at 7:14:35 AM UTC-7, wrote: That is true for the small ring! They are seamlessly rolled or forged but the large ring has to get through it somehow, so it starts its life as a piece or 'wire' which gets formed and its ends are then joined by electric resistance welding (look up 'chain making' on YouTube). Today, I inspected all the large rings of the double ring pairs I have with our winch and all of them show the tell-tale signs of a weld opposite of the stamped name 'Tost'. At least a close visual did not show any cracks. Maybe a simple 'dye-pen test is in order. Uli 'AS' I seem to remember having read that the rings are made that way without any form of welding now. I suppose you could get the exact method used if you agree to pay for the technical norm: http://standards.globalspec.com/std/...7/din-ln-65091 It's cheaper than ordering from the original German institute: http://www.din.de/en/getting-involve...din21:84399512 Correct. Any connecting rings meeting Aeronautical Standard (LN) 65091 can't be welded. Tost connecting rings pairs are made from steel fine cast. The small ring and large ring are casted into each other. This casting is an elaborate procedure. Rings with welding seam are not from Tost and do not meet the Aeronautical Standard. Sean Franke Web page has been reconstructed. It has new detailed pictures. It also has a standard dimensions diagram. http://wingsandwheels.com/tost-double-tow-rings.html Sean Franke Confused; one header has "New Edition of LN 54091" vs LN65091. Is 54091 new? Thank you for publishing the dimensions of the tow ring; must get busy with a micrometer this weekend! Dan I shortened the heading from "New edition 2005 of LN 65091 (supersedes edition 1985-12)" Sean Franke |
Tow ring attachment? | Waveguru | Soaring | 7 | May 25th 15 07:50 AM |
Tost release failure | Bill D | Soaring | 24 | August 20th 13 10:49 AM |
TOST Release Failure - Two Uncommanded Release's | [email protected] | Soaring | 11 | October 13th 12 10:23 AM |
red ring of death | larryo keeffecom | Soaring | 1 | February 29th 12 03:50 PM |
VW Flywheel O-ring | [email protected] | Home Built | 0 | April 6th 08 09:57 PM |
