Flarm Range Analysis
Old June 14th 17, 01:34 AM posted to rec.aviation.soaring
waremark
Default Flarm Range Analysis
In my Arcus I have the receive and transmit aerial where fitted by the factory on top of the rear glare shield, and the receive only aerial on the belly in front of the main wheel.
Old June 14th 17, 07:20 PM posted to rec.aviation.soaring
Dan Marotta
Unfortunately, the lower receive-only antenna may have nothing to
receive if the upper transmit-receive antenna is blocked by the fuselage
and does not ping the approaching aircraft behind/below.
Dan, 5J
Old June 15th 17, 11:57 AM posted to rec.aviation.soaring
Dan Daly[_2_]
Dan, 5J
Hi Dan. The flarm doesn't work as an interrogator/response system like a transponder. From flarm.com : "Each FLARM system determines its position and altitude with a sensitive GPS receiver. Based on speed, acceleration, track, turn radius, wind, altitude, vertical speed, aircraft type, and other parameters, a precise projected flight path can be calculated. The flight path, together with additional information such as a unique identification number, is encoded before being broadcast over an encrypted radio channel twice per second."
So the lower antenna doesn't "ping" the other flarm - it receives the signal which is transmitted twice per second by any flarm within its view.
Another Dan
Old June 15th 17, 03:56 PM posted to rec.aviation.soaring
Dan Marotta
Thanks for that explanation! To me that means that the guy in the
carbon glider below me may not "see" me but I will (statistically) "see"
him with a lower antenna. I'll look into mounting my "B" antenna on the
belly then.
Dan
Dan, 5J
Another Dan
Dan, 5J
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
FLARM Range [email protected] Soaring 11 June 16th 15 11:44 PM
Flarm range Ramy[_2_] Soaring 7 May 7th 15 11:02 PM
PowerFlarm Range Analysis for "WX" - 15M Nats Yreka 2014 WaltWX[_2_] Soaring 13 March 27th 15 10:34 PM
PowerFlarm Range Analysis Richard[_9_] Soaring 0 March 25th 13 04:43 PM
