I raised all of these issues with FLARM years ago. The typical statistics from a flight do not support the range analysis very well at all. I asked for the ability to upload multiple files but was completely blown off by FLARM. I wrote some code to add together many IGC files and it was quite instructive. Their tools work quite a bit better. The problem is that people really don't understand how to read these plots. What you are really getting is the mean range. The problem with that is that contact is really a statistical problem. Really there should be three range rings: Mean range, mean range plus one standard deviation, and mean range minus one standard deviation. I suggested this as well but was completely blown off again.
To get a minimum range with a reasonable contact probability from a safety standpoint, you really should look at the mean minus one standard deviation.. Those are the conditions under which you would have a reasonable confidence interval and know that you will hav a good signal. I suspect that in a large majority of cases, this may actually be a negative number. Unfortunately, people rely on this tech to alert them to a potential collision and the reality is that there is a relatively high probability that it will not do so. People use anecdotal evidence to support unreasonably long contact distances, "the other day I saw XX on my FLARM display from 15km away!", so they assume that is the norm but it is really probably mean plus multiple standard deviations. Unfortunately, they think that is normal when it isn't. FLARM is hampered by several technological problems. Low power transmitters, poorly placed and poorly performing antennas, and low power cpus with insufficient horsepower to handle lots of targets in close proximity. It will never work right. ADS-B uses high power transmitters, reliable position reporting and good antennas that are well placed. ADS-B targets can be easily tracked from 50 miles out. For an anti collision system, I want something that will give me good advanced notice that something is nearby and be compatible with all the other air traffic because it doesn't matter whether I hit another glider or a power plane, it's going to hurt either way. FLARM is a highly flawed product and I won't have it in my aircraft. |
![]() FLARM is a highly flawed product and I won't have it in my aircraft. Interesting post Mike but I'm glad you don't fly in the same airspace as me! Perhaps you should fit Flarm, try it for a season, then post your conclusions? I've yet to meet anyone who purposefully removed a Flarm; it may not be perfect but it's a LOT better than nothing. You might also ask yourself why the French mandate Flarm? Dave Walsh |
On Tuesday, June 13, 2017 at 8:51:26 PM UTC-7, wrote:
I raised all of these issues with FLARM years ago. The typical statistics from a flight do not support the range analysis very well at all. I asked for the ability to upload multiple files but was completely blown off by FLARM. I wrote some code to add together many IGC files and it was quite instructive. Their tools work quite a bit better. The problem is that people really don't understand how to read these plots. What you are really getting is the mean range. The problem with that is that contact is really a statistical problem. Really there should be three range rings: Mean range, mean range plus one standard deviation, and mean range minus one standard deviation. I suggested this as well but was completely blown off again. To get a minimum range with a reasonable contact probability from a safety standpoint, you really should look at the mean minus one standard deviation. Those are the conditions under which you would have a reasonable confidence interval and know that you will hav a good signal. I suspect that in a large majority of cases, this may actually be a negative number. Unfortunately, people rely on this tech to alert them to a potential collision and the reality is that there is a relatively high probability that it will not do so. People use anecdotal evidence to support unreasonably long contact distances, "the other day I saw XX on my FLARM display from 15km away!", so they assume that is the norm but it is really probably mean plus multiple standard deviations. Unfortunately, they think that is normal when it isn't. FLARM is hampered by several technological problems. Low power transmitters, poorly placed and poorly performing antennas, and low power cpus with insufficient horsepower to handle lots of targets in close proximity. It will never work right. ADS-B uses high power transmitters, reliable position reporting and good antennas that are well placed. ADS-B targets can be easily tracked from 50 miles out. For an anti collision system, I want something that will give me good advanced notice that something is nearby and be compatible with all the other air traffic because it doesn't matter whether I hit another glider or a power plane, it's going to hurt either way. FLARM is a highly flawed product and I won't have it in my aircraft. Brakes don't work very well, so I won't have them in my car. They take a long time to stop you, the stopping distance is a statistical average depending on conditions. Yet people actually depend on this flawed concept to keep them from hitting anything. They will never work right. Some people say, "yesterday a truck pulled in front of me but my brakes just stopped me in time!" not realizing that if the road were wet, they would not have. What we need is tractor beams from the Starship Enterprise. They are high power and would stop you instantly, you would never hit anything. Rather than dis the Flarm range tool, why don't you write one that works the way you want? All the information is in the files and is easily parsed. It doesn't even seem like that challenging an app to write. |
![]() FLARM is a highly flawed product and I won't have it in my aircraft. Mark, long time no see. I really recommend that you install Flarm and see how it does. I am still flying out of DKX, and there are a number of power planes with ADSB now that I can see on Flarm. BUT at the Sports Class Nationals in Mifflin, all competitors had Flarm but four. All the contest days were ridge, with the practice day ridge and mixed thermals. Flarm was INCREADIBLY useful when we had closing speeds of 250 mph , and also really useful when someone came up from behind of the side. With the overcast sky on several days it was difficult to see other traffic, and it helped tremendously. When the guys came by that did not have it, it was a very different experience. Please don't fly any competitions that I am in, unless you install Flarm. No its not perfect, but it is really quite good for its intended purpose. Kevin Anderson 92 92 |
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm | [email protected] | Soaring | 28 | March 12th 16 04:31 AM |
FLARM Range | [email protected] | Soaring | 11 | June 16th 15 11:44 PM |
Flarm range | Ramy[_2_] | Soaring | 7 | May 7th 15 11:02 PM |
PowerFlarm Range Analysis for "WX" - 15M Nats Yreka 2014 | WaltWX[_2_] | Soaring | 13 | March 27th 15 10:34 PM |
PowerFlarm Range Analysis | Richard[_9_] | Soaring | 0 | March 25th 13 04:43 PM |
