A Tale of Two Takeoffs
Old June 18th 17, 01:58 AM posted to rec.aviation.soaring
John Cochrane[_3_]
Default A Tale of Two Takeoffs
Many a tow pilot has wondered, "why are they all whining about 60 knot tows, when that's well above their stall speed, even ballasted?" The answer is that gliders following the towplane are in the downwash of the wing -- not the propwash, the downwash -- but the wingtips are not. So, the wingtips are operating at a larger angle of attack than the main wings. They will now stall first.
Even if the wingtip doesn't stall, the aileron does -- you get the aileron response of ragged edge of stall though the main wing is flying. That's why gliders get wallowy and hard to control on tow behind slow towplanes. This has caused crashes. That's also why it's especially a problem when the towplane takes off, gets up to speed, and then heads for the sky, losing speed, as quite a few tow pilots seem to do. Now the glider is slow, stuck in ground effect, well below the towplane, and deep in the downwash. Yes, airspeed indicators are off, but it's not that hard to be aware of the issue, and ask the first few pilots for a calibration. I think the larger problem is we all get used to towing dry, and the higher speeds just don't feel right.. It's a worse problem for standard class, since they're stall speed challenged to start with and many flaps typically allow a little more twist.
10.6.2.9 ...Towplanes will tow at 80 miles per hour (unless otherwise requested) in a pre- selected pattern to an altitude of 2000 feet AGL (or as specified by the CD).
Old June 18th 17, 02:32 AM posted to rec.aviation.soaring
What John said, even though he had to go and mention "whining" again.
For more discussion (any takers?), see "Glider Handling on Tow" on RAS a few years ago: https://groups.google.com/forum/#!searchin/rec.aviation.soaring/%22glider$20handling$20on$20tow%22/rec.aviation.soaring/rxCTVDJnKVc/Qn6gkHnP7EgJ
My number is 60 kts. dry and 70 kts. fully ballasted in a Standard Class glider. Below those numbers, I am VERY uncomfortable and less maneuverable. So add 5 kts. to allow for tow pilots who ease back on the stick after they've climbed up a few hundred feet.
Flapped 15M gliders have a bit more margin. Big ships seem to have still more but I can't speak from experience.
Chip Bearden
"JB"
Old June 18th 17, 04:00 AM posted to rec.aviation.soaring
Echo
That's true....seems ballasted standard class birds have gotta be the highest speed required on tow group. Can't speak much to open class. Not a lot of that on the east coast.
Old June 18th 17, 05:04 PM posted to rec.aviation.soaring
Dan Marotta
This is a great discussion!
Before I retired from towing, my technique was to level off in ground
effect until reaching full towing speed (and note that the glider's
ground effect is deeper than the tug's due to the difference in span)
and then begin a gentle climb at a pitch rate which would preclude a
reduction in airspeed. Some glider pilots like to be towed at 75 KIAS
when fully loaded.
Chip Bearden
"JB"
Dan, 5J
Old June 18th 17, 03:57 AM posted to rec.aviation.soaring
Echo
I must admit the downwash discussion is one I'm not fluent on. I've been around a while, but it's certainly an interesting concept I don't know much about. Makes you wonder how high a position you'd have to be for it not to matter...especially when you consider actual climb gradient, compared to AoA and angular fluid dynamics from the tug wing back to a glider 200' back. I haven't seen it in any book, but the books have been updated a few times and it doesn't mean it doesn't exist.
Old June 18th 17, 10:45 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Its even a bit worse than has been described: your outer wings and
ailerons are in the tow plane's wingtip vortex, which adds a still
further to the AOA difference due to the upward flaw in that part of the
vortex.
Low tow may be a better answer simply because it puts the whole glider
below the tugs downwash and tip vortices. It certainly feels smoother,
but doesn't sort out takeoff and initial climbout problems.
Side comment: the issue of wingtips extending beyond the tug's wing
downwash in pretty much unique to our sailplanes: all of the Allied troop
carrying gliders during WW2 had lower spans than their tugs (a Waco CG4
is smaller than a C47 - look it up if you don't believe me). The only
exceptions were the British Hamilcar (about 6 feet bigger span than the
Halifax tow plane and one or two of the German and Russian troop carriers
when towed by single engine aircraft and, of, course the Me 321 Gigant.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old June 18th 17, 02:50 PM posted to rec.aviation.soaring
Echo
Wow that's interesting stuff. I once went to a WW2 glider museum in Iron Mountain Michigan, but it was more about the manufacturing and stories and less about the design and flight characteristics. The only time I've ever noticed any kind of wash from a towplane is on pavement behind a CAP 182. 100' into the takeoff roll, the right wing always drops. It's a briefing item when we fly there. Spiraling slipstream of a tri gear vs taildragger.
It's a shame we can't put a glider and towplane in a wind tunnel together....or at least some smoke/fluid testing released from the towplane wingtips. So much of aerodynamic "fact" isn't really known, but more speculated and generally accepted. Would be a pretty neat study to actually watch said downwash. I still have never noticed it in flight; It was explained differently to me many years ago, and it has always seemed to prove to be passing below me. If the glider keeps the towplane referenced on the horizon from high tow position, they're essentially level horizontal with each other. That means that the towplane is not dragging the glider through it's path, but rather the two are climbing together, a level horizontal plane going up. (Most gliders' drag in lbs at a tow speed is probably only 50ish pounds...so the tension on the rope wouldn't be much more in order to yield a climb at constant speed. Similar to the discussion on excess power required for climbs in the book Aerodynamics for Naval Aviators). If applying that theory of the horizontal plane climbing evenly, and towing at say 60kts and 500ft/min (for simple math), that's a climb gradient of 500ft/nm, or 5 degrees. So the relative wind is essentially from 5 degrees above the horizon, and downwash results in 5 degrees off below to the rear, or more depending on angle of incidence, etc. That, at 200, back, puts the theoretical downwash line a little over 15 feet below the level horizontal plane that the glider exists in with the towplane. So clearly in that theory, a weak towplane and a heavy glider has many issues beyond clearing the trees, but a strong towplane makes everything less of a factor.
Again that's just a theory, just like the perceived downwash one. My only point here is to say that all this stuff is theory, something from voodoo black magic aerodynamics. It would be truly interesting to hook up some smoke canisters across the wing of the tug and see where it all goes. Same with the tips.
I would love to hear the perspective of military guys here who have done many hours of aerial refueling...what they think about the presence of downwash and how much it affected their aircraft when sitting behind a tanker (with a much higher wing loading).
Jordan
Old June 18th 17, 08:13 PM posted to rec.aviation.soaring
together...or at least some smoke/fluid testing released from the
towplane wingtips.
There seems to have very little research into glider towing, not even in
the Akafliegs, which did surprise me.
Take a look at this:
Wake Turbulence Hazard Analysis For A General Aviation Accident, DLR
2014, DocumentID 340177
You'll need to run a search as I don't have the URL to hand. Its a report
on a crash when a Robin GR400 took off too close behind an Antonov AN-2,
so not directly about glider towing, but there is some good info and
numbers about tip vortexes.
A glider on a 200 ft rope is close enough to the tug to be flying in its
downwash field if it is in the normal tow position, with the glider just
above the turbulent prop wake, which is angled down behind the tug's
flight path at about 1/3 of its AOA. and you can get some idea of the
downwash depth at the glider's distance if you extrapolate from
assumption that the downwash thickness is about half the wing chord at
4-5 chords behind the wing. NOTE this the tug's wing-generated downwash
and has nothing to do with the turbulent prop wake: I don't know how that
is positioned in relation to the wing downwash, how far back it extends
or what its 3D shape might be.
It seems to me that this topic could be the basis of a really nice PhD
thesis for an aerodynamicist.
org |
Old June 19th 17, 12:55 AM posted to rec.aviation.soaring
IIRC Gliding International magazine had something on towplane/glider interference sometime in the last year.
Old June 19th 17, 04:58 AM posted to rec.aviation.soaring
George Haeh
My limited exposure to aerodynamics textbooks leaves me with the
impression that airflow behind the vehicle is neglected.
When heavy jets came out, there was a spate of light aircraft crashes in
wake
encounters, followed by NASA research and guidance on avoiding.
I have not come across any formulae for air behavior behind aircraft. There
are simply general statements that the air will be descending and vortices
will trail the wing tips.
Perhaps a good analogy for being behind a towplane is that it has
similarities
for approaching a ridge from downwind - a bad place for being slow.
14 takeoffs = 14 approaches - Video [email protected] Piloting 0 February 4th 10 01:16 AM
Any early turn takeoffs still around? Michael Instrument Flight Rules 12 June 6th 04 06:24 PM
Ground steering and Takeoffs webmaster Simulators 3 February 15th 04 08:34 PM
F-15 takeoffs Mary Shafer Military Aviation 2 July 1st 03 07:41 AM
