Trig TT22 transponder issues
Old June 18th 17, 06:17 PM posted to rec.aviation.soaring
Echo
Default Trig TT22 transponder issues
Will do. Mid continent (the North American distributor) said check connections. No screen messages. Gonna reset all hookups and try again this weekend...then it's a call to trig.
E
Old June 19th 17, 11:39 PM posted to rec.aviation.soaring
George Haeh
1. Where did you put your L2 antenna? I did fine putting it in the nose
after
shaping a balsa piece to fit.
2. How did you route the coax? With a lifting instrument panel you have to
be
careful the coax does not get mangled by adjacent hardware.
3. Are the coax connectors secure to the conductors, especially outer?
If it gets to the point that you might have to ship it out for diagnosis,
it might
help to hook up the removed components to a battery. If there's a major
airport within 50 miles you should see replies to TCAS interrogations from
the heavies. You don't have to be in the air to receive TCAS
interrogations.
But do double check the harness plugs are seated properly before doing
anything else.
Old June 21st 17, 03:07 PM posted to rec.aviation.soaring
Echo
Yeah the L2 is well behind the control mixing in the mid aft fuselage. It's strange to me because if it were a fault with the antenna or other, my understanding is it should throw a fault code. When it is on (like after I restart it), Nashville approach picks me up fine. I can't get a hold of trig, every time I call I get error messages, so not sure how to call over there if my provider and wifi options aren't working.
Old June 20th 17, 01:29 AM posted to rec.aviation.soaring
George Haeh
after
be
it might
interrogations.
anything else.
Trig TT21 Transponder ... reports? Grider Pirate Soaring 105 March 29th 18 01:10 AM
Trig transponder [email protected] Soaring 0 April 14th 16 03:30 AM
Garmin GPS 20A with Trig TT22 in Experimental Glider - OK? Paul Remde Soaring 35 December 21st 15 05:17 AM
Transponder TT21 versus TT22 - Considerations WaltWX[_2_] Soaring 16 January 23rd 15 06:01 PM
New Trig TT22 Transponder Paul Remde Soaring 1 January 14th 10 07:27 PM
