1. Where did you put your L2 antenna? I did fine putting it in the nose
after shaping a balsa piece to fit. 2. How did you route the coax? With a lifting instrument panel you have to be careful the coax does not get mangled by adjacent hardware. 3. Are the coax connectors secure to the conductors, especially outer? If it gets to the point that you might have to ship it out for diagnosis, it might help to hook up the removed components to a battery. If there's a major airport within 50 miles you should see replies to TCAS interrogations from the heavies. You don't have to be in the air to receive TCAS interrogations. But do double check the harness plugs are seated properly before doing anything else. |
Yeah the L2 is well behind the control mixing in the mid aft fuselage. It's strange to me because if it were a fault with the antenna or other, my understanding is it should throw a fault code. When it is on (like after I restart it), Nashville approach picks me up fine. I can't get a hold of trig, every time I call I get error messages, so not sure how to call over there if my provider and wifi options aren't working.
Trig TT21 Transponder ... reports? | Grider Pirate | Soaring | 105 | March 29th 18 01:10 AM |
Trig transponder | [email protected] | Soaring | 0 | April 14th 16 03:30 AM |
Garmin GPS 20A with Trig TT22 in Experimental Glider - OK? | Paul Remde | Soaring | 35 | December 21st 15 05:17 AM |
Transponder TT21 versus TT22 - Considerations | WaltWX[_2_] | Soaring | 16 | January 23rd 15 06:01 PM |
New Trig TT22 Transponder | Paul Remde | Soaring | 1 | January 14th 10 07:27 PM |
