The belief that low-tow significantly reduces the risk of sling-shot tug
upsets is mistaken. The trigger is if the glider pitches up to about 30 degrees above the line of the rope. Being in low-tow when that happens simple makes the sunsequent event take about half a second longer - not enough extra time to greatly increase the chance of releasing before the critical point. At 08:42 20 June 2017, Justin Couch wrote: On Tuesday, 20 June 2017 15:45:04 UTC+10, Don Johnstone wrote: From another thread it has been confirmed that in Australia low tow=20 is the standard position behind the tug. Definitely. All our training from the first tow is in low position for clim= b. We'll go high if doing a cross-country tow, and some clubs use high tow = for the first couple of hundred feet of the launch, but low is our teaching= here.=20 There is, however, a second factor: All gliders have been mandated to have = nose hooks installed when brought into the country. This was instituted in = mid 80's after a couple of upset accidents resulting in multiple deaths. It= is rare to see a glider with only a belly release. Mandated nose releases= as a local requirement were removed a couple of years ago as CS22 effectiv= ely mandated them for aerotow certification anyway. No need to duplicate th= e rules.=20 Also, I believe Schweizer tow hooks here are illegal. I've only ever seen T= OSTs on tugs here. Don't quote me on that though. I've been doing a quick = search while writing this up and can't find out either way.=20 Does using low tow offer a solution to the ring jam with a Schweizer=20 hook given that there is almost no chance of glider getting too high=20 behind the tug?=20 Tug upsets should be almost unknown in Australia, are they?=20 I haven't heard of one in the last 30 years or so (I started gliding in 198= 7). There's been a few ground loops from wing drops in paddocks on CG relea= ses, but nothing resulting in a tug pilot looking at the ground due to kiti= ng. |
At 13:38 20 June 2017, Chris Rollings wrote:
The belief that low-tow significantly reduces the risk of sling-shot tu upsets is mistaken. The trigger is if the glider pitches up to about 3 degrees above the line of the rope. Being in low-tow when that happen simple makes the sunsequent event take about half a second longer - no enough extra time to greatly increase the chance of releasing before th critical point. That may be so Chris, but would the start of the sequence be more obvious to both the glider and towplane pilot? In low tow the tug is definitely above the glider, the divergent situation should be more immediately recognisable. I accept that the statistics in Australia may be skewed by the requirement for a nose hook but do they show a decrease in the number of tug upsets? Is it not worth some study? Are there other challenges to the use of low tow instead of high tow? Is a procedure which is only marginally safer still a valid consideration? |
The argument that low tow might substantially decrease the chances of tug upsets is limited. As was pointed out by a previous poster this might only increase the chance to react by half a second. My personal experience is that in a sudden kiting situation it's happened before you could react. If it is a slowly evolving circumstance you might have a chance to release. There is an altitude below which the outcome will be disastrous no matter what kind of hook is being used.
In my two experiences both gliders had nose hooks. While the CG hook might enhance the kiting incident the nose hook requirements are not going to eliminate it. While I am all for extra training and vigilance the bottom line is that the human element is still in the picture and humans make mistakes even with the best of training. One moment of failure to pay attention on the part of the glider pilot can result in the death or serious injury of the tow pilot. The Schweizer hook is well documented to be incapable of releasing the glider under certan circumstances. The Tost hook on the other hand does not seem to have these limitations. In virtually every document I have read regarding this it states, "In some towhook systems, the high pressure loading on the towhook causes towhook seizure, and the tow pilot may not be able to release the towline from the towplane. This situation can be critical if it occurs at altitudes below 500 feet above ground level (AGL). Upon losing sight of the towplane, the glider pilot must release immediately." For this reason it is beyond my ability to comprehend why Schweizer hooks are still in use. At a minimum they should be inverted and the release handle should be such that olympic level calesthenics are not necessary for actuation. My letter is nearing completion and I fully intend to submit it to the FAA. Will it cause disruption to the sport? Perhaps, but the fact is that the SSA and their assigns have demonstrated to me that they are unwilling to step forward in the name of safety and act. Walt |
Step away from this Walter. Establish your own limitation, what you will accept.
Allow others the same. Trust me on this. Romeo |
![]() Quote:
I have already stepped further away than I have wanted to but trust ME on this. If YOU had found yourself 300 feet in the air dangling from a tow rope attached to a glider and unable to release while at full power headed right to the dirt YOU WOULD BE ON MY SIDE IN SPADES. PERIOD, END OF STORY. WALT |
On Wednesday, June 21, 2017 at 9:43:20 PM UTC+3, Walt Connelly wrote:
The argument that low tow might substantially decrease the chances of tug upsets is limited. As was pointed out by a previous poster this might only increase the chance to react by half a second. My personal experience is that in a sudden kiting situation it's happened before you could react. If it is a slowly evolving circumstance you might have a chance to release. There is an altitude below which the outcome will be disastrous no matter what kind of hook is being used. In my two experiences both gliders had nose hooks. While the CG hook might enhance the kiting incident the nose hook requirements are not going to eliminate it. While I am all for extra training and vigilance the bottom line is that the human element is still in the picture and humans make mistakes even with the best of training. One moment of failure to pay attention on the part of the glider pilot can result in the death or serious injury of the tow pilot. The Schweizer hook is well documented to be incapable of releasing the glider under certan circumstances. The Tost hook on the other hand does not seem to have these limitations. In virtually every document I have read regarding this it states, "In some towhook systems, the high pressure loading on the towhook causes towhook seizure, and the tow pilot may not be able to release the towline from the towplane. This situation can be critical if it occurs at altitudes below 500 feet above ground level (AGL). Upon losing sight of the towplane, the glider pilot must release immediately." For this reason it is beyond my ability to comprehend why Schweizer hooks are still in use. At a minimum they should be inverted and the release handle should be such that olympic level calesthenics are not necessary for actuation. My letter is nearing completion and I fully intend to submit it to the FAA. Will it cause disruption to the sport? Perhaps, but the fact is that the SSA and their assigns have demonstrated to me that they are unwilling to step forward in the name of safety and act. Like others here, I don't have any expectation that involving the FAA will have any good results, and almost certainly not net good results. Quite the opposite. If I were you, I'd send off a few dozen friendly and informative letters with your experiences and concerns addressed to "The Chief Tow Pilot" at every US gliding organisation I could find the address of. |
Walt, I understand your desire to help here, but I don't feel this is the way to help. At our club we have 3 towplanes, 2 with tost releases, and one with a Schweizer. Why not all 3, THE FAA! It would be a piece of cake to come up with an appropriate mount for a tost hook on our L-19, but the FAA makes it difficult. As others have suggested, working to make the installation of the tost hook easier, rather than trying to make it harder to use a Schweizer release, would be far more useful. It would require more effort than a letter, but would be very benifisal to the community.
Please consider an alternative course of action. RR |
![]() Quote:
The reason my letter (originally a scathing report which I have been told by a college expository writing/English composition teacher was much too long to keep the attention of the average government employee) hasn't gone in is my desire to impact the soaring public as little as possible. Believe me, had I wanted to be an ALPHA HOTEL I could have easily done so. I am not an A&P, I would think that those who are and who frequent the glider world would have a much better chance of working to make the Tost hook installation easier. Walt |
Here's a thought experiment. It's based on having read the NTSB report for every single accident and fatal accident in soaring over several decades.
Presume that the desired action here is for the FAA to ground towplanes with Schweizer hooks until such time as they are replaced. Further presume that the process will take from weeks to forever - for some towplanes where it is either cost prohibitive or where there is no FAA-approved solution. If some portion of those grounded towplanes restrict the ability of clubs or commercial operators to launch gliders for anywhere from weeks to forever, then it stands to reason, based on the relative probability of a fatality due to kiting versus the probability of a fatality flying gliders generally, that the most significant live-saving impact of this action would be from simply stopping glider pilots from flying gliders. I'm not saying if that's a good thing or a bad thing overall. Saving lives is a good thing. It's just a question of what the cost is to get there and whether the view is worth the climb. Feel free to make assertions about the probabilities. People generally are terrible at estimating the probabilities of rare events. They tend to elevate the probabilities of the risks they think they can control and underestimate the probabilities of the risks they can't control. It leads to the illusion of control - which is comforting. Andy Blackburn 9B |
You want to help save towpilots? Write articles for soaring magazine discussing towing safety(not just preaching an equipment solution.) Collect all STCs and 337s for Tost hooks for every plane that has ever towed a glider, build a webpage and put the info there. Add estimated costs of conversions and parts suppliers for the different airplanes. Once you have that info out in the world ask Tost if they'd do a group towhook discount if a bunch of US clubs purchased hooks at the same time. Then organize said group buy. If you collected the info so clubs knew that a Tost conversion cost X, info and parts came from Y, and it will take Z time to complete a lot of more them would make the switch. Or you could hide under the ruse of safety and cry to the gov't to exact revenge on the soaring community for scaring you. The only request to the FAA that would improve towing safety would be asking them to go easy on Tost hook 337s same as they do for shoulder belt installations. But this isn't about safety, no one believes that BS Walt.
from latest news letter on vulcan, hope it is of intrest to some of you if you dont get the news letter | PAUL H | Aviation Photos | 0 | January 27th 13 11:21 AM |
A LETTER OF THANKS | minimoa | Soaring | 0 | September 14th 10 12:06 AM |
Letter from TSA? | Emily | Piloting | 14 | August 14th 06 11:33 PM |
A letter to a friend... | Greasy Rider© @ invalid.com | Naval Aviation | 3 | August 23rd 05 12:23 AM |
Letter from TSA | Rosspilot | Piloting | 2 | November 20th 03 01:12 AM |
