On Saturday, June 3, 2017 at 8:34:46 AM UTC-4, Echo wrote:
I then realized that where the "ALT" is indicated on the lower right of the screen with the little airplane symbol was actually just 3 dashes instead.. This is confusing. The dashes/airplane_icon are in the UPPER LEFT of the screen. My understanding is that the airplane_icon only flashes visible when the XPNR is replying to interrogations. The 'dashes' are displayed when it is NOT being interrogated. Do you think that the airplane_icon should be displayed all the time? Why do you think that the XPDR should constantly be replying to interrogations? |
*Sigh*
I know how transponders work. No you don't get constantly pinged. Yes the plane is supposed to flash as it's being tagged by radar. No that's not what I'm talking about. I meant to say text on lower left. Do you want a photo? It displays text: SBY/GND/ON/ALT corresponding to switch position. Mine works for maybe 20 minutes, then displays dashes where the text was. Same issue with a different hesd unit and transponder in my plane today. Starting to think it's the wiring harness, more specifically the data line connecting the head unit on the panel and the box in the back. Running dual batteries, both lithium....power supply shouldn't be a factor. Antenna shouldn't make a difference to the display. Still troubleshooting. Next step is to try another harness, and check mine for breaks and bad solders. Jordan |
When I first installed my TT22 about 3 or 4 years ago, I thought
everything was OK except that it failed the test. Closely monitoring the display during startup revealed an error message displayed for such a short time that I could not read it. I cycled the unit through several power cycles reading the next word in the message each time and, when I had the full message, I contacted Trig tech support. I believe the engineer's name was Andy. Andy told me that the message indicated a problem with the wire harness so I took it apart (the end which I'd soldered on) and found one stray strand of wire which was shorting two pins. I'm not saying this is your problem, especially as you describe the temporal aspect of your indications, but it certainly couldn't hurt to have a look inside the connectors or even just ring out the harness with an ohm meter. Good luck, Dan On 6/24/2017 5:10 PM, Echo wrote: *Sigh* I know how transponders work. No you don't get constantly pinged. Yes the plane is supposed to flash as it's being tagged by radar. No that's not what I'm talking about. I meant to say text on lower left. Do you want a photo? It displays text: SBY/GND/ON/ALT corresponding to switch position. Mine works for maybe 20 minutes, then displays dashes where the text was. Same issue with a different hesd unit and transponder in my plane today. Starting to think it's the wiring harness, more specifically the data line connecting the head unit on the panel and the box in the back. Running dual batteries, both lithium...power supply shouldn't be a factor. Antenna shouldn't make a difference to the display. Still troubleshooting. Next step is to try another harness, and check mine for breaks and bad solders. Jordan -- Dan, 5J |
Today I discovered jiggling the connection between the L2 antenna and coax cable caused the issue. Made a new cable, issue appears resolved. A bit surprised since it was a Goddard cable, but works now. (I think/hope)
Jordan |
On Sunday, June 25, 2017 at 8:40:52 AM UTC-7, Dan Marotta wrote:
When I first installed my TT22 about 3 or 4 years ago, I thought everything was OK except that it failed the test. Closely monitoring the display during startup revealed an error message displayed for such a short time that I could not read it. I cycled the unit through several power cycles reading the next word in the message each time and, when I had the full message, I contacted Trig tech support. I believe the engineer's name was Andy. Andy told me that the message indicated a problem with the wire harness so I took it apart (the end which I'd soldered on) and found one stray strand of wire which was shorting two pins. I'm not saying this is your problem, especially as you describe the temporal aspect of your indications, but it certainly couldn't hurt to have a look inside the connectors or even just ring out the harness with an ohm meter. Good luck, Dan On 6/24/2017 5:10 PM, Echo wrote: *Sigh* I know how transponders work. No you don't get constantly pinged. Yes the plane is supposed to flash as it's being tagged by radar. No that's not what I'm talking about. I meant to say text on lower left. Do you want a photo? It displays text: SBY/GND/ON/ALT corresponding to switch position. Mine works for maybe 20 minutes, then displays dashes where the text was. Same issue with a different hesd unit and transponder in my plane today. Starting to think it's the wiring harness, more specifically the data line connecting the head unit on the panel and the box in the back. Running dual batteries, both lithium...power supply shouldn't be a factor. Antenna shouldn't make a difference to the display. Still troubleshooting. Next step is to try another harness, and check mine for breaks and bad solders. Jordan -- Dan, 5J The Andy you spoke with may have been the CEO and founder Andy Davis. :-) |
Now THAT's what I would call service! :-D
On 6/25/2017 10:54 PM, Darryl Ramm wrote: On Sunday, June 25, 2017 at 8:40:52 AM UTC-7, Dan Marotta wrote: When I first installed my TT22 about 3 or 4 years ago, I thought everything was OK except that it failed the test. Closely monitoring the display during startup revealed an error message displayed for such a short time that I could not read it. I cycled the unit through several power cycles reading the next word in the message each time and, when I had the full message, I contacted Trig tech support. I believe the engineer's name was Andy. Andy told me that the message indicated a problem with the wire harness so I took it apart (the end which I'd soldered on) and found one stray strand of wire which was shorting two pins. I'm not saying this is your problem, especially as you describe the temporal aspect of your indications, but it certainly couldn't hurt to have a look inside the connectors or even just ring out the harness with an ohm meter. Good luck, Dan On 6/24/2017 5:10 PM, Echo wrote: *Sigh* I know how transponders work. No you don't get constantly pinged. Yes the plane is supposed to flash as it's being tagged by radar. No that's not what I'm talking about. I meant to say text on lower left. Do you want a photo? It displays text: SBY/GND/ON/ALT corresponding to switch position. Mine works for maybe 20 minutes, then displays dashes where the text was. Same issue with a different hesd unit and transponder in my plane today. Starting to think it's the wiring harness, more specifically the data line connecting the head unit on the panel and the box in the back. Running dual batteries, both lithium...power supply shouldn't be a factor. Antenna shouldn't make a difference to the display. Still troubleshooting. Next step is to try another harness, and check mine for breaks and bad solders. Jordan -- Dan, 5J The Andy you spoke with may have been the CEO and founder Andy Davis. :-) -- Dan, 5J |
Trig TT21 Transponder ... reports? | Grider Pirate | Soaring | 105 | March 29th 18 01:10 AM |
Trig transponder | [email protected] | Soaring | 0 | April 14th 16 03:30 AM |
Garmin GPS 20A with Trig TT22 in Experimental Glider - OK? | Paul Remde | Soaring | 35 | December 21st 15 05:17 AM |
Transponder TT21 versus TT22 - Considerations | WaltWX[_2_] | Soaring | 16 | January 23rd 15 06:01 PM |
New Trig TT22 Transponder | Paul Remde | Soaring | 1 | January 14th 10 07:27 PM |
