Anyone get hassled for exceeding max car and trailer length?
Old June 26th 17, 09:35 AM posted to rec.aviation.soaring
Duster[_2_]
Default Anyone get hassled for exceeding max car and trailer length?
Though several references state the Oregon limit is well beyond your 60' combo, I think you meant you'd be 10' over a 50' max (not 10")? Nevertheless, some references have it as a 65' max, with some selected highways 60', 50' or shorter. As for Mr. Kelly driving well over most state's combo limit for many years and getting away with it. Have you thought about the risk you put on some sleeping baby's life or yours if you were to jackknife? Are you sure your insurance company will pay physical/medical claims when the forensic police report discovers you were pulling a 73' rig? Good thing the adjusters are too dumb to perform a simple internet search to evidence your public boasting here in social media!
Old June 26th 17, 11:58 AM posted to rec.aviation.soaring
Tim Newport-Peace[_4_]
co=
Nevertheless,=
50'=
fo=
you
you=
fore=
adj=
pu=
In UK we are fortunate in having one law for the whole country!
And regardless of any UK national limit on length, Glider Trailers come
under an exemption as a "Normally Indivisible Load".
Old June 26th 17, 01:30 PM posted to rec.aviation.soaring
Bruce Hoult
co=
Nevertheless,=
50'=
fo=
you
you=
fore=
adj=
pu=
I hope you give the required two days notice to the police each time you use it :-)
Old June 26th 17, 02:29 PM posted to rec.aviation.soaring
Tom Kelley #711
Registered Florida. Federal laws allow travel, but not on all state highways/roads.
Florida Length:
48′ trailer (53′ semi-trailer must have kingpin setting of 41′ from center of kingpin to center of rear axle to be legal)
75′ overall length.
1500 pound trailer jackknifing a 35,000 pound motor home. Now really, LMAO!
Already been discussed with insurance. Not only one doing this.
Best. Tom #711.
Old July 20th 17, 02:03 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Duster wrote on 6/26/2017 1:35 AM:
Motorhomes are far more stable towing a glider trailer than any SUV or car. Even a
small one like I have - 25' long, 13,500lbs - totally controls the situation, and
my 2500' lb, 34' glider trailer is unnoticeable behind it. Often, the motorhome
driver's first hint there is a big problem with the trailer is an excited motorist
driving alongside him, pointing wildly to the rear!
I've dealt with the situation by adding a tire pressure monitoring system to my
motorhome. It monitors the 6 tires on the motorhome and the 2 on the trailer.
My motorhome and trailer are 59' long, which is, I believe, legal in every state.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old July 21st 17, 03:47 PM posted to rec.aviation.soaring
Eric, which TPMS are you using? Any particular problems with the trailer tires?
Chip Bearden
ASW 24 "JB"
Old July 21st 17, 04:21 PM posted to rec.aviation.soaring
Craig Funston
Chip Bearden
ASW 24 "JB"
Chip,
I know the question was for Eric, but I'll chime in anyways. After losing an inside dual and also setting at trailer tire on fire on the way to Nephi several years ago I invested in a TPMS.
Ended up going with the EEZRV TPMS and a variety of stem mounted sensors. It's working well on a 28' RV with an open class trailer behind it. The stem mounted sensors do mean that re-balancing the tires is a good idea after they're installed.
Craig Funston 7Q
Old July 21st 17, 05:53 PM posted to rec.aviation.soaring
Thanks, Craig! The EEZRV is the one I was investigating. I don't have an RV but I've had tires go flat on my trailers behind a van. Often you can feel it, even see it if you're watching the rear view mirror closely. But at night, wind, passing trucks, and twisty roads can mask it until you've done rim damage. Curious to know who else uses this technology for glider trailers.
Chip Bearden
ASW 24 "JB"
best tow rope length Morris Carter Soaring 7 November 4th 16 01:59 PM
Total length of 15m Cobra trailer (ft)? Sean Fidler Soaring 4 August 17th 14 02:58 PM
Does exceeding manufacturers' tow rating void collision liability insurance? son_of_flubber Soaring 4 September 10th 12 08:15 PM
exceeding TBO on Continental 0200-A Marty from Sunny Florida Owning 9 June 11th 04 08:11 AM
F-104 Zero Length Launch Bjørnar Bolsøy Military Aviation 0 January 4th 04 11:40 PM
