On Saturday, July 8, 2017 at 6:23:42 AM UTC-5, Werner Schmidt wrote:
Hello Ueda you also may consider a complete different engine. Our club in northern Germany uses a tost winch, too and in the 1980ies fitted a Mercedes Benz 330 HP Turbo-Diesel truck engine which works fine up to now. No Gearbox required, just the torque converter between engine and drive shaft. You may have to change the gear transmission ratio to adapt it to the different revolution speed range and do some more minor changes. I could help with construction schemes - hope I have found the correct terms, my english is somewhat poor :-/ regards Werner Werner, We got a similar (identical?) Benz Diesel in the mid-80's together with a modified axle from their test shop for free (Luftsportverein Hameln/Bisperode). The engine and axle still are still in great shape. Not an option for us here in the US and for sure not in Japan. Herbert, J7 |
Is OLC Broken Again? | Dan Marotta | Soaring | 16 | May 9th 17 05:37 PM |
Best winch metrics - what is the best winch operationally? | Bruce | Soaring | 19 | July 19th 09 11:45 AM |
uk Argosy broken up | BILL | Aviation Photos | 2 | May 1st 07 07:51 PM |
OLC broken ? | Limus | Soaring | 35 | April 2nd 07 12:43 AM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
