Export CofA in Germany is a days work. Certificate of deregistration can be
arranged from the LBA in a week. Been there, done that. Have the current owner do it as part of the deal. Saves hassle. |
At 05:48 18 July 2017, Eric Munk wrote:
Export CofA in Germany is a days work. Certificate of deregistration can b arranged from the LBA in a week. Been there, done that. Have the current owner do it as part of the deal. Saves hassle. Hello, I'm a EASA-FAA engineer & have worked on the G109B-Grob 2500 engine for the last two years. If you want to replace the engine with a EASA/FAA compliant unit, the only company presently advertising an overhauled engine from the factory is Soaring Oxford in the U.K. Please find link below. http://www.segelflug.de/osclass/inde...=item&id=16512 The company normally supplies spares to the RAF cadets flying schools, which no longer require the engines having "Scrapped" the majority of their fleet, hence an abundance of spares no longer required held by Soaring Oxford. The company is expensive, having dealt primarily with the RAF cadets & not having to "trim" their profit margins. I'm sure a discount is available if you play "Hard Ball". Good luck. Best regards Paul |
Grob 109B Vector Diagram | Go Soaring | Soaring | 0 | March 23rd 15 03:26 PM |
Wanted Grob 109B | Nick Kennedy | Soaring | 4 | November 12th 14 12:36 AM |
Exporting a glider to/import a glider into Germany | Pete Smith[_2_] | Soaring | 1 | August 8th 08 09:33 AM |
import | Hugh Newbery | Soaring | 1 | June 8th 08 01:44 PM |
Are "Popups" A Hassle? | skym | Instrument Flight Rules | 45 | November 10th 05 06:23 PM |
