thermal wave
Old July 23rd 17, 06:45 PM posted to rec.aviation.soaring
firsys
Default thermal wave
Yesterday, close to my home field, after I had given up( 2500 ft cloudbase)
I noticed lennie like clouds lining up across the light NW wind.
I have flown thermal wave often in the past, but nothing in the last ten years.
Missed this one but probably too weak to use.
These systems can difficult to get into but extensive and rewarding if you can do it.
Has anyone any idea of the met conditions for development of T.W?
Here are a couple:
Weak convection in the lower layer with light winds.
An upper wind of 15+ kts above an inversion, rising with height.
But there must be something else or I would see this more frequently.
John Firth
Ottawa
Old July 23rd 17, 07:32 PM posted to rec.aviation.soaring
krasw
Here are a couple:
John Firth
Ottawa
They are pretty common everywhere in flatlands but obviously hard to spot as wave is almost always above cloudbase level and often weak. Wave occurs in stable atmosphere, so inversion above convective layer is common, preferable with strong wind shear. Approaching fronts usually create wave patterns..
Old July 23rd 17, 08:15 PM posted to rec.aviation.soaring
Duster[_2_]
Pileus clouds are cap-like clouds that can be used to identify thermal wave.. Good convection apparently acts like orographic barrier, wind shear hits it, forced up and moisture condences. Climb is on windward side of cumulus, from my limited experience. The Pileus often don't last very long, though the lift may still be there.
https://www.youtube.com/watch?v=mGM7kJQr0RA
https://www.youtube.com/watch?v=3eHKYWMvmWE
Old July 23rd 17, 09:41 PM posted to rec.aviation.soaring
Dave Nadler
Hi John! Sure...
ten years. Missed this one but probably too weak to use.
if you can do it.
Here are a couple:
No, doesn't have to be weak.
More important is a change in direction at the top and above
the convective layer.
It is actually very common, but much easier to see from above.
In eastern North America, especially near frontal passages (because of wind
rotation). I've flown in thermal wave often in New England and also flat terrain
in Florida, Texas, South Carolina, a few Australian sites, etc.
See for example: http://www.ssa.org/Contests?show=blog&id=4169
https://www.onlinecontest.org/olc-2....Id=-1131309345
Fun stuff!
Best Regards, Dave
Old July 23rd 17, 10:54 PM posted to rec.aviation.soaring
firsys
Here are a couple:
John Firth
Ottawa
PS In the last ten years or so, here in E Ontario, it has not been common, or even frequent as it was in the 70s and 80s; I have been looking to fly any day since 2008 and think I would have noticed.
(BTW I published a paper in the OSTIV journal reporting a flight to 16000
ft after a low level struggle in weak convection; I think it was presented at the 1978 meeting at Chateauroux)
Old July 23rd 17, 11:42 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
wave. Good convection apparently acts like orographic barrier, wind
I didn't know the name until now, but I remember some years ago coming
off the Channel car ferry at Calais and heading for Hungary. This took us
through Lille and across Belgium into Germany at Aachen. All the way
across Belgium there were really good-looking Cu with Pileus caps on the
northerly slopes of most of them with bright sun on the ground and a
decent northerly blow, so good, unstable, thermally lower atmosphere. I
remember thinking that this would have a been a great day to have taken
an early launch in southern England to cross the Channel and see how far
into France or Germany you could get.
The trick seems to be to leave the English coast high enough to get to
France with enough height move away from the coast and into the first
thermal region. Still, you may get lucky on the way. I remember reading
that Philip Wills was lucky enough to drift most of the way across in
what sounds like some sort of self-recycling lift bubble before leaving
as it decayed and finally landing at St.Omer, 30km from the coast, as the
day died.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old July 24th 17, 12:25 PM posted to rec.aviation.soaring
Here are a couple:
John Firth
Ottawa
Back in the early 80's my friend Bennie Flowers and I flew a Florida wave on three different occasions. The wave took us well offshore south of Miami and we could have easily landed in the Bahamas. There was an article written for Soaring Magazine which depicted photos of the clouds. Since that time I have seem that same type cloud formation only a couple of times. As I recall the cloud base was about 2500 feet and we flew between the row of clouds and started going up like a homesick angel. Wish I could find those same conditions again. Bob
Old July 24th 17, 12:49 PM posted to rec.aviation.soaring
One needs to differentiate between thermal waves and ridge lift induced by thermals.
Real thermal waves are actually quite rare, at least here in the German flat lands. They require a significant wind-shear in direction and strength above the inversion layer. Cloud-streets lining-up 90° to the actual wind direction below inversion are an indicator of such thermal waves. These are real waves that bring you way above the convection layer. There were reports of altitudes 4000m AGL (cloud base at 2000m).
Climbing in front of a Cu like in front of a ridge happens quite often. All it needs is a wind increase above the condensation level. The lift in most cases is not very strong and brings you a few hundred metres above cloud base level. I had one occasion earlier this year that brought me to the Cu-top, some 800m above cloud base.
Old July 25th 17, 09:49 PM posted to rec.aviation.soaring
danlj
John Firth
Ottawa
Here's the link to the talk I gave at OSTIV in January...
http://www.danlj.org/~danlj/Soaring/...ver-plains.pdf
Dan Johnson
Please send me logs, stories of flying in thermal wave over the plains danlj Soaring 8 November 16th 15 03:33 PM
Thermal Forcasting -Thermal index gldrgidr Soaring 6 November 27th 10 10:26 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
Marfa 2004 Spring Thermal & Wave Camp Report Dick Johnson Soaring 0 April 13th 04 02:19 AM
Thermal to Wave contact! C.Fleming Soaring 1 January 21st 04 01:54 PM
