glue to rebond rubber tailskid to LS6
Old July 26th 17, 02:12 PM posted to rec.aviation.soaring
Default glue to rebond rubber tailskid to LS6
On Tuesday, July 25, 2017 at 9:40:51 PM UTC-4, Bob Kuykendall wrote:
On Monday, July 24, 2017 at 10:22:43 AM UTC-7, JS wrote:
Consider cutting a hole in the bottom of the tail (discovering that there is already a wheel well in the LS6) and installing a tail wheel...
If your LS6 is Experimental, I have a fender and external fairing that fits if it turns out that it isn't already in there.
--Bob K.
The inner fender is part of LS-6 aft construction, even when skid is installed, based on the one I worked on. It would require the factory drawing to duplicate the mounting of the axle bolt.
FWIW
UH
Looking for Wedekind sleeves and tailskid with wheel... [email protected] Soaring 6 January 30th 15 02:42 AM
Keep the rubber side down! Waveguru Soaring 1 September 24th 12 04:57 AM
Gluing rubber pieces [email protected] Home Built 16 June 2nd 09 05:32 AM
Rubber stamp??? Tri-Pacer Owning 13 January 28th 06 07:04 PM
Rubber Stamp ??? Tri-Pacer Home Built 7 January 26th 06 01:34 PM
