![]() You have a fundamental misunderstanding about solar power: they don't generate heat, they consume solar radiation (which reduces heat, much like a body of water). They do generate heat, not reduce it. From the lay literature, the efficiency of solar panels is 12-20%, while the theoretical limit is just over 30%. New advancements may beat those numbers. Maybe the glass panels act as insulators, but the heat is radiated back somewhere. Also, bodies of water and suspended particles absorb light and are heated by it; water doesn't reduce heat. |
Thermal Forcasting -Thermal index | gldrgidr | Soaring | 6 | November 27th 10 10:26 PM |
Byron Airport's Proposed House Thermal | sisu1a | Soaring | 8 | August 7th 10 04:22 PM |
Where is the next thermal? | danlj | Soaring | 36 | September 28th 09 12:12 AM |
Which Way is That Thermal? | ContestID67 | Soaring | 26 | September 9th 06 08:30 PM |
Thermal Data Files Thermal Mapping Project Australia | Mal | Soaring | 0 | December 2nd 05 11:14 PM |
