FES vs Gas Engine – Finding a Thermal?
Old August 25th 17, 12:54 AM posted to rec.aviation.soaring
Dan Marotta
Default FES vs Gas Engine – Finding a Thermal?
It's pretty easy in the Stemme with the triple probe mounted to the
front of the nose cone, in front of the propeller.* All the soaring
instruments work as designed without interference from the prop. BTW,
the Stemme (used) costs less than the Arcus AND you can take a friend! :-D
On 8/24/2017 2:28 PM, V1 wrote:
While reading the FES article in June Soaring (yes, I’m behind in my reading), I noticed the author’s comment about searching for a thermal while FES was running, then shutting down FES as he started to climb. This is a topic I don’t recall seeing discussed in any FES vs gas comparisons.
In my Solo-powered Ventus 2cxT, my experience has been that the vibration (and possibly disturbed airflow) caused so much wild gyration in the vario readings that it seemed pointless to try to determine if I was flying into rising air, so I just climbed first, then shut down the engine and started a thermal search.
My question – do others have experience to share about their ability to find thermals while a sustainer or self-launcher (either gas or electric) was running? If electric has an advantage here, this could reduce the run-time needed and conserve “fuel”.
- Frank
Dan, 5J
Need help finding someone. Tim Murphy Soaring 0 March 12th 12 04:15 PM
Thermal Forcasting -Thermal index gldrgidr Soaring 6 November 27th 10 10:26 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
Finding a partnership Greg Owning 11 November 10th 03 08:40 PM
Help finding photo Chris W Piloting 11 July 29th 03 04:07 PM
