![]() Why not run a yotaphone? E-ink on one side... Yes, and LCD on the other. I tried to get my Nook to run TopHat and have had zero luck. It is not possible withouot taking it apart and doing some soldering.Even then you have to have a serial output GPS. Newer USB output GPS will not work. I was lucky enough to test fly a Yodaphone (not sure about the spelling) and it worked well. However last time I searched for them online they were not sold in the USA. Probably because they are made in Russia... might include spyware at no extra charge :-) |
On Friday, September 15, 2017 at 4:13:44 PM UTC-4, Soartech wrote:
... I tried to get my Nook to run TopHat and have had zero luck. ... I've used a Nook for several years now. You do need to "root" the Nook (jailbreak the OS). Instructions are on the Tophat website. Once I've created the needed special memory card I've re-used it to root several Nooks easily enough. For me and for other club members. If you want I can do it for you too. I've used two ways to get around the Nook not having a built-in GPS. One does not need soldering and uses cheap off-the-shelf components: a USB GPS "puck" and an OTG Y-cable (to which external 5V power also connects). It works reasonably well, although sometimes it froze up in mid-flight and I had to restart the Nook, which meant a split flight log. I suggested to the main developer to allow continuing the same log file after a crash and restart, and that is supposedly done now, although I havn't used that feature because I meanwhile switched to a different solution: I did solder a serial GPS to the Nook's motherboard. Not for the faint of heart... But it does work very well once done. A third way is via an "IOIO box" but that seems overkill to me. A Yotaphone sounds neat, but it's hard to get one. Used Nooks are (still) plentiful and cheap, and I like the bigger screen. For a slightly smaller e-ink screen (good in tight cockpits) some people use a "Kobo Mini" e-reader. |
On Friday, September 15, 2017 at 4:40:52 PM UTC-4, wrote:
On Friday, September 15, 2017 at 4:13:44 PM UTC-4, Soartech wrote: ... I tried to get my Nook to run TopHat and have had zero luck. ... I've used a Nook for several years now. You do need to "root" the Nook (jailbreak the OS). Instructions are on the Tophat website. Once I've created the needed special memory card I've re-used it to root several Nooks easily enough. For me and for other club members. If you want I can do it for you too. I've used two ways to get around the Nook not having a built-in GPS. One does not need soldering and uses cheap off-the-shelf components: a USB GPS "puck" and an OTG Y-cable (to which external 5V power also connects). It works reasonably well, although sometimes it froze up in mid-flight and I had to restart the Nook, which meant a split flight log. I suggested to the main developer to allow continuing the same log file after a crash and restart, and that is supposedly done now, although I havn't used that feature because I meanwhile switched to a different solution: I did solder a serial GPS to the Nook's motherboard. Not for the faint of heart... But it does work very well once done. A third way is via an "IOIO box" but that seems overkill to me. A Yotaphone sounds neat, but it's hard to get one. Used Nooks are (still) plentiful and cheap, and I like the bigger screen. For a slightly smaller e-ink screen (good in tight cockpits) some people use a "Kobo Mini" e-reader. http://tophatsoaring.org/Kobo.html An available solution is http://goflyinstruments.com/ . I have a V4. 20 hr battery, GPS, pressure sensor all in one package. Not inexpensive, but it works on a Kobo Mini. They're up to V6 now. Well thought out. I started with the Y-cable but found it messy. All in one is nice - when I fly club duals I use it with a kneeboard. |
On Saturday, September 16, 2017 at 8:13:44 AM UTC+12, Soartech wrote:
Why not run a yotaphone? E-ink on one side... Yes, and LCD on the other. I tried to get my Nook to run TopHat and have had zero luck. It is not possible withouot taking it apart and doing some soldering.Even then you have to have a serial output GPS. Newer USB output GPS will not work. I was lucky enough to test fly a Yodaphone (not sure about the spelling) and it worked well. However last time I searched for them online they were not sold in the USA. Probably because they are made in Russia... might include spyware at no extra charge :-) I've been using an Android based e-reader for a few seasons now. XCSoar runs on it nicely, standard install, nothing fancy. Just upgraded to a faster display that reduces the flashing on refresh. Using a Boox e-reader from Onyx. 6 inch e-ink display. I got mine from Banggood.com. Connecting to Flarm using an ioio adapter and the UART interface kit from Soartronics. Works great and very reliable. |
FS: Oudie 2 w/ sunlight readable screen & accessories | CJ[_3_] | Soaring | 1 | June 11th 14 10:26 PM |
GliderGuider - Sunlight Readable PDA | Allan Arthurs | Soaring | 1 | September 23rd 12 01:57 PM |
Sunlight readable Oudie - get yours upgraded! | Andrej Kolar[_4_] | Soaring | 36 | March 10th 12 07:42 PM |
BriteNav 5" Sunlight Readable PNA for Soaring. | Andrzej Kobus | Soaring | 1 | February 29th 12 03:04 PM |
Sunlight readable PNAs reviewed | PCool | Soaring | 6 | January 8th 12 02:10 AM |
