Fligth Time Calculator
Old September 17th 17, 03:58 AM posted to rec.aviation.soaring
Tom Kelley #711
Default Fligth Time Calculator
On Saturday, September 16, 2017 at 8:32:55 PM UTC-6, 2G wrote:
I has always worked for me. Post a link to a flight that was miscalculated.
Tom
Tony is right. The OLC flight book shows not only when the recorder is first turned on and but when it is finally turned off. Check your flight with SeeYou, you will see. All of my flights on the OLC flight book show when the logger is first powered and are at least 15 to 20 minutes longer when I am on the ground, out of the glider and starting to clean and download the flight before I turn off battery power to the logger's off.
At least that's how my OLC flight book works.
Best. Tom #711.
Old September 17th 17, 04:02 AM posted to rec.aviation.soaring
JD Williams
The olc detail page has the correct flight time info, but the logbook does not. I use 3 min increments and go digital but .05. Much easier.
JD
Old September 17th 17, 03:50 PM posted to rec.aviation.soaring
Dan Marotta
And you log flight time while you're cleaning the bugs off the wings???
Good thing the chicks andÂ* money aren't calculated based upon flight time...
Since my Air Force days, I've always logged flight time using tenths of
hours.Â* Works well enough for me (and the chicks).
Tom
Best. Tom #711.
Dan, 5J
J.S.W Calculator--K35 Dave White Soaring 2 February 1st 11 03:15 PM
density altitude calculator and wind calculator on web site and asGoogle gadget Howie Piloting 3 August 5th 07 11:52 PM
density altitude calculator and wind calculator on web site and asGoogle gadget virtuPIC[_2_] General Aviation 0 August 4th 07 05:55 PM
Calculator Phoebus_810 Soaring 0 January 8th 05 04:36 PM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
