sunlight readable iphone
Old September 20th 17, 06:43 PM posted to rec.aviation.soaring
Default sunlight readable iphone
I run Top Hat on a Kobo e-reader; i.e., gray scale. Very legible. As good as my old Compaq Aero but a much larger display.
I also have a Dell Streak 5 in the pocket as a backup, which I was forced to go to at Cordele this summer when the Kobo stopped getting GPS data from my PowerFLARM. I much prefer the color (Dell)...but it's not nearly as readable. It's "good enough". So if I could get a more readable color display at comparable or even moderately higher cost, I'd go with that.
I like having a completely independent backup, though (self contained battery, GPS, CPU, display), so I'll probably keep the Dell Streak in the cockpit for a long time.
Chip Bearden
Old September 20th 17, 10:44 PM posted to rec.aviation.soaring
I am something of a collector of these things. I have an LX9000 in the panel, and fly with an Oudie IGC running standalone as an additional display. The PF feeds traffic to the LX and to a Butterfly.
When in another glider I use the Oudie IGC - fully standalone, an IGC logger, what I consider to be a great interface (if you invest the time to know it and to set it up), and with a big internal battery. I think it is the gold standard in standalone devices, and has significant advantages over the expensive dedicated devices such as LX, Zeus, Clearnav and Air Avionics.
I also own an S8 on which I have XC Soar and Skydemon - also Tophat but I prefer XC Soar. I changed from iOs to get Oudie Live and XC Soar. I carry it in the pocket of the glider but have never had to turn it on. When flying power I use Skydemon on the S8.
I also own a Kobo Glo HD with Bluefly vario/GPS bought from http://gethighstayhigh.co.uk/
running XC Soar. I don't use it. IMO the benefits of colour and a phone touchscreen make the S8 a better device for XC Soar than the bigger and superb in sunlight eink device.
All these devices are fine for sunlight readability IMO, unlike earlier generations. Early monochrome iPaqs were good (I used Winpilot) but from the time colour came in until the Oudie 2 sunlight readability was a real issue. On these devices it isn't.
Old September 21st 17, 01:19 AM posted to rec.aviation.soaring
jfitch
Just goes to show what different people prefer. I consider the Oudie/SYM UI to be awful. I tried to like it but cannot. In my opinion, XCSoar is slightly better, Winpilot was clearly superior, and iGlide is far superior. iGlide on an iPhone 6 or later (with built in barograph) makes a very good stand alone tactical flight computer. It lacks the IGC legal recorder in the Oudie IGC though.
Old September 21st 17, 02:32 AM posted to rec.aviation.soaring
6PK
When in another glider I use the Oudie IGC - fully standalone, an IGC logger, what I consider to be a great interface (if you invest the time to know it and to set it up), and with a big internal battery. I think it is the gold standard in standalone devices, and has significant advantages over the expensive dedicated devices such as LX, Zeus, Clearnav and Air Avionics..
I would agree with most but how is iGlide far superior? Forgive my ignorance please.....
Old September 21st 17, 06:11 AM posted to rec.aviation.soaring
jfitch
I did say "in my opinion" and opinions may differ. It will be difficult to explain why, unless you have tried all of these offerings for yourself. I own them all, own the hardware, have the interfaces installed in the glider and on any day could run any of them. Broadly speaking, configuration, task entry, task editing, zooming, and panning are much quicker, and less verbose. I credit part of this to the hundreds of millions of dollars of development that has been sunk into general smartphone UI, with all the hooks necessary to take advantage of it available for free to the developer. Window CE has not had any development done on it for many years now (predating smartphones). XCSoar using Android in theory could take advantage but they are handicapped by needing to make the code and UI work across a very wide variety of OS and hardware, this is always a compromise. I credit the remaining to the developers who looked at the problem with a modern view, rather than one rooted in Windows 3.1/CE UI which dates from the last century. iGlide was designed from the beginning around a modern smartphone interface, while SYM and XCSoar have tried to adapt grudgingly to it. Winpilot made the jump more properly, but the iOS version has never really been finished.
Sadly, Air Avionics have done themselves a huge disservice by not providing a free demo mode app which I believe would result in much wider deployment, given that all their competition does so.
Old September 21st 17, 08:05 AM posted to rec.aviation.soaring
waremark
"Broadly speaking, configuration, task entry, task editing, zooming, and panning are much quicker, and less verbose."
I would quote those points as reasons for preferring SYM! The biggest benefit being the total flexibility on the configuration of the map pages. I find it better than XCS in all those ways except panning which is equally easy in all touchscreen software.
When I bought iglide lite I didn't like the interface and the screen wasn't bright enough. I have never tried the full version on a recent iPhone. No-one at my club uses it.
Old September 21st 17, 08:18 AM posted to rec.aviation.soaring
Ian[_2_]
been finished.
Have you tried TopHat? Basically XCSoar with a rationalised UI. I don't
know if it works on old Windows CE devices but I find it much more
intuitive on my Dell Streak than native XCSoar.
There are also versions patched for use on black and white e-Ink displays.
Old September 21st 17, 04:55 PM posted to rec.aviation.soaring
jfitch
been finished.
There are also versions patched for use on black and white e-Ink displays..
I do not own a Tophat version, though I have had it demonstrated to me by someone who uses it and likes it. It did seem to improve on the XCSoar base.
Since the Lite version of iGlide does not support routes, it is impossible to compare task creation and editing in it to SYM or XCSoar. What iGlide needs to do is publish a full Pro version, enabled in demo mode only, for free. Then it could be compared to the others by anyone without risk.
Currently (for me) I rank them in usability:
iGlide
XCSoar
SYM
Winpilot iOS (crashes too often to use)
Ranked in value, its hard to overcome the fact that XCSoar is free:
XCSoar
iGlide
SYM
But the software is such a minuscule cost in soaring - compared to the rest of it - that I discount that. I spend more on oxygen each soaring season than iGlide cost.
Old September 21st 17, 03:25 PM posted to rec.aviation.soaring
6PK
Just goes to show what different people prefer. I consider the Oudie/SYM UI to be awful. I tried to like it but cannot. In my opinion, XCSoar is slightly better, Winpilot was clearly superior, and iGlide is far superior.. iGlide on an iPhone 6 or later (with built in barograph) makes a very good stand alone tactical flight computer. It lacks the IGC legal recorder in the Oudie IGC though.
I appreciate the reply, there was no pun intended, simply was curious as the one system I have not tried is iGlide.
I happen to agree with Ian; I prefer TopHat over XCsoar, I find somewhat more user friendly. Mine runs on a Kobo Glo (grayscale), works very well... it would be revolutional if only a little color:-)
JS[_5_]
Fahr-Kinell, "ma"!
You win tonight's star prize... this fabulous LOUNGE SUITE!
(music, canned applause)
zoom to attractive girl, waving arm at settee
FS: Oudie 2 w/ sunlight readable screen & accessories CJ[_3_] Soaring 1 June 11th 14 10:26 PM
GliderGuider - Sunlight Readable PDA Allan Arthurs Soaring 1 September 23rd 12 01:57 PM
Sunlight readable Oudie - get yours upgraded! Andrej Kolar[_4_] Soaring 36 March 10th 12 07:42 PM
BriteNav 5" Sunlight Readable PNA for Soaring. Andrzej Kobus Soaring 1 February 29th 12 03:04 PM
Sunlight readable PNAs reviewed PCool Soaring 6 January 8th 12 02:10 AM
