ADSB visibility with non certified GPS
Old September 22nd 17, 03:31 AM posted to rec.aviation.soaring
Darryl Ramm
Default ADSB visibility with non certified GPS
Walt, I think you are misunderstanding what Trig wrote. A TN72 GPS Source will be seen by everybody. That is why anybody doing ADS-B Out in an experimental glider with a TT22 should be equipping with at least a TN72 (or TN70, TN70 required for certified gliders).
Old September 22nd 17, 05:11 PM posted to rec.aviation.soaring
Dan Marotta
This is very confusing.Â* So a TN72 is not a TSO device, but is compliant
and therefore can be mounted in an experimental aircraft which will be
seen by all compliant ADS-B In systems?Â* I feel cheated by having a
certificated aircraft!
Dan, 5J
Old September 22nd 17, 07:38 PM posted to rec.aviation.soaring
Darryl Ramm
Dan, 5J
You, and everybody else will continue to be confused if you keep talking about "TSO" and not specifying what TSO you are talking about. This caused lot of unneeded confusion and many posts on r.a.s. when the TN72 was announced. I don't know how many times I;ve already pointed this out.
The TN72 is a TSO-C199 Class B (aka TABS GPS source) device. Which from a regulation point of view makes no difference, since there are no installation or usage regulations that cover TSO-C199 devices. But since it is TSO-C199 we know important things about it's GPS quality, SIL parsameters, etc. and how it will interact with IFR GPS receivers and ground infrastructure.
The TN72 is Not TSO-C145 (requited for ADS-B Out in certified aircraft)
The TN72 does not meet TSO-C145 requirements (so can't be used for ADS-B Out in experimental aircraft where you want to us it to meet 2020 carriage requirements, in the case of gliders can't be used to meet requirements in the few areas where exemptions don't cover).
But yes I agree on the "feeling cheated" part in general, it points out the regulations are kinda stupid, especially when applied to gliders.
Old September 22nd 17, 07:48 PM posted to rec.aviation.soaring
John Carlyle
Darryl,
You said "The TN72 does not meet TSO-C145 requirements (so can't be used for ADS-B Out in experimental aircraft where you want to use it to meet 2020 carriage requirements, in the case of gliders can't be used to meet requirements in the few areas where exemptions don't cover)."
For those of us who cannot keep up, would you kindly list the requirements where the exemptions don't cover?
Many thanks!
-John
Old September 22nd 17, 08:01 PM posted to rec.aviation.soaring
Darryl Ramm
On Friday, September 22, 2017 at 11:48:33 AM UTC-7, John Carlyle wrote:
Darryl,
Many thanks!
-John
John
Start thinking more like a lawyer. Since gliders have broad ADS-B Out carriage exemptions in the areas those exemptions apply they remove the need for you to have ADS-B Out so by definition there is no requirements specific to *those areas* that apply.
The regulatory issue is if you have a certified aircraft, regardless of where you intend to or actually fly it the install and equipment has to meet 2020 carriage mandate requirements. That brings in the requirements for a TSO-C145 GPS source (e.g. a TN70 not TN72), and other things like excludes using a Trig TT-21.
Darryl
Old September 22nd 17, 08:20 PM posted to rec.aviation.soaring
Darryl Ramm
Darryl,
Many thanks!
-John
John
Darryl
14CFR 91.225 makes it mostly clear. Except I am hesitant to quote it again became it may yet again lead to lots of 10,000' confusion (just knock it off, gliders can operate above 10,000' without ADS-B Out).
But basically in a glider you can't fly without a compliant ADS-B out system in
Class B or C airspace, and
Anywhere below that top of Class B or Class C airspace or 10,000 feet MSL above that airspace, whichever is lower. Folks need to watch this, no clipping under or over (unless you are over 10,000' and above the airspace) corners of class B or C airspace.
This is the same as transponder requirements and you should really not be in those areas today without a transponder. Folks who fly gliders near controlled airspace should think about this.
And in all it's regulatory glory.... (yes OK gliders also need ADS-B Out in the Gulf of Mexico ADS-B surveillance area, if you out there in a sailplane you may have more problems than ADS-B Out compliance. But hey fly across the coastline in that area without a complaint ADS-B Out and you are violating 14CFR 91.225).
14CFR 91.225
(d) After January 1, 2020, and unless otherwise authorized by ATC, no person may operate an aircraft in the following airspace unless the aircraft has equipment installed that meets the requirements in paragraph (b) of this section:
(1) Class B and Class C airspace areas;
(2) Except as provided for in paragraph (e) of this section, within 30 nautical miles of an airport listed in appendix D, section 1 to this part from the surface upward to 10,000 feet MSL;
(3) Above the ceiling and within the lateral boundaries of a Class B or Class C airspace area designated for an airport upward to 10,000 feet MSL;
(4) Except as provided in paragraph (e) of this section, Class E airspace within the 48 contiguous states and the District of Columbia at and above 10,000 feet MSL, excluding the airspace at and below 2,500 feet above the surface; and
(5) Class E airspace at and above 3,000 feet MSL over the Gulf of Mexico from the coastline of the United States out to 12 nautical miles.
(e) The requirements of paragraph (b) of this section do not apply to any aircraft that was not originally certificated with an electrical system, or that has not subsequently been certified with such a system installed, including balloons and gliders. These aircraft may conduct operations without ADS-B Out in the airspace specified in paragraphs (d)(2) and (d)(4) of this section. Operations authorized by this section must be conducted -
(1) Outside any Class B or Class C airspace area; and
(2) Below the altitude of the ceiling of a Class B or Class C airspace area designated for an airport, or 10,000 feet MSL, whichever is lower.
Old September 22nd 17, 09:21 PM posted to rec.aviation.soaring
John Carlyle
Oh, Darryl - think like a lawyer? Can't - I'm a physicist, legal thinking "does not compute".
Many thanks for explaining, and then explaining even more in subsequent posts. Me and my experimental glider are going with a Trig TT22 and a TN 72...
-John
On Friday, September 22, 2017 at 3:01:13 PM UTC-4, Darryl Ramm wrote:
John
Darryl
Old September 25th 17, 04:30 PM posted to rec.aviation.soaring
- yeah, after all these years I still cannot make any sense of the wording "any aircraft that was not originally certificated with an electrical system, or that has not subsequently been certified with such a system installed". Had it said "nor" instead of "or", perhaps? (I do have a degree in physics.)
Old September 22nd 17, 09:30 PM posted to rec.aviation.soaring
Dan Marotta
Thanks for your patience.
Dan, 5J
Dan, 5J
Old September 24th 17, 07:59 PM posted to rec.aviation.soaring
WaltWX[_2_]
Darryl,
OK, I'm clear now that a TN72 GPS Source from a Trig T22 will make me officially visible to all ADS-B in equipped aircraft.
I am still trying to figure out why I would want to equip with any kind of ADS-B out in my T22 equipped glider:
1) It would be great (but not necessary) to be seen by all ADS-B equipped aircraft. But, with ADS-R (rebroadcast) won't those other aircraft see me anyway since I'm equipped with a Mode-S Trig transponder? I suppose at low altitude where ADS-R is not available, direct receipt of my ADS-B out would be an advantage.
2) It sounds like with the TN72 GPS source, I will not be compliant if wanting to enter Class B, C, and a few other little used airspace. My question is this... If equipped with a TN72 GPS source, do you think that ATC will allow temporary access to Class B and C... such a for passing through their airspace? That was ONE reason for equipping with a transponder in the past.. I have no intention of OPERATING in Class B and C so as to use full ATC services. Also, do you think that controllers for restricted airspace MIGHT allow transiting that airspace without fully compliant ADS-B out?
If ATC uniformly will disallow temporary transiting of Class B, C and restricted airspace unless equipping with a fully compliant GPS source (i.e. TN70), then there is VERY LITTLE REASON TO EQUIP WITH A TN72.
I see small potential justification for equipping with a TN72:
A) visibility to all ADS-B official aircraft directly without rebroadcast (ADS-R) which means they can see me in the pattern a low altitude.
B) Potenially, a TN72 will also give me an alternative to a Satellite tracker if Flight Aware or Aerion makes tracking of ADS-B aircraft less expensive than the current vendors (Spot and Garmin Inreach).
comments...
Walt Rogers WX
Stratus / Foreflight ADSB 6X Soaring 5 December 17th 13 09:34 AM
ADSB is only the start... Martin Gregorie[_5_] Soaring 0 October 1st 09 01:27 PM
Santa and ADSB Mal Soaring 0 December 15th 06 07:42 PM
Non-certified parts for a certified plane? Dico Owning 10 August 22nd 06 03:11 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
