On Friday, September 22, 2017 at 11:48:33 AM UTC-7, John Carlyle wrote:
Darryl, You said "The TN72 does not meet TSO-C145 requirements (so can't be used for ADS-B Out in experimental aircraft where you want to use it to meet 2020 carriage requirements, in the case of gliders can't be used to meet requirements in the few areas where exemptions don't cover)." For those of us who cannot keep up, would you kindly list the requirements where the exemptions don't cover? Many thanks! -John John Start thinking more like a lawyer. Since gliders have broad ADS-B Out carriage exemptions in the areas those exemptions apply they remove the need for you to have ADS-B Out so by definition there is no requirements specific to *those areas* that apply. The regulatory issue is if you have a certified aircraft, regardless of where you intend to or actually fly it the install and equipment has to meet 2020 carriage mandate requirements. That brings in the requirements for a TSO-C145 GPS source (e.g. a TN70 not TN72), and other things like excludes using a Trig TT-21. Darryl |
On Friday, September 22, 2017 at 12:01:13 PM UTC-7, Darryl Ramm wrote:
On Friday, September 22, 2017 at 11:48:33 AM UTC-7, John Carlyle wrote: Darryl, You said "The TN72 does not meet TSO-C145 requirements (so can't be used for ADS-B Out in experimental aircraft where you want to use it to meet 2020 carriage requirements, in the case of gliders can't be used to meet requirements in the few areas where exemptions don't cover)." For those of us who cannot keep up, would you kindly list the requirements where the exemptions don't cover? Many thanks! -John John Start thinking more like a lawyer. Since gliders have broad ADS-B Out carriage exemptions in the areas those exemptions apply they remove the need for you to have ADS-B Out so by definition there is no requirements specific to *those areas* that apply. The regulatory issue is if you have a certified aircraft, regardless of where you intend to or actually fly it the install and equipment has to meet 2020 carriage mandate requirements. That brings in the requirements for a TSO-C145 GPS source (e.g. a TN70 not TN72), and other things like excludes using a Trig TT-21. Darryl 14CFR 91.225 makes it mostly clear. Except I am hesitant to quote it again became it may yet again lead to lots of 10,000' confusion (just knock it off, gliders can operate above 10,000' without ADS-B Out). But basically in a glider you can't fly without a compliant ADS-B out system in Class B or C airspace, and Anywhere below that top of Class B or Class C airspace or 10,000 feet MSL above that airspace, whichever is lower. Folks need to watch this, no clipping under or over (unless you are over 10,000' and above the airspace) corners of class B or C airspace. This is the same as transponder requirements and you should really not be in those areas today without a transponder. Folks who fly gliders near controlled airspace should think about this. And in all it's regulatory glory.... (yes OK gliders also need ADS-B Out in the Gulf of Mexico ADS-B surveillance area, if you out there in a sailplane you may have more problems than ADS-B Out compliance. But hey fly across the coastline in that area without a complaint ADS-B Out and you are violating 14CFR 91.225). 14CFR 91.225 .... (d) After January 1, 2020, and unless otherwise authorized by ATC, no person may operate an aircraft in the following airspace unless the aircraft has equipment installed that meets the requirements in paragraph (b) of this section: (1) Class B and Class C airspace areas; (2) Except as provided for in paragraph (e) of this section, within 30 nautical miles of an airport listed in appendix D, section 1 to this part from the surface upward to 10,000 feet MSL; (3) Above the ceiling and within the lateral boundaries of a Class B or Class C airspace area designated for an airport upward to 10,000 feet MSL; (4) Except as provided in paragraph (e) of this section, Class E airspace within the 48 contiguous states and the District of Columbia at and above 10,000 feet MSL, excluding the airspace at and below 2,500 feet above the surface; and (5) Class E airspace at and above 3,000 feet MSL over the Gulf of Mexico from the coastline of the United States out to 12 nautical miles. (e) The requirements of paragraph (b) of this section do not apply to any aircraft that was not originally certificated with an electrical system, or that has not subsequently been certified with such a system installed, including balloons and gliders. These aircraft may conduct operations without ADS-B Out in the airspace specified in paragraphs (d)(2) and (d)(4) of this section. Operations authorized by this section must be conducted - (1) Outside any Class B or Class C airspace area; and (2) Below the altitude of the ceiling of a Class B or Class C airspace area designated for an airport, or 10,000 feet MSL, whichever is lower. |
Oh, Darryl - think like a lawyer? Can't - I'm a physicist, legal thinking "does not compute".
Many thanks for explaining, and then explaining even more in subsequent posts. Me and my experimental glider are going with a Trig TT22 and a TN 72... -John On Friday, September 22, 2017 at 3:01:13 PM UTC-4, Darryl Ramm wrote: John Start thinking more like a lawyer. Since gliders have broad ADS-B Out carriage exemptions in the areas those exemptions apply they remove the need for you to have ADS-B Out so by definition there is no requirements specific to *those areas* that apply. The regulatory issue is if you have a certified aircraft, regardless of where you intend to or actually fly it the install and equipment has to meet 2020 carriage mandate requirements. That brings in the requirements for a TSO-C145 GPS source (e.g. a TN70 not TN72), and other things like excludes using a Trig TT-21. Darryl |
On Friday, September 22, 2017 at 4:21:56 PM UTC-4, John Carlyle wrote:
Oh, Darryl - think like a lawyer? Can't - I'm a physicist, legal thinking "does not compute". - yeah, after all these years I still cannot make any sense of the wording "any aircraft that was not originally certificated with an electrical system, or that has not subsequently been certified with such a system installed". Had it said "nor" instead of "or", perhaps? (I do have a degree in physics.) |
I asked Trig support this question:
"Will a TT21 + TN72 transmit a non-zero quality indicator?" Here is their reply: "The TT21 is fully certified to the latest ADS-B Out cert TSO C166b – so it can output all the required data. It is true that if you wish to meet ADS-B Out compliance FAR 91.227, you should have a higher power TT22. However, there is no way for the radar to tell if you’re using a TT21 or TT22. Inspection of your aircraft would be the only way to tell. As such I believe a number of experimental pilots have opted to ignore the requirement , but of course I cannot recommend this as it would be in violation of FAR 91.227 – the requirements for 2020 compliance. The TN72 offers both a SIL =1 output, and also a SIL = 3 output. So this means that you can meet the FAA compliance check using your TN72 plus TT21. https://adsbperformance.faa.gov/PAPRRequest.aspx If you so choose, you can opt to have your TT21 upgraded to a TT22. For more information on this please contact our US service centre below; Trig Avionics Technical Support 9400 East 34th Street North Wichita KS 67226 United States Tel: Toll Free 800 821 1212 Tel: +1 316 630 0101 Email: Web: www.mcico.com " The response to my inquiry with is: "The cost to update the TT21 to the TT22 is $950.00. Turn around time is 3-4 days in house." |
Interesting that the information sent out from a 1090ES device doesn't
include enough to identify the model number. But of course an avionics shop or A&P might spot the problem. On 09/27/2017 11:24 AM, son_of_flubber wrote: I asked Trig support this question: "Will a TT21 + TN72 transmit a non-zero quality indicator?" Here is their reply: "The TT21 is fully certified to the latest ADS-B Out cert TSO C166b – so it can output all the required data. It is true that if you wish to meet ADS-B Out compliance FAR 91.227, you should have a higher power TT22. However, there is no way for the radar to tell if you’re using a TT21 or TT22. Inspection of your aircraft would be the only way to tell. As such I believe a number of experimental pilots have opted to ignore the requirement , but of course I cannot recommend this as it would be in violation of FAR 91.227 – the requirements for 2020 compliance. The TN72 offers both a SIL =1 output, and also a SIL = 3 output. So this means that you can meet the FAA compliance check using your TN72 plus TT21. https://adsbperformance.faa.gov/PAPRRequest.aspx If you so choose, you can opt to have your TT21 upgraded to a TT22. For more information on this please contact our US service centre below; Trig Avionics Technical Support 9400 East 34th Street North Wichita KS 67226 United States Tel: Toll Free 800 821 1212 Tel: +1 316 630 0101 Email: Web: www.mcico.com " The response to my inquiry with is: "The cost to update the TT21 to the TT22 is $950.00. Turn around time is 3-4 days in house." |
On Wednesday, September 27, 2017 at 10:24:48 AM UTC-7, son_of_flubber wrote:
I asked Trig support this question: "Will a TT21 + TN72 transmit a non-zero quality indicator?" Here is their reply: "The TT21 is fully certified to the latest ADS-B Out cert TSO C166b – so it can output all the required data. It is true that if you wish to meet ADS-B Out compliance FAR 91.227, you should have a higher power TT22. However, there is no way for the radar to tell if you’re using a TT21 or TT22. Inspection of your aircraft would be the only way to tell. As such I believe a number of experimental pilots have opted to ignore the requirement , but of course I cannot recommend this as it would be in violation of FAR 91.227 – the requirements for 2020 compliance. The TN72 offers both a SIL =1 output, and also a SIL = 3 output. So this means that you can meet the FAA compliance check using your TN72 plus TT21. https://adsbperformance.faa.gov/PAPRRequest.aspx If you so choose, you can opt to have your TT21 upgraded to a TT22. For more information on this please contact our US service centre below; Trig Avionics Technical Support 9400 East 34th Street North Wichita KS 67226 United States Tel: Toll Free 800 821 1212 Tel: +1 316 630 0101 Email: Web: www.mcico.com " The response to my inquiry with is: "The cost to update the TT21 to the TT22 is $950.00. Turn around time is 3-4 days in house." That is some very useful information right there. Two questions: Does the receiver (FAA) have any way to tell more information about the GPS source? If it is transmitting an SIL of 3 (required for carriage requirements), other than physical inspection can a receiver discriminate between a 70 and a 72? What does Powerflarm do with a glider having both ADSB out and Flarm? Does it deambiguize? |
Now that the TN72 is available and relatively low cost, is there a reason for those of us with TT21/TT22 in experimental gliders to wait till 2020 to install the TN72 vs installing now to become more visible to more aircrafts?
I am curious to hear from folks who already done that. Ramy |
On Thursday, September 28, 2017 at 9:51:13 AM UTC-7, Ramy wrote:
Now that the TN72 is available and relatively low cost, is there a reason for those of us with TT21/TT22 in experimental gliders to wait till 2020 to install the TN72 vs installing now to become more visible to more aircrafts? None at all. And there is nothing magic about 2020 that should affect your decision here. Please get started and go do it. We are talking the incremental costs of a few long aerotows. (since I know you fly near SFO Class B at times) keep in mind doing that will not give you access to those areas where the glider exemption does not remove ADS-B Out requirements after 2020 (Class B and C and related, read the regs for details). For that you would need a TN70 based install. I am curious to hear from folks who already done that. Ramy |
On Thursday, September 28, 2017 at 9:12:56 AM UTC-7, jfitch wrote:
On Wednesday, September 27, 2017 at 10:24:48 AM UTC-7, son_of_flubber wrote: I asked Trig support this question: "Will a TT21 + TN72 transmit a non-zero quality indicator?" Here is their reply: "The TT21 is fully certified to the latest ADS-B Out cert TSO C166b – so it can output all the required data. It is true that if you wish to meet ADS-B Out compliance FAR 91.227, you should have a higher power TT22. However, there is no way for the radar to tell if you’re using a TT21 or TT22. Inspection of your aircraft would be the only way to tell. As such I believe a number of experimental pilots have opted to ignore the requirement , but of course I cannot recommend this as it would be in violation of FAR 91.227 – the requirements for 2020 compliance. The TN72 offers both a SIL =1 output, and also a SIL = 3 output. So this means that you can meet the FAA compliance check using your TN72 plus TT21. https://adsbperformance.faa.gov/PAPRRequest.aspx If you so choose, you can opt to have your TT21 upgraded to a TT22. For more information on this please contact our US service centre below; Trig Avionics Technical Support 9400 East 34th Street North Wichita KS 67226 United States Tel: Toll Free 800 821 1212 Tel: +1 316 630 0101 Email: Web: www.mcico.com " The response to my inquiry with is: "The cost to update the TT21 to the TT22 is $950.00. Turn around time is 3-4 days in house." That is some very useful information right there. Two questions: Does the receiver (FAA) have any way to tell more information about the GPS source? If it is transmitting an SIL of 3 (required for carriage requirements), other than physical inspection can a receiver discriminate between a 70 and a 72? There is no GPS Source vendor ID. No Mode-S transponder or UAT Out vendor ID, no serial numbers, no encryption signature, etc. allowed for in the design of ADS-B. The lack of signature is a much more serious shortcoming IMNSHO that any of the others. ADS-B Out systems do transmit SIL, NIC and NAC GPS quality parameters and interestingly CC (capability code) that describe if the aircraft has 1090ES In and/or UAT In. What does Powerflarm do with a glider having both ADSB out and Flarm? Does it deambiguize? Yes it deduplicates them, based in aircraft ICAO address. Presumably PowerFLARM gives priority to the FLARM signal but somebody like Dave would have to confirm that. I believe FLARM also deduplicates Mode S PCAS alerts based on ICAO ID. It can't do that to Mode C PCAS alerts because there is no ICAO address broadcast on Mode C. |
Stratus / Foreflight ADSB | 6X | Soaring | 5 | December 17th 13 09:34 AM |
ADSB is only the start... | Martin Gregorie[_5_] | Soaring | 0 | October 1st 09 01:27 PM |
Santa and ADSB | Mal | Soaring | 0 | December 15th 06 07:42 PM |
Non-certified parts for a certified plane? | Dico | Owning | 10 | August 22nd 06 03:11 AM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
