Removing oxidation from Cobra trailer trim rubber and plastic fenders
Old September 24th 17, 07:12 PM posted to rec.aviation.soaring
Roy B.
Default Removing oxidation from Cobra trailer trim rubber and plastic fenders
Hi Dave:
On my Nimbus I masked the trim and hit it with Krylon brand "Fusion" spray paint. It bonds to plastic well. Also - Spindleberger sells replacement trim if you like.
Roy
Old September 25th 17, 02:40 PM posted to rec.aviation.soaring
I did what Roy did, knock off the crud with wire brush and 80 grit sandpaper, then mask and shoot with rattle-can, changed to blue. I used 2" tape on top and a 3 foot piece of cardboard below the lip.......spraying 2 foot at a time with the can aimed down 45 degrees. I'm buffing the glass top now........good winter projects.
JJ
Old September 25th 17, 04:25 PM posted to rec.aviation.soaring
Dan Marotta
Default Removing oxidation from Cobra trailer trim rubber and plasticfenders
Curious - why blue instead of red?Â* Something to do with solar radiation?
On 9/25/2017 7:40 AM, wrote:
I did what Roy did, knock off the crud with wire brush and 80 grit sandpaper, then mask and shoot with rattle-can, changed to blue. I used 2" tape on top and a 3 foot piece of cardboard below the lip.......spraying 2 foot at a time with the can aimed down 45 degrees. I'm buffing the glass top now.......good winter projects.
JJ
Dan, 5J
Old September 25th 17, 05:05 PM posted to rec.aviation.soaring
It's a general phenomenon. Red paint/pigments etc reflect longer wavelengths and absorb more blue and UV. Blue reflects more blue and UV so it fades less. Blue cobra trim fades little. Red much more. In the UK some older red cars often become very faded (especially Vauxhall/Opels)
Cobra trailer trim [email protected] Soaring 11 September 5th 13 03:54 PM
Cobra trailer wing dolly plastic sidewall rollers? [email protected] Soaring 4 May 9th 13 10:52 PM
plastic or metal fenders on the trailer? chris Soaring 14 December 20th 10 09:51 PM
Cobra trailer trim. Bob Soaring 12 July 19th 06 05:12 AM
Help - Cobra Trailer Trim? WDM Soaring 2 January 12th 05 07:47 PM
