Glider near miss with Airliner (emergency climb) near Chicago yesterday?
Old October 5th 17, 10:14 PM posted to rec.aviation.soaring
Bruce Hoult
Default Glider near miss with Airliner (emergency climb) near Chicago yesterday?
On Thursday, October 5, 2017 at 10:12:39 PM UTC+3, wrote:
The 250 limit is "indicated air speed" not true air speed. The airliner was probably doing ~300 knots at the time of the encounter.
Well that's weird, because a B737 or A320 or whatever cruising at Mach 0.78 at 35000 ft only has an IAS/EAS of 250 knots *anyway*, even though the TAS is 450.
So unless they go faster on descent the 250 limit is pretty much meaningless.
Old October 5th 17, 10:35 PM posted to rec.aviation.soaring
jfitch
Doesn't seem like you thought about that one much. There is no speed limit at 35000 so it is already meaningless. By the altitude that it becomes meaningful, it is meaningful.
Old October 5th 17, 11:10 PM posted to rec.aviation.soaring
Bruce Hoult
Really?
So what's the typical maximum IAS seen on a typical 737 flight, then?
They have an Mmo of 340 knots, but I doubt they usually get anywhere near it.
Old October 6th 17, 12:54 PM posted to rec.aviation.soaring
Never flown a 737, but they are probably at or near Mmo during descents and in cruise at lower alititudes.
There are several airline pilots that are also glider pilots, so maybe they will reply.
Although, they may be too busy for ras.
If it helps, the IAS for a C560 at FL410 is usually around 230 kias which is ~420 true.
At FL350 the indicated is 250 and below FL250 the power must be reduced to stay below Vne of 290 even in cruise.
Descents from high altitude can only be at full power for a few minutes before Vne is reached and typical descents are done at reduced power.
If allowed by ATC to descend at pilot discretion, then it is easy to descend at Vne with reduced power to the assigned altitude.
If an expedited descent or agressive crossing restriction is given, then the descent may be at idle and sometimes even with spoilers out to stay below Vne.
Obviously the lower the aircraft is (i.e. closer to standard sea level pressure and temperature) the closer the indicated airspeeds is to the true airspeed.
It is usually necessary to start slowing down by 15,000 to be under the 250 knot speed limit at 10,000.
290 kias at 15,000 is 380 knots and 250 kias at 10,000 is 300 knots.
Stinson Airliner pics 1 [04/11] - Chicago Municipal Airport - American Airlines - Stinson Model A Tri-Motor.jpg (1/1) Miloch Aviation Photos 0 August 14th 17 02:55 PM
Need to move a glider from Chicago to Los Angeles Maciek Arkuszewski Soaring 14 May 18th 16 11:59 PM
Aug 6th B738 and Glider Near Miss. Frankfurt Karen Soaring 70 October 23rd 10 05:27 AM
Glider-Airliner Near Miss jcarlyle Soaring 0 June 12th 07 04:52 PM
Report on "Old" Glider/airliner midair? Jim Kellett Soaring 5 October 13th 03 02:20 PM
