removing mylars at every annual?
Old October 10th 17, 10:44 PM posted to rec.aviation.soaring
Tom Kelley #711
Default removing mylars at every annual?
On Tuesday, October 10, 2017 at 3:20:13 PM UTC-6, Darryl Ramm wrote:
On Tuesday, October 10, 2017 at 2:10:23 PM UTC-7, krasw wrote:
If you have proper sealing, teflon tape under mylar, it is not possible to lubricate hinges. Use upper mylar to prevent water or dust entering hinge. Change everything after 3-5 years and lubricate using grease, not anything that comes out of spray can as it is only cosmetics.
Sure you can, if you want to, you stick a large hypodermic needle thought the teflon barrier tape and apply oil from a syringe.
Hmmmm.........you might want to check your bottoms!
Best. Tom #711
PS glad your not Doctor giving me a shot!
Old October 10th 17, 11:35 PM posted to rec.aviation.soaring
Darryl Ramm
Best. Tom #711
Tom when you eventually make it out to CA I can demonstrate how to apply an oil injection. You'll hardly feel it.
Removing flux? Michael Horowitz Home Built 6 July 22nd 10 12:33 PM
Removing 2-33A wheel lanebush Soaring 2 June 27th 09 02:15 PM
Removing RTV John Home Built 6 October 31st 06 10:07 PM
Removing Decals [email protected] Home Built 85 September 9th 05 11:58 PM
Removing old antennas Jay Honeck Owning 30 March 21st 04 04:34 PM
