removing mylars at every annual?
Old October 10th 17, 11:35 PM posted to rec.aviation.soaring
Darryl Ramm
Default removing mylars at every annual?
On Tuesday, October 10, 2017 at 2:44:15 PM UTC-7, Tom Kelley #711 wrote:
On Tuesday, October 10, 2017 at 3:20:13 PM UTC-6, Darryl Ramm wrote:
On Tuesday, October 10, 2017 at 2:10:23 PM UTC-7, krasw wrote:
If you have proper sealing, teflon tape under mylar, it is not possible to lubricate hinges. Use upper mylar to prevent water or dust entering hinge. Change everything after 3-5 years and lubricate using grease, not anything that comes out of spray can as it is only cosmetics.
Sure you can, if you want to, you stick a large hypodermic needle thought the teflon barrier tape and apply oil from a syringe.
Hmmmm.........you might want to check your bottoms!
Best. Tom #711
PS glad your not Doctor giving me a shot!
Tom when you eventually make it out to CA I can demonstrate how to apply an oil injection. You'll hardly feel it.
Old October 11th 17, 08:23 AM posted to rec.aviation.soaring
krasw
Hole in airtight seal, interesting.
Old October 11th 17, 08:49 AM posted to rec.aviation.soaring
Darryl Ramm
Oh no, a few hypodermic needle holes. Maybe the massive bleeding of air though those tiny holes will affect the handling, and the gliders will fall out the sky.... it's amazing whole fleets of gliders maintained in this way have not fallen out of the sky, or had any other apparent problems...
Old October 11th 17, 11:26 AM posted to rec.aviation.soaring
krasw
Well why seal at all then, the glider flies perfectly well anyway?
Old October 11th 17, 01:47 PM posted to rec.aviation.soaring
My wing ends up with 2 holes at each hinge, made with a sharp 20 gauge needle.
These holes mostly close back up anyway. Given that they are on the high pressure side of the wing, underneath a close fitting wiper seal, I doubt that a meaningful affect on performance results.
This is a well proven technique.
UH
Old October 11th 17, 02:59 PM posted to rec.aviation.soaring
It's pretty early for the annual winter discussion/argument about spray lubricants, but what the hell.........
After retiring from the AF, I took the GI bill and antended Sacramento City College who offered a 2 year program in aeronautics leading to an AA degree and an A&P license. Their aero club flew a fleet of light aircraft and the students maintained them. What lubricant was taught and used? Good old WD-40! The thinking was that a brief shot would loosen old grease and any over spray would soon evaporate. I have several long tube setups to allow a brief shot of lube into hard to get to areas like all points on the landing gear and deep inside the fuselage or way inside the wing. How do you "oil only" guys lube these areas?
Flame suit on,
JJ
Old October 11th 17, 03:33 PM posted to rec.aviation.soaring
Flame suit on,
JJ
I use syringes with several different needles, the longest is a spinal needle about 6 inches long. Lets me get pretty much wherever I need to get. Needles also allow working oil inside felt seals. To loosen stuff up I like a 50-50 mix of light oil(20 weight) and Marvel Mystery Oil. Does a pretty good job of softening up old goo. Also use WD-40 as a clean up fluid, but not as a lubricant. WD-40 leaves a film coating which is what it was originally created for. WD= Water Displacement. Really good for corrosion prevention in metal ships.
Mostly my message is don't spray **** all over.
FWIW
UH
Old October 11th 17, 10:09 PM posted to rec.aviation.soaring
Jonathan St. Cloud
WD 40 is the 40th formula tried for Water Displacement (i.e., anti-rust), It is kerosene and perfume, not a lubricant. Tri-flow is a is a great lubricant for aileron hinges, or lead-lag hinges on helicopters.
Flame suit on,
JJ
Removing flux? Michael Horowitz Home Built 6 July 22nd 10 12:33 PM
Removing 2-33A wheel lanebush Soaring 2 June 27th 09 02:15 PM
Removing RTV John Home Built 6 October 31st 06 10:07 PM
Removing Decals [email protected] Home Built 85 September 9th 05 11:58 PM
Removing old antennas Jay Honeck Owning 30 March 21st 04 04:34 PM
