Is there a nose hook modification for a standard cirrus
Old October 12th 17, 05:00 AM posted to rec.aviation.soaring
Tim Taylor
Default Is there a nose hook modification for a standard cirrus
In general the cg hook is not an issue on S-H gliders if the glider is correctly set-up. The important things that need to be checked and done:
1. Replace a tail skid with a tail wheel.
2. Make sure the tail wheel is rubber and not hard plastic like some of the early models.
3. The tail wheel needs to be aligned with the glider so that it tracks straight. This can be tested by holding the wings level and pushing the glider on a flat surface for several hundred feet. No deviation should be found..
If all of the above have been done the glider should track straight on normal take-off. You can also hold back on the stick during the initial few seconds of roll to help hold a straight line in cross-winds until more rudder athority is gained and the tail is raised.
nose section from salvaged standard cirrus. Scott Williams Soaring 1 May 27th 17 04:58 PM
Jantar standard SZD-41A C.G. hook Žiga Munda Soaring 3 November 24th 15 02:00 AM
Standard Cirrus C-Hook Randy[_2_] Soaring 26 September 26th 08 10:24 PM
Hook up an mini headset to a Vertex Standard VX150 or 210 radio Peter Soaring 2 July 3rd 06 04:49 PM
Nose hook addition Jack Soaring 2 April 29th 06 08:08 AM
